DiscoTOC - automatic table of contents
We target the immediate child headings to exclude headings in quotes or oneboxes and other elements in the Table of Contents. Otherwise, we’d have to exclude them individually, which can be tedious.
Hi,
How we can make title in the table bold and sub-title normal font ?
Hello! You have to do it with CSS.
Thanks but i don’t have experiance in CSS, is there some ready template for that ?
You should be able to add something like this to the CSS section of your site theme:
.d-toc-heading > li > a {
  font-weight: bold;
…which would look like this:
DiscoTOC is a great component, thank you very much.
Is there a chance to get this working in combination with the
Plugin?
It’s work good thanks, but how can i add this bold font for sub-sub-font ?
ex:
headfont
sub-headfont
sub-sub-headfont
sub-sub-sub-headfont
since i have 4 level of sub fonts inside the context.
Thanks
Sorry, I’m not sure I understand - do you want the same font for all the links in the Table of Contents? If so, you could probably use something like this:
#d-toc a {
  font-weight: bold;
If you want different styles for different levels of heading, you’ll need something a bit more complicated:
// Style for first-level headings
  font-weight: bold;
// Style for second-level headings
.d-toc-heading > li > ul > li > a {
  color: red;
// Style for third-level headings
.d-toc-heading > li > ul > li > ul > li > a {
  color: green;
// etc.
Note that this is quite closely tied to the implementation of the theme component, so if that ever changes, you might need to update these rules.
Thank you so much, this is what i want.
There are currently no plans to support published pages. It is supported alongside the docs plugin.
Does anyone have an issue with DiscoTOC being displayed in desktop mode while in :iphone: mobile view?
We had the issue on 2.7.x and even after 2.8. update it persists, see here:
Excuse me! Joe
Today, i update Discourse, My DiscoToc full right Display but broken screen width.
I update newest Disco Toc theme Component.
Can you continue to fix this issue.
https://nganhangbatdongsan. com/t/bang-gia-xem-data-nha-chinh-chu/63389
Thank you!
So that’s not a problem of DiscoTOC, it’s because you have the layouts plugin taking up space as well.
Still getting the same issue; have had to remove the old version of DiscoTOC that was at least installing/working as it doesn’t work with the latest Discourse.
The /log summary is:
Aws::S3::Errors::InvalidArgument (Unsupported value for canned acl 'public-read')
lib/s3_helper.rb:74:in `upload'
lib/file_store/s3_store.rb:116:in `store_file'
lib/file_store/s3_store.rb:30:in `store_upload'
lib/upload_creator.rb:212:in `block (2 levels) in create_for'
lib/upload_creator.rb:211:in `open'
lib/upload_creator.rb:211:in `block in create_for'
lib/distributed_mutex.rb:33:in `block in synchronize'
lib/distributed_mutex.rb:29:in `synchronize'
lib/distributed_mutex.rb:14:in `synchronize'
lib/upload_creator.rb:64:in `create_for'
app/models/remote_theme.rb:164:in `block in update_from_remote'
app/models/remote_theme.rb:160:in `each'
app/models/remote_theme.rb:160:in `update_from_remote'
app/models/remote_theme.rb:93:in `import_theme'
app/controllers/admin/themes_controller.rb:104:in `import'
app/controllers/application_controller.rb:397:in `block in with_resolved_locale'
app/controllers/application_controller.rb:397:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:358:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:202:in `call'
And backtrace:
aws-sdk-core (3.121.2) lib/seahorse/client/plugins/raise_response_errors.rb:17:in `call'
aws-sdk-s3 (1.96.1) lib/aws-sdk-s3/plugins/sse_cpk.rb:24:in `call'
aws-sdk-s3 (1.96.1) lib/aws-sdk-s3/plugins/dualstack.rb:36:in `call'
aws-sdk-s3 (1.96.1) lib/aws-sdk-s3/plugins/accelerate.rb:50:in `call'
aws-sdk-core (3.121.2) lib/aws-sdk-core/plugins/jsonvalue_converter.rb:22:in `call'
aws-sdk-core (3.121.2) lib/aws-sdk-core/plugins/idempotency_token.rb:19:in `call'
aws-sdk-core (3.121.2) lib/aws-sdk-core/plugins/param_converter.rb:26:in `call'
aws-sdk-core (3.121.2) lib/seahorse/client/plugins/request_callback.rb:71:in `call'
aws-sdk-core (3.121.2) lib/aws-sdk-core/plugins/response_paging.rb:12:in `call'
aws-sdk-core (3.121.2) lib/seahorse/client/plugins/response_target.rb:24:in `call'
aws-sdk-core (3.121.2) lib/seahorse/client/request.rb:72:in `send_request'
