Horizon Theme: Incorrect Reply Count Display
Hello,
I’ve discovered a bug when using the official Horizon theme. It seems to be incorrectly displaying the reply count for topics.
The issue: The number of replies shown for any given topic is consistently one higher than the actual number of replies. For example, if a topic has 5 replies, the theme displays “6 replies.” This is a persistent issue and can be reproduced on any topic when the Horizon theme is active.
Thank you for your hard work!
If I’m not wrong, the ‘5’ refers to the number of posts including the topic post, but the ‘4’ refers to the actual number of replies.
If you look at the topic timeline:
But perhaps the icon is a bit misleading :thinking:.
Thanks for the report, good catch! Pretty sure that wasn’t our intention and we’re just doing some special maths :wink:
It will get fixed soon.
