CSS personalizzato all'interno di un post / aggiunta di classi personalizzate
Is it possible to give a <div> inside a post some custom styling?
I’ve seen that any non-whitelisted classes are stripped out, and I’ve tried addingstyle= to my divs and spans to no avail , so does anyone know if there’s a way to do that?
Basically I have a bot that posts from an internal tool and I’d like to have it post with something that looks like the tool to make it obvious that it’s not a regular disourse post, something like this:
It’s got a couple of nested divs/spans to make it look nice and they each have their own associated css.
Ideally if the bot could post something like this:
<div class="mytool">
  <div class="item">
    <div class="name">Machine64</div>
    <div class="message">Top Secret operation has executed sucessfully</div>
  </div>
  <div class="item">
    <div class="name">Device 08</div>
    <div class="message">Test operation failed at 16:22</div>
  </div>
</div>
those extra classes would be specified in the global discourse css, but even if I could lump all my styling into style tags, that would solve my problem.
Any ideas on how I could do this? Thanks!
2 Mi Piace
This might not be appropriate for dev, but I wasn’t sure where it should go as it’s not really theme-ing or plugin either! Please move if it’s in the wrong place :slight_smile:
Styles/classes are stripped out, but you can use data-theme-* attributes to target things in posts:
<div data-theme-bot>
   Content here
</div>
For example, this paragraph is wrapped in a data-theme-bot div
And then in a theme, target it like:
div[data-theme-bot] {
  background-color: red;
15 Mi Piace
This is perfect; thank you so much!
4 Mi Piace
Thanks @david!
However, how would I go about changing styling for tags (such as <a> or <span>) within this div?
In SCSS:
  a {
Or in plain CSS
div[data-theme-bot] a {
4 Mi Piace
Thank you @david! That does it.
2 Mi Piace
@david Ho inserito il tuo esatto div in un argomento e aggiunto questo CSS a un componente del tema
  color: red;
L’ispettore mostra div data-theme-bot (racchiuso tra < >), ma il colore calcolato è var(--primary) html
Devo aggiungere selettori aggiuntivi o modificare un’impostazione dell’amministratore? Grazie.
Ho appena provato lo stesso codice e funziona correttamente per me. Forse prova:
  color: red !important;
Se funziona, significa che qualche CSS da qualche altra parte (un tema, un componente o un plugin) aveva una specificità maggiore rispetto a questo stile, quindi veniva sovrascritto.
3 Mi Piace
Hai ragione. Credo di aver avuto un problema di cache nel mio browser.
Questo trucco è un elemento importante per pubblicare i miei post di WordPress su Discourse e farli apparire simili alla versione WordPress.
Grazie a tutti.
1 Mi Piace
