Has there been any easier way to do this yet? Have any plugins or components been created?
I made a Theme Component for thisâŚ
Nicely done!
This should be another request, but we need an user setting for that. Some of my users would like to get on right side and I want keep it on left. Because Iâm the master of everything my opinion wins, butâŚ
Sure, I could duplicate themes but having a lot of similar themes where the only difference is location of the sidebar, but that is just dum.
But⌠AFAIK practically all of my registrate users and for sure all of active ones are using mobiles, and there isnât bigger difference between left and right. So I donât see that question so important either.
I like the idea of using the theme toggle to provide a variety of layouts. I think itâs a terrific idea.
Well you could add logic.
- If not you move sidebar.
Any luck with the hamburger as the second icon from the right and not the first to the right? ![]()
Can be changed with CSS or above plugin
Is this moving the left side column to the right? Or does it move the hamburger menu to the right?
The Left side column (menu).
I want to do the following:
I was able to do this using CSS. DM me if you need it. I only moved the hamburger menu to its more natural locationâaway from logo/hotspot. But didnât move the column. As such, both mobile and desktop the hamburger now share the same location.
