As far as I can tell debian (stable) provides an execution environment that’ sufficient for discourse without docker. And some (most?) cheap VPS boxes don’t allow you to run docker, but will give you 20- GiB of disk space and 2GiB RAM. I’ve one of those and my (low-traffic) discourse installation runs happily there.
Then you’re missing out on a lot of performance improvements, especially with regard to TLS handshakes, that nginx has received since that version.
Sure, if your forum is small enough, you can certainly do without, and if nothing else, Debian ist excellent at backporting security fixes to outdated versions.
I think @codinghorror objects to the hugely conservative release cycle practiced by debian, its just way too slow for our liking.
not sure if you can get aufs going on debian, device mapper is a disaster on docker and not sure what release of btrfs you would be on, but I doubt it is recent. no chance of getting overlayfs imo. Not sure how you are getting a decent docker install.
Nice, thanks for the link to the old manual, and the script!
I guess I could also use Docker, but as long as there is no ‘How to integrate discourse_docker into an existing system with a normal webserver’ tutorial, this method is far simpler for me.
Just wanted to chime in to clear things up: I run packager.io, so I can confirm that Discourse is still maintained. What Packager does is simple: it takes an app, applies one of the Heroku buildpacks on it, and package that into a deb/rpm for any number of the Linux distributions we support.
So you basically end up with what you would get on Heroku (i.e. processes are launched based on your Procfile, using the exact ruby version and gems specified in your Gemfile), but on your server(s). The package also ships with init scripts, logrotate, crons, etc.
For other dependencies, we rely on the system dependencies provided by the package manager of the distribution (i.e. we don’t package the world).
That being said, I can understand why Discourse went the docker route, especially if the alternative was a manual/roll-your-own install.
I just setup my first Discourse installation on DO using Ubuntu and Docker and I have to say it was painless. I have read on this forum that some people have Discourse configured with Nginx. I don’t use Nginx and while setting up Discourse I don’t remember installing Apache. So my question is… how are my web requests being handled? Also, does using Nginx make Discourse run more efficiently?
