Hi - I created an event 3 weeks ago, now nothing happens when i try to create an event. I am going nuts. Does anyone have a solution?
I have done all of the recommended troubleshooting:
Updated Chrome, cleared cache
Tried on Chrome, Incognito, Firefox
My permissions (Admin) are the same as developer’s permissions
No events start/end restrictions
Groups set to be able to create events include Admin
I am creating topic within category that is allowed in settings for events
Turned off all browser extensions except LastPass
Main thing is - developer can create, and I cannot, so it seems to be a computer issue (??)
He is wondering if it is a timezone issue of some sort. He is in India and can create (only after he deleted the start/end restrictions). I am in California and cannot create. But I did create once weeks ago!
When the month and day are swapped, dates Sept 1 - Sept 12 are valid dates (Jan 1 - December 1) but September 13 becomes invalid (there is no first day of the thirteenth month).
I bet you can create an event between October 1st and October 12th.
Hi Tomas - Yes I am entering the date in the preset calendar as well, not entering it manually. That works for you and creates the event?
PS I might have flagged your reply (and mine) by mistake. I was logged out and trying to hit the reply button, but that doesn’t appear unless you are logged in.
Hi Tobias - Thanks for checking in to see how things are going on this post. No, I haven’t found a solution. When I hit the Create Event + sign it just doesn’t do anything at all… It’s a dead end. Developer can create an event, and I cannot… Do you have any ideas on how I could troubleshoot beyond what I’ve done already (see above)?
Мой хост Communiteq решил этот вопрос! Они сказали, что я должен добавить событие на САМУЮ ПЕРВУЮ СТРОКУ. Я сделал это, и всё заработало! Раньше, когда это не работало, я добавлял какой-то текст первой строкой, а ПОТОМ уже событие. Это неправильно и приводит к тому, что событие не отображается.
