Pasting tables into the composer behaves oddly at times
https://github.com/discourse/discourse/pull/5389
4 лайка
OK it is merged, let’s try pasting from Excel, latest version, Windows 10:
test 1
data 0.5
sample 3
Nice worked perfectly :+1: no extra image nonsense. Next step: make it a cool Markdown table! :wink:
6 лайков
I actually used the paste-as-image all the time when explaining something or showing a complicated calculation. It does make sense.
e.g.:
But if you really want that you can go the intermediate route of GIMP etc. to get a bitmap.
Do you think even pasting it as markdown table can’t fulfill your needs?
3 лайка
PR created for Paste as Markdown Table and merged.
Edit: testing with excel table in Windows 10
test 1
data 0.5
sample 3
17 лайков
This is awesome, so magical :sparkler:
Thing Another Total
1 1 2
1 2 3
5
Can anyone test if pasting in from Numbers on Mac and Open Office / Libre Office works as well?
9 лайков
AAAA ZZZZ
A 1
B 2
C 3
AVG 2
LibreOffice on Linux is :ok_hand:
This is crazy useful in some types of forums. AWESOME!
5 лайков
Apple Numbers:
Table title
Row 1 Data 1
Row 2 Data 2
Row 3 Data 3
Google Docs:
Table title
Row 1 Data 1
Row 2 Data 2
Row 3 Data 3
6 лайков
@vinothkannans looks like both of the above may need some refinements (Numbers and Google docs), do you have a Mac to test?
4 лайка
Header 1 Header 2
Bold ⓭
Italics Yellow BG
Underlined RED
OK, looks like formatting is not included. A pity… But what a GREAT and WONDERFUL feature this is!!!
3 лайка
Just Table in Microsoft Word:
Header 1 Header 2
Row 1 Row 1.1
Row 2 Row 2.2
Yay!
Whole doc from Word with heading and table:
My Heading
The following is an awesome table outlining what I just described:
Header 1 Header 2
Row 1 Row 1.1
Row 2 Row 2.2
Another paragraph of text after the table.
Nope.
1 лайк
I don’t have Mac to test. I guess if I fix Google Docs it will be fixed there too.
Edit: Now it is working for Google Spreadsheet tables too. Can anyone re-test it on Apple Numbers?
test 1
data 0.5
sample 3
8 лайков
A table inside Google Docs will not work though, as it doesn’t copy as tab-delimited rows, but one cell on its own row after another.
Yes. My commit is yet supporting pasting in Google Docs or Tables inside Document files. As I said, it is only for Excel, Spreadsheet and Numbers.
For Docs please follow other topic HTML/RTF pasting - #17
7 лайков
RAID Array Space Calculator Type 1 Type 2
Number of Arrays of this type: 9 3
Number of Disks in this type Array: 10 4
Number of Spares in this type Array: 0 0
Disk Capacity: (GB) 10000 2000
RAID Level: raidz3 10-2x
Usable Capacity / Array: 70000 4000
Usable Capacity (Array Total): 630000 12000
My canonical example looks pretty damn good, and took 5 seconds to refine into exactly how I wanted it to look (merging top two lines, adding italics). Well done @vinothkannans :clap:
11 лайков
I tried numbers before merging it was working
number sample:
Money In
Paycheck €4 000
Additional income €0
Total income €4 000
8 лайков
Вставка из буфера обмена, когда присутствуют и изображение, и текст, снова вызывает проблемы. Я протестирую это здесь, используя таблицу, скопированную из LibreOffice (мы получали аналогичные отчеты для Excel):
synthfive@synth.com eurorack
При вставке таблицы в редактор создаётся тег изображения в формате Markdown:
![image|205x17](upload://6O1dCT74X45mQmlBp54nm0GnrZK.png)
2 лайка
Вот мой тестовый случай в Microsoft Word
При вставке получается
И какой-то текст
Давайте попробую изменить порядок (сначала текст) и посмотрим… тот же результат. Я нажимаю ctrl+a, чтобы выделить весь документ, который состоит из изображения и строки текста.
