Set up HTTPS support with Let's Encrypt
:bookmark: This is a guide for enabling HTTPS on an existing Discourse installation using Let’s Encrypt. It assumes prior installation without HTTPS enabled.
:person_raising_hand: Required user level: System Administrator
:exclamation: This guide is only for existing installs where HTTPS is not enabled. Following the official setup guide automatically enables HTTPS by default.
So you’d like to add https to your Discourse absolutely free, courtesy of our friends at Let’s Encrypt?
:bell: Is everything else on your site ready for HTTPS?
Before you start, please bear in mind that for HTTPS to work properly, every single resource on the page must be HTTPS compatible. Consider your CDN, your social logins, your logo files, any third party JavaScript, images, fonts, or css — these all must be available over HTTPS!
Note: ./discourse-setup will enable Let’s Encrypt. And as of March 2017, you can run it again, and press return a few times and enter your email address ; the script will include the required templates and insert your email address as required. Unless you are an expert sysadmin and know a reason not to do that, you should run discourse-setup rather than read any further. (If you installed Discourse a long time ago, you might still have to edit app.yml by hand.)
Note: If your Discourse is accessed via some reverse proxy (e.g., Cloudflare) this configuration will not work.
Configure HTTPS with Let’s Encrypt
1. Edit app.yml
Access your Discourse’s configuration file:
cd /var/discourse
nano containers/app.yml
  • Add the following templates:
    templates:
      - "templates/web.ssl.template.yml"
      - "templates/web.letsencrypt.ssl.template.yml"
:warning: Is Discourse the only website on your server?
If you are already using web.socketed.template.yml, because you host other websites via port 80 on the same server, stop. You should be using a Let’s Encrypt client on the host system; the validation will fail as the client used is unable to bind to the necessary sockets.
2. Expose HTTPS ports
Ensure the following ports are exposed for HTTPS traffic:
expose:
  - "80:80"
  - "443:443"
3. Add email for Let’s Encrypt
Insert the email address for Let’s Encrypt notifications:
env:
  LETSENCRYPT_ACCOUNT_EMAIL: 'your-email@example.com'
4. Rebuild the application
Apply the changes by rebuilding the container:
./launcher rebuild app
5. Validate HTTPS
Access your site via https://yourdomain.com. If successful, you’ll see your site secured with HTTPS.
Review your resources:
  • Ensure assets (e.g., images, scripts) load over HTTPS.
  • Reconfigure social logins and CDN for HTTPS as required.
  • Address any warnings in the browser console about insecure assets.
Discourse automatically enables force_https after a rebuild with a valid HTTPS certificate.
How does it work?
The template uses GitHub - acmesh-official/acme.sh: A pure Unix shell script ACME client for SSL / TLS certificate automation · GitHub which is
Simplest shell script for LetsEncrypt free Certificate client
Simple and Powerful, you only need 3 minutes to learn.
Pure written in bash, no dependencies to python , acme-tiny or LetsEncrypt official client. Just one script, to issue, renew your certificates automatically.
Probably it’s the smallest&easiest&smartest shell script to automatically issue&renew the free certificates from LetsEncrypt.
web.letsencrypt.ssl.template.yml adds a boot script to your container that
  1. Starts a lightweight nginx to serve ACME challenges on port 80 before the main nginx is up.
  2. Issues both an RSA (4096-bit) and an ECDSA (ec-256) Let’s Encrypt certificate using webroot mode with /var/www/discourse/public as the directory.
  3. Installs the certificates into the /shared/ssl/ directory that nginx expects. At the same time, it sets up a cron job for automatic certificate renewal. This will automatically renew your certs. Nothing happens if certs have not expired. If a certificate does expire, you’ll get an email about it from Let’s Encrypt at the email address you provided during setup.
  4. Sets force_https to true if valid certificates are obtained.
Troubleshooting
Checking logs
If HTTPS doesn’t work, check logs for SSL or Let’s Encrypt errors with:
./launcher logs app
Verifying certification files
Ensure certificate and key files are in place with:
ls -l /var/discourse/shared/standalone/ssl
You should see files like:
  • yourdomain.com.cer (RSA)
  • yourdomain.com.key (RSA)
  • yourdomain.com_ecc.cer (ECDSA)
  • yourdomain.com_ecc.key (ECDSA)
Renewing certificates manually
If auto-renewal fails, you can manually reissue your certificates:
./launcher enter app
sv stop nginx
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
LE_WORKING_DIR=/shared/letsencrypt DEBUG=1 /shared/letsencrypt/acme.sh --issue -d example.com -k 4096 -w /var/www/discourse/public
LE_WORKING_DIR=/shared/letsencrypt /shared/letsencrypt/acme.sh --installcert -d example.com --fullchainpath /shared/ssl/example.com.cer --keypath /shared/ssl/example.com.key --reloadcmd "sv reload nginx"
LE_WORKING_DIR=/shared/letsencrypt DEBUG=1 /shared/letsencrypt/acme.sh --issue -d example.com --keylength ec-256 -w /var/www/discourse/public
LE_WORKING_DIR=/shared/letsencrypt /shared/letsencrypt/acme.sh --installcert --ecc -d example.com --fullchainpath /shared/ssl/example.com_ecc.cer --keypath /shared/ssl/example.com_ecc.key --reloadcmd "sv reload nginx"
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf -s stop
Rebuilding with clean certs
Remove old certificate files and rebuild to start afresh:
rm -rf /var/discourse/shared/standalone/ssl
rm -rf /var/discourse/shared/standalone/letsencrypt
Limitations
Let’s Encrypt certificates only validate the domain and encryption. They don’t confirm ownership or identity, which may be flagged in some browsers. For more details, refer to the Let’s Encrypt community.
