SSO: ログアウトできません
You’re correct, that has solved the issue for me. I think I had that working on a previous install and then forgot to update the API key when I did a fresh install, not realising because everything else seemed to be working. Thanks a lot for your help.
「いいね!」 1
Just to chip in some info from my setup:
I’m using https://www.example.com/wp-login.php?action=logout
「いいね!」 1
It worked!
I logged out of Discourse and was redirected back to the WP/MP logon—where it stayed. I entered forum.thegearheadproject.com in the address bar of the very same tab—and nothing happened.
I’m going to ask my partner to give it a try and confirm as well. Will advise.
Thank you, Simon.
「いいね!」 3
This is confirmed solved. Thanks, @simon. :1st_place_medal:
「いいね!」 1
