I am honestly not going to read all the replies here, but are you using Cloudflare? If you are, disable it while installing the first time, after its fine, but both LetsEncrypt and Discourse misbehave when using Cloudflare because it can’t see your ip. It instead sees Cloudflares IP. Which can then sometimes mess with (in my experience) with successfully installing/setting up.
There is a dedicated template to add into app.yml for Cloudflare.
I disabled the orange cloud where the IP can be viewed, and it’s still like this
2026-08-05T04:21:34.539Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:35.566Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:36.589Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:37.614Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:38.654Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:39.690Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:40.722Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:41.743Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:42.767Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:43.789Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:44.813Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:45.832Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:46.860Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:47.885Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:48.914Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:49.939Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:50.967Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:51.992Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:53.015Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:54.039Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:55.060Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:56.080Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:57.101Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:58.123Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:21:59.150Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:00.172Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:01.194Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:02.237Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:03.268Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:04.296Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:05.323Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:06.350Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:07.388Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:08.410Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:09.433Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:10.457Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:11.481Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:12.511Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:13.535Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:14.561Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:15.586Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:16.632Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:17.659Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:18.691Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:19.726Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:20.753Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:21.774Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:22.803Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:23.828Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:24.854Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:25.881Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:26.904Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:27.923Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:28.946Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:29.969Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:30.994Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:32.016Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:33.037Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:34.059Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:35.084Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:36.106Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:37.130Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:38.151Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:39.171Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:40.198Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:41.228Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:42.252Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:43.278Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:44.296Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:45.320Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:46.346Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:47.367Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:48.401Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:49.425Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:50.454Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:51.473Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:52.498Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:53.522Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:54.543Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:55.563Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:56.587Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:57.610Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:58.638Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:22:59.657Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:00.683Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:01.721Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:02.757Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:03.791Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:04.826Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:05.854Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:06.879Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:07.901Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:08.927Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:09.952Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:10.980Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:12.008Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:13.036Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:14.057Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
2026-08-05T04:23:15.089Z nginx: [emerg] cannot load certificate "/shared/ssl/debatehosting.co.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0480006C:PEM routines::no start line:Expecting: TRUSTED CERTIFICATE)
Hey guys, a colleague was running a test on Dokploy using an older version. It turned out I needed the latest update, so I applied it, and since then the website has gone down with this same SSL issue. Any idea what’s going on?
Update: I think the domain debatehosting.co is blocked due to SSL. I tried another one and everything worked normally. What should I do?
Wait for one week when you are no longer rate limited then rebuild again, or simple try to use a subdomain like www
Thank you all very much, my requests were blocked, so I’m going to close this.
please check the correct solution. someone else solved this for you by telling you what to investigate, otherwise your site would still be broken.
it also helps others who might have a similar install issue and read this topic later.
As Jay said, debatehosting.co doesn’t exist.
○ → host debatehosting.co
Host debatehosting.co not found: 3(NXDOMAIN)
○ → whois debatehosting.co
The queried object does not exist: DOMAIN NOT FOUND
>>> Last update of WHOIS database: 2026-08-05T15:50:43.0Z <<<
You need to register the domain before using it.
Oh yeah! Apologies @pfaffman!
Did the OP assume just adding a hostname to app.yml automatically paid a registrar and completed the registration?
@Picho_Pelis I suggest you register this domain asap if you want to claim it!
No wonder letsencrypt couldn’t handle the request!
@pfaffman’s post should be marked as Solution
OK the mystery deepens.
I decided to delete it because, with that issue, I got tired and canceled everything. I’m testing on another domain and everything is fine.
Cancel the domain due to the issue
It would have been good if you could have shared that detail explicitly so people would not have drawn incorrect conclusions and wasted time following up.
Linking this here:
@Picho_Pelis Did you purchase the domain when you made the topic I linked?
Yes, bro, what happened was that SSL blocked the domain.
I understand that what happened was your repeated attempts to generate credentials hit the rate limits on Let’s Encrypt. That is not the same as ‘SSL blocked my domain’.
You can always use another SSL certificates provider (paid) or wait for the release of this limit. It’s all about keeping the (free) service available to everyone.
Other free ACME CAs