aws-sdk-s3 (1.96.1) lib/aws-sdk-s3/client.rb:11274:in `put_object'
aws-sdk-s3 (1.96.1) lib/aws-sdk-s3/object.rb:1329:in `put'
actionpack (6.1.4.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.1.4.1) lib/abstract_controller/base.rb:228:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.1.4.1) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:117:in `block in run_callbacks'
i18n (1.10.0) lib/i18n.rb:328:in `with_locale'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:126:in `block in run_callbacks'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:137:in `run_callbacks'
actionpack (6.1.4.1) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
activesupport (6.1.4.1) lib/active_support/notifications.rb:203:in `block in instrument'
activesupport (6.1.4.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.1.4.1) lib/active_support/notifications.rb:203:in `instrument'
actionpack (6.1.4.1) lib/action_controller/metal/instrumentation.rb:33:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
activerecord (6.1.4.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.1.4.1) lib/abstract_controller/base.rb:165:in `process'
actionview (6.1.4.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.3.4) lib/mini_profiler/profiling_methods.rb:111:in `block in profile_method'
actionpack (6.1.4.1) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.1.4.1) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
actionpack (6.1.4.1) lib/action_dispatch/routing/mapper.rb:49:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:842:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
actionpack (6.1.4.1) lib/action_dispatch/http/permissions_policy.rb:22:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:98:in `run_callbacks'
actionpack (6.1.4.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.10.1) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.1.4.1) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.1.4.1) lib/rails/rack/logger.rb:28:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/host_authorization.rb:92:in `call'
rack-mini-profiler (2.3.4) lib/mini_profiler/profiler.rb:393:in `call'
message_bus (4.2.0) lib/message_bus/rack/middleware.rb:60:in `call'
railties (6.1.4.1) lib/rails/engine.rb:539:in `call'
railties (6.1.4.1) lib/rails/railtie.rb:207:in `public_send'
railties (6.1.4.1) lib/rails/railtie.rb:207:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.7.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/2.7.0/bin/unicorn:25:in `<main>'
The URL from the env summary was: REQUEST_URI /admin/themes/import - so I’m pretty sure I’ve got the right error.
Maybe I’ve unintentionally set things up in a non-standard way. I have Backblaze (S3 API) configured in app.yml with DISCOURSE_USE_S3 commented out, but all other S3 settings entered. DISCOURSE_BACKUP_LOCATION is set to S3. The goal was to keep local image etc uploads but have backups go to Backblaze. None of the S3 settings appear to be enabled in the admin web pages. Backups have been appearing on Backblaze, and I can still add images etc- so I assumed all is good.
Any suggestions appreciated!
This isn’t a DiscoTOC issue. Please search for Backblaze here on meta to see if you can find the solution to your issue. (And if you don’t find one, feel free to open a separate support topic.)
We’re getting an error after upgrading Discourse:
Screenshot from 2022-02-25 18-35-43
edit: oh no, sorry. that’s on an instance that is not updated. It’s probably because of that.
In case this helps others, I was struggling to add a ToC to a seemingly-properly formatted post & it kept not showing up. Finally I checked edit history:
Selection_022
Moving the tag to a new line (and whittling it down to just one instance) fixed the problem.
Hi, I face the following issue.
If there are chinese headings, TOC link can not link to correct location.
For example, KeepZotero 防止 Zotero 被關掉 - 綜合討論 - TW Community
Clicking the 2nd-5th links from right side table always shift to second heading position not the corresponding position.
If click the link on heading left side, it works and the link is like ${topic-url}#h-4
Is it the same issue as Bug of DiscoTOC with Chinese Headings - bug - Discourse Meta mentioned?
I believe it is the same
I try your fix on my site and it works correctly.
Do you plan to create a pull request?