143 лайка
Setting up Let's Encrypt for multisite
How should I enable letsencrypt while discourse is beside other websites
Cant setting SLL (Let's Encrypt) for Discourse
Add to homescreen banner on Android
How to Set Up SSL in Discourse
Setting up SSL with my domain name and Discourse instance
Issue installing on subdomain
Completely automated SSL certificate generation
Problem with my SSL certificate
German 1&1-hosting user experience?
Replacement for whitelist-iframe
Site throws a blank screen after trying to enable LetsEncrypt
Missing file(discourse.conf) when launching after lets encrypt update?
My discourse has either been hacked or catfished?
Discourse has stopped opening
Using a certificate when Discourse is installed behind a reverse proxy
Can discourse be installed in private mode
My Forum Is showing "Privacy Error" after upgrading SSL certificate
Why my forum not pop-up "Add to Home screen"(PWA) automatically?
HTTPS : issue while trying to set up SSL certification
SSL received a record that exceeded the maximum permissible length
Discourse site loads via IP but via domain only header
Why is the Apple Touch Icon loaded via HTTP instead of HTTPS?
Defaultish app won't rebuild
Unable to connect Discourse and WordPress
I have a very difficult problem installing ssl - please help
How to install Discourse in the AWS EC2 Instances(Ubuntu Server LTS)?
Cannot connect to IP address and no errors in log
Http logo urls after enabling LetsEncrypt
How to install SSL certificate in Discourse
White blank page on mobile app
Cloud installation not working
My forum goes offline after removing https
Trying to use Let's Encrypt + Cloudflare
New user invite links only give ERR_SSL_PROTOCOL_ERROR
[DigitalOcean] hostname having "www" in A records showing blank page
Error at LetsEncrypt validation
Set Up Let's Encrypt with Second Domain for Existing Discourse Install
Not able to access site after letsencrypt cert expiry and rebuild due to IPV6
Port 443 of computer does not appear to be accessible
Make auto-linked URLs use HTTPS
Unable to change domain name
LetsEncrypt certificate not renewing
How to deny request from unauthorized domain pointing to my IP address?
No login is possible after recovery a Discourse Backup on a new server
Letsencrypt issued on every build?
My Discourse is Down. Certificate Issue?
Setup Let’s Encrypt + non-www > www
No connection accepted on http / https after fresh installation on Ubuntu 22.04 LTS
SSL certificate expired and after that - Error 404 Not Found
SSL didn't renew automatically and I can't manually renew it
443 address already in use? Letencrypt
Set up Let’s Encrypt with multiple domains / redirects
Using Discourse with Cloudflare: Best Practices
./launcher rebuild app error bootstrap failed with exit code 125
Uncaught ReferenceError: Discourse is not defined due to Cloudflare Rocket Loader
Let's Encrypt SSL Certificate Not Renewing
Uploads paths have 80 port but protocol is https
Bootstrap error during Discourse install: ENOENT - /etc/runit/1.d/letsencrypt
Trouble with SSL after lots of rebuilds
Installation auto-hébergée derrière une IP non-routée publiquement
ServiceWorker script evaluation failed due to HTTP (not HTTPS)
Not starting up after rebuild
Question about the email configuration
Discourse-saml: There was an error authorizing your account
Problem in installing Let's Encrypt SSL for www and non-www
Email not sending out after installation. I need help please
Discourse not starting up: nginx: unable to open supervise/ok: file does not exist
Failed to bootstrap: Failure with receiving network data
Error when installing ssl Let's Encrypt
How to adjust dependencies for https?
Clicking links is stuck in click tracking, shows ERR_FAILED
Minimum needed to get LetsEncrypt working on a GCE instance
Can we install discourse in another container distro?
[PAID] setup ssl - Let's encrypt
Error after moving from HTTP to HTTPS
How to renew Let's Encrypt?
Too many redirects after enabling https
В чём разница между сертификатами в папке standalone/letsencrypt и папке standalone/ssl?
В папке letsencrypt я вижу две подпапки для сайта с сертификатами: одна с именем sitename (RSA), а другая — с именем sitename_ecc (ECC).
Затем я вижу ещё одну папку ssl, которая также, похоже, содержит сертификаты .key и .cer с теми же именами, что и сертификаты в папках letsencrypt sitename и sitename_ecc.
Однако временные метки всех файлов в папке ssl отличаются от временных меток в папках letsencrypt, и, что особенно важно, размеры файлов .cer в папке ssl отличаются от размеров файлов .cer в папках letsencrypt.
Таким образом, мои вопросы:
  • в чём разница между файлами в папках ssl и letsencrypt
  • какой из них используется Discourse
  • если папки в папке ssl повреждены или удалены, можно ли заменить их файлами из папки letsencrypt? (это важно, потому что я столкнулся с ситуацией, когда при восстановлении сайта letsencrypt не смог получить заменяющие сертификаты из-за чрезмерного количества операций восстановления, но у меня была рабочая копия работающих сертификатов из папки letsencrypt из резервной копии образа).
1 лайк
@tgxworld
Можно ли изменить строку LE_WORKING_DIR=/shared/letsencrypt DEBUG=1 /shared/letsencrypt/acme.sh --issue -d example.com -k 4096 -w /var/www/discourse/public на LE_WORKING_DIR=/shared/letsencrypt DEBUG=1 /shared/letsencrypt/acme.sh --issue -d example.com -d www.example.com -k 4096 -w /var/www/discourse/public, чтобы получить SSL-сертификат, поддерживающий оба домена?
