Discourse Transclusie (Citeren tussen Discourse-instanties)
A decade ago there was a similar discussion, but it didn’t go anywhere. Now, we have a bit more experience and tools…
Imagine you are the Discourse Team, and you’re using one public, and one private Discourse instances. Usually you would copy a quote from the public one into the private one, but then, you would lose context: instead of being able to expand the quote, or to click-and-go to the original, you’d have to mention the source URL as well. Now, if your reader is authenticated, and the source URL is part of the quote, you can seamlessly go from one instance to the next.
Perfect for Discourse-connected sites, and for sites using ActivityPub Plugin.
2 posts were merged into an existing topic: Cross-Discourse Quoting
