Recuperar os dados "brutos" reais que criaram uma postagem?
If you’re using chrome desktop then you can use Ctrl+Shift+V to paste as plain text instead of notepad.
Also in the admin site settings page, you can disable this fancy pasting behavior by unchecking the “enable rich text paste” option.
2 curtidas
Thanks, but my goal is to keep the original formatting from microsoft word (in the raw data), not strip it down to plain text.
Currently, Discourse removes a variety of the formatting–such as font size and font type, while leaving others (bold and italics seem to stay there). As a comparison, Gmail composer seems to leave all formatting.
To try to keep more formatting, I suppose an alternative would be to upload a word document (not paste in text to the composer–but upload the actual doc). The problem there, I think, is that discourse does not show the contents of the upload inline (it just displays an upload link).
Then paste the raw HTML.
There are different goals involved. Gmail’s goal is to preserve all the formatting, whereas a forum’s goal is to keep a meaningful subset of it while preventing abuse (huge text, blinking text, OVERLY LARGE FONTS, annoying colours, etc.)
As a simple example, here is some simple text’s HTML as generated by Office, present in the clipboard as text/html:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
	<meta http-equiv="content-type" content="text/html; charset=utf-8"/>
	<title></title>
	<meta name="generator" content="LibreOffice 7.1.2.2 (Linux)"/>
	<style type="text/css">
		@page { size: 21.59cm 27.94cm; margin: 2cm }
		p { margin-bottom: 0.25cm; line-height: 115%; background: transparent }
	</style>
</head>
<body lang="en-CA" link="#000080" vlink="#800000" dir="ltr"><p style="margin-bottom: 0cm; line-height: 100%">
<b>Hello there</b><span style="font-weight: normal"> sunshine </span><i><span style="font-weight: normal">eh</span></i></p>
</body>
</html>
It looks like:
@page { size: 21.59cm 27.94cm; margin: 2cm } p { margin-bottom: 0.25cm; line-height: 115%; background: transparent }
Hello there sunshine eh
But when interpreted by to-markdown.js you get:
**Hello there** sunshine *eh*
You cannot, unless you put it there yourself as I did in this post. If you really need it there, hide it in a comment. If you want to later convert it yourself to markdown, use something like pandoc.
2 curtidas
I support transferring to markdown on the post that is displayed to others for some consistency. It’s the raw entry I’m curious about.
How do you get the raw html of a word doc that you could paste in?
Save it as HTML from Word, or copy it to the clipboard and pull the text/html explicitly from the clipboard.
4 curtidas
If all you care about is being able to reference the raw input at a later point, this component might work for you.
It adds a button to the post menu that shows the raw content on a per-post basis.
5 curtidas
@jomaxro, qual é a sintaxe para a marcação bruta de um comentário?
O que você está perguntando? Você está perguntando o que é markdown? Como https://commonmark.org/ Você está perguntando como obter o markdown bruto de uma postagem? Como /raw/123
Para uma única postagem, você pode adicionar o ID à URL. Por exemplo, https://meta.discourse.org/raw/189183/27 é a sua resposta.
2 curtidas
@pfaffman, a segunda opção. Obrigado, @Moin. Isso é óbvio, em retrospectiva.
@jomaxro, /raw/ não funciona em nenhuma das postagens de discuss.kde.org/c/community/blogs/24, pois, em view-source:discuss.kde.org/raw/43656, observo:
<pre>Konqi | 2026-01-23 22:43:37 UTC | #1
&lt;p&gt;Leaking memory is impolite. It’s messy, it can suggest logic bugs, and thanks to AI grifters RAM is expensive.&lt;/p&gt;
&lt;hr&gt;
&lt;small&gt;This is a companion discussion topic for the original entry at &lt;a href="https://nicolasfella.de/posts/detecting-leaks-in-kde-ci/?utm_source=atom_feed"&gt;https://nicolasfella.de/posts/detecting-leaks-in-kde-ci/?utm_source=atom_feed&lt;/a&gt;&lt;/small&gt;
</pre>
…enquanto, quando o details é expandido interativamente em discuss.kde.org/t/43656, eu posso expandi-lo para:
Isso pode ser viável de ser atendido no lado do Discourse upstream? Observei algo semelhante em outras instâncias do Discourse, ligeiramente personalizadas, por isso pergunto.
Qual problema você está tentando resolver?
Esses tópicos são especiais porque são links para publicações grandes.
Este é o texto bruto do op.
1 curtida
O texto bruto do OP nesse tópico é:
○ → curl https://discuss.kde.org/posts/132565/raw
<p>Leaking memory is impolite. It’s messy, it can suggest logic bugs, and thanks to AI grifters RAM is expensive.
</p>
<hr>
<small>This is a companion discussion topic for the original entry at <a href="https://nicolasfella.de/posts/detecting-leaks-in-kde-ci/?utm_source=atom_feed">https://nicolasfella.de/posts/detecting-leaks-in-kde-ci/?utm_source=atom_feed</a></small>
Isto é exatamente o que é renderizado na versão cozida.
Não é um bloco details sendo expandido. Um clique em Show Full Post carrega algo mais, que é a expansão completa do embed, que não vem do raw do post, mas de metadados adicionais do post.
Você pode ver a requisição de rede no seu navegador quando clica nela, aqui está a equivalente:
○ → curl -s -H 'accept: application/json' 'https://discuss.kde.org/posts/132565/expand-embed' | jq -r .cooked
<div><div>
            <p>Leaking memory is impolite. It’s messy, it can suggest logic bugs, and thanks to AI grifters RAM is expensive.</p>
<p>LSAN is now enabled for some Frameworks CI builds, but ideally it would be enabled for all KDE projects. And of course any leaks found along the way should be fixed.</p>
<p>Happy leak-fixing!</p>
        </div></div>
<hr>
<small>This is a companion discussion topic for the original entry at <a href='https://nicolasfella.de/posts/detecting-leaks-in-kde-ci/?utm_source=atom_feed'>https://nicolasfella.de/posts/detecting-leaks-in-kde-ci/?utm_source=atom_feed</a></small>
Você queria ver o conteúdo do embed? Se sim, use o acima. Se não, o que você está esperando ver?
2 curtidas
@supermathie, de fato. Muito obrigado! Evidentemente, muito mais da API do Discourse existe do que eu sei.
1 curtida
