Discourse AI - Embeddings
Yes.
Yes, each model produces different vector representations.
It’s basically one call per topic, so very easy to calculate.
If most of your topics are long, they will be truncated to 8k tokens, otherwise they will use your topic length.
Yes.
Both work at the topic level, so one per topic.
May I know how to properly add the gems without forking the plugin with the suggested PR?
I’m trying the scale-to-zero feature on HuggingFace and I just need to use the rake task for backfill embeddings.
why return 418 error code when I using discourse ai embeddings full search in DiscourseAi::Embeddings::EmbeddingsController#search as JSON? Could you help me?
3 posts were split to a new topic: Gemini Embeddings Issue After Discourse Update to 3.6.0 Beta 2
2 posts were split to a new topic: Gemini API Embedding Configuration Clarification
