Removed Moderator still has Moderator Flair?
Hello.
In a forum I moderate for, a moderator was removed several months ago but they still have the moderator flair icon next to their avatar, and neither me (a moderator) nor a Forum admin can figure out how to actually remove this flair from them.
Our forum is currently on 3.6.0.beta2-latest and was just updated today to that, and the flair still remains.
How can we remove this flair icon from the user?
לייק 1
You can impersonate the user and remove the flair. IIRC when a user leaves a group that has a flair, the flair stays. I believe it can be removed in the user preferences.
My forum admin tried that earlier and the flair dropdown was not there.
לייק 1
Seems like this bug has been here for a while, reported here:
You may also want to try the Rails command suggested in User flair remains after user is removed from group.
2 לייקים
Just to confirm if you are using category moderator groups that they are not in any of those groups?
Hello, we managed to isolate the cause and fix it a few days ago.
The former moderator was not a member of any flared group. What we had to do was add them to another group with a flair, then the admin impersonated and changed the Flair to “none” and then we removed them from the group.
Seems like a general bug where if you are removed from a group with a flair equipped, the flair stays despite not being a member.
2 לייקים
If this is a bug we should fix it.
לייק 1
