How discourse stays online (Message Bus, Faye, Long Polling)
Yeah, the whole backend is powered by message_bus. The android/ios client long-polls. Not sure if this is the best use of message_bus, but It works w/o the added complexity of web sockets. The major win is that it fits in our existing rails stack. The only disadvantage i’ve come across so far is that I can’t find an elegant way to support the typing indicator.
http://www.eggie5.com/58-real-time-messenging-w-ruby-ios-android
@sam I see this works with Thin. What about Unicorn, I’ve read that Thin is excellent (best supported) with Long-Polling, is this why you only support Thin when using Long-Polling with your message_bus gem?
Please correct me if I’m wrong but looking at the code Long-Polling seems to be enabled if Thin is running?
It works fine with unicorn, in fact we host all our sites on unicorn.
unicorn, passenger and puma all support rack hijack. This means message_bus can pull sockets out of the normal lifecycle and release the connections back to unicorn while keeping the socket open.
That’s great to know. Thank you. Will read up on rack hijack.
@sam From what I got by reading the README and this thread, message_bus seems to be a pure notification system (sth like a Pusher alternative)
Am I correct by saying, it’s not designed for implementing event sourcing in a distributed systems?
All examples here are rather related to short-term messaging catch-up, but it’s not possible to restore old app state from the events stream, due to the truncation mechanism. Is there anything I missed?
Technically you could kick retention up and use PG as a backend. That said holding a transaction log forever certainly has costs. Rebuilding a DB from 10 years of transactions, though feasible is probably not something you would be doing.
