Introducing Upcoming Changes, a system to manage new features and changes to existing functionality in your community
lindsey announced the launch of Upcoming Changes, a new admin system at /admin/config/upcoming-changes designed to help administrators manage and test new features and functional changes in their Discourse communities. The system replaces the previous experimental settings area, offering a structured workflow for rolling out updates. Each change entry includes a name, description, status (e.g., Experimental, Beta, Stable, Permanent), and an “Enabled for” dropdown allowing admins to apply changes to No one, Everyone, Staff only, or Specific groups. This enables safe, transparent testing by letting admins opt-in to new features or temporarily opt-out to address compatibility issues with customizations before changes become permanent.
The announcement generated significant community feedback. NateDhaliwal asked about rollout controls, to which lindsey clarified that admins receive notifications when changes are ready for opt-in testing or when a disabled change is scheduled to become permanent. merefield praised the feature flags but requested an API for plugins; martin explained that while plugins can technically use the system via hidden site settings and YAML metadata, it was primarily designed for core Discourse development.
Discussion also focused on visibility and configuration for self-hosters. sniper756 and ToddZ struggled to find the menu item, with martin explaining that self-hosters must enable the hidden enable_upcoming_changes site setting via the Rails console until the system is fully stable. Moin requested the ability to sort changes by status, a feature martin agreed to implement. Additionally, noahl asked for direct links to related settings; martin implemented this fix shortly after.
A key clarification emerged regarding rollout timelines. mcwumbly noted that while hosted sites automatically enable Beta changes, self-hosters previously waited until Stable. Following community input, mcwumbly confirmed a pull request to align self-hosters with Beta auto-enablement to provide earlier feedback opportunities, though martin emphasized that changes remain opt-outable until they reach Permanent status.
Later posts addressed specific UI behaviors. EricGT reported missing “Preview” links in notification URLs, which martin clarified are optional developer implementations. Lilly sought to disable admin notifications, leading to community-shared workarounds. Finally, Ethsim2 inquired about retaining the legacy admin dashboard; mcwumbly confirmed the old dashboard would be fully removed once the new one became permanent, though its functionalities would be integrated into the new interface.
As we continue to improve Discourse, we’ve created a new Upcoming Changes config page to help admins understand what changes are coming to Discourse and let them manage how those changes are implemented in their community. We believe this system will help us keep improving Discourse in a safe, transparent way.
In this topic, we’ll explain how this new system works and how to use it to safely introduce new features and other changes in your community.
Overview of how Upcoming Changes works
As we work on new features or other changes, we will add them to the Upcoming Changes config page at /admin/config/upcoming-changes. Each change will include a description, status, indicator of which users are impacted by it, and which users (if any) it is enabled for in your community.
Depending on the change’s status, you can decide whether to turn it on or off for your community — at least temporarily, since some changes will eventually be turned on permanently.
Temporarily disabling a change gives you time to address any impacted site customizations, processes, and so on, inform your member base about the change, or deputize certain member groups for testing.
Dissecting an Upcoming Change
Let’s dissect an Upcoming Change and define the information you’ll see in each section.
1 - Name and description
The name and description give you a brief explanation of the change and will link to related Meta topic for additional information and a place to collect feedback.
2 - Status
The status communicates its position in the development lifecycle. Status directly impacts whether the change is opt-in (i.e. off by default, but you can turn it on), opt-out (i.e. on by default, but you can turn it off), or forced on (i.e. on, and you can’t turn it off).
We use the following statuses in Upcoming Changes:
  • Experimental: A potential change that is in early development / testing and is expected to evolve rapidly, or may be removed altogether if we end the experiment (at which point it will move to Inactive status; see below). You may opt-in to Experimental changes to test them out.
  • Alpha: A tested change that is safe to use, though there may be some minor updates to its design or functionality. You may opt-in to Alpha changes to use them early.
  • Beta: A tested change that is safe to use, and is unlikely to change much before moving to Stable or possibly Permanent status.
    • :information_source: For most sites on our hosting, and for self-hosted sites, Beta changes are automatically turned on for everyone (if you haven’t previously enabled it), but you may still opt-out.
  • Stable: A completed change[1] , but is still opt-out (i.e. admins can disable it). Admins will be warned on their dashboard when they have opted-out of a Stable change.
  • Permanent: A change that has completed testing, and is forced on (i.e. admins cannot disable it). Permanent changes will no longer appear in the upcoming changes list, instead they will be shown on the /admin/whats-new page.
  • Inactive: An abandoned experiment. You cannot opt-in.
Sometimes, changes will move linearly through these statuses (i.e. start in Experimental and end in Permanent), but not always. Some changes may be introduced in Alpha or Beta status, and some will end in Stable status. Changes that are of the type “site setting default” will not be moved to Permanent, since they are only changing the default value of an existing setting.
There is no set time for how long it will take a particular change to progress from one status to another, but admins will be notified when:
  • A new change is available to try out
    • These are sent at most once per week to avoid notification fatigue. If you prefer not to receive these notifications, you can disable them in /my/preferences/notifications
  • A change has been enabled automatically
  • When you have disabled a change that will soon be forced on
    • This will be shown as an admin dashboard warning
3 - Impacted users
The impacted users tag describes which users in your community can see or interact with the change in some way. To put it simply — who might notice this change? There are several types of impacted users:
  • Admins: The change is only visible to admins.
  • Staff: The change is only visible to admins and moderators.
  • All members: The change is visible to all members on your site.
  • Developers: In rare cases, a change will only be noticeable to those who are interacting with code in core, themes, or plugins.
Impact type
A subset of impacted users, and not shown in the list, is the impact type. The impact type describes how the change will affect your community in a broad sense:
  • Feature: The change introduces a new feature or functionality to your community, or modifies existing functionality.
  • Site setting default: The change modifies the default value of an existing site setting. Admins who have already changed the setting off its old default will not be affected. No admin dashboard warning will be shown for this change once it reaches Stable.
  • Other: Any other change that doesn’t fit into the above categories.
4 - Enabled for…
This drop-down is where you, as the site admin, can control whether and how to introduce this change to your community by enabling it for:
  • No one: Disables the change for everyone on the site.
  • Everyone: Enables the change for everyone on the site, including anonymous users. When the change is automatically turned on (typically at Beta status), it will be for Everyone.
  • Staff only: Enables the change for site staff (i.e. admins and moderators).
  • Specific groups: Enables the change for the selected group(s).
:information_source: Some upcoming changes may have restricted “Enable for” options. The available options in the “Enabled for” dropdown are determined by the change’s configuration. For example, certain changes might only allow Everyone and No one options, since limited group testing would be infeasible for the change.
For now, we have moved most Experimental changes from /admin/config/experimental into Upcoming Changes, and you’ll start seeing new updates land here soon. We’re looking forward to hearing about the impact this makes in your community, and welcome any questions or feedback!
  1. Insofar as any software is complete! ↩︎
I’m curious - how does it control how the change is rolled out? Can it be changed after the feature is introduced? Thanks.
Native Feature Flags! Very good :clap:
Be great to have an API for plugins.
That’s a long-awaited feature! Thanks!
This is great, having the ability to change flags like this is amazing for people on the bleeding edge like myself especially when developing a theme
Is “upcoming changes” really the best name for it though? For example HomeAssistant uses “labs” and a lot of other people just use stuff like “experiments” which feel better than upcoming changes.
You’ll be notified of new features while they are still in a state where you can try it out early (opt-in) and turn it off temporarily to fix any issues caused by the change (opt-out). If a change is going to become permanent (which means you can’t opt-out) and you’ve currently turned it off, we’ll let you know.
This section describes that in a little more detail:
Right now, you’re seeing only experimental changes because we migrated those over from the settings area to Upcoming Changes, but in the future there will be non-experimental updates here, too. So “labs” doesn’t feel accurate for how we are using this system.
Plugins can already use this system. The OP doesn’t go into the technical ins-and-outs, but there is not much needed to add an upcoming change.
The quick summary is:
  • Add a site setting which is hidden: true and client: true
  • Add a description for the setting in server.en.yml
  • Optionally add a screenshot to public/images/upcoming_changes/SETTING_NAME.png
  • Add upcoming_change metadata to the setting, which looks like this:
# upcoming_change       - Additional metadata with the following options to show in the /admin/config/upcoming-changes page:
#                          - status: experimental | alpha | beta | stable
#                          - impact: two parts separated by comma - feature|other , staff|admins|moderators|all_members|developers
#                          - learn_more_url: a url for more information
However the caveat here is that we haven’t really intended to have third party plugin developers use this system, it was mostly for our own purposes. Maybe over time we can think more about this use case.
Love this! Thank you :raising_hands:
Is it possible to have a link/shortcut to the applicable setting if relevant? e.g. the custom splash screen has additional settings that need setting up for it to work (uploading the SVG) - but you have to actively go and find them. Would be helpful to have them alongside where it’s being enabled
Yes indeed! I’m working on that change now, should be available in the next day or two, I will make a note to deploy your hosted site so you get the update :slight_smile:
Edit: Done! :rocket:
I have a question, for a self-hosted Discourse instance, how do I display these “Upcoming Changes” in the admin panel?
@lindsey
We still have this hidden behind a global enable_upcoming_changes site setting which is hidden, so you can enable this in your site’s rails console with rails c. Eventually we will remove this and you won’t have to anymore.
Okay, thank you, I’ll wait then~
I’m not sure if this was clear: the menu item for Upcoming Changes isn’t live yet, but …
rephrasing:
If you don’t have the menu item yet, you can still see the Upcoming Changes section by going to [your_forum]/admin/config/upcoming-changes
It should be, you don’t see it here?
Are you self-hosting? If so you will also need to set enable_upcoming_changes (which is a hidden setting) to true. We plan to remove this in the not-too-distant future once we are completely sure the system is stable.
Is there a reason why most site settings for upcoming changes are hidden, but enable_auto_grid_images is not?
Nope, just an oversight, fixed here:
Yes, I’m self-hosting, like sniper756.
“isn’t live yet” was maybe not the best phrasing; I’ll edit.
Today, I was thinking it would be handy if I could sort the changes by status - first beta, then alpha, and finally experimental. I know I can filter by that, but I like to see the whole list; I just find changes more or less interesting depending on their status.
Yep makes sense, I have also thought about adding a sort option based on when the change appeared on your site…will add both :smiley:
Fantastic addition!
Thank you for this.
