Backup Restore Failed, log.txt inside
I have spent a few days trying many things.
To preface this, some upgrade broke my discourse, I believe it was when Discourses upgraded to 3+.
That was back in March 2023, I worked on it intermittently the past 12 months to no avail and this week hit it hard.
No amount of restore worked, not on the command line, not over discourse UI.
I thought rather than fixing the old I would start a new install, had plenty of auto backups on my S3, 3.2.0/16.2 postgres/7.2 redis — very clean install works great … .so I went for the restore and then it failed.
Being DB is not my expertise I am on a steep learning curve even trying to surmise what could solve my problem.
I thought maybe schema diff could, and while I see there are 14 tables with differences in a compare to a base install I still do not understand how to synchronize DB nor could I find a script to do so.
log.txt (97.7 KB)
It looks like you’re using the bitnami install rather than the official install, which is unsupported here. If you can move to using the standard install instead that would be great (and open you up to much more community support on here as well).
Though this stands out from your log:
ActiveRecord::StatementInvalid: PG::DuplicateTable: ERROR:  relation "chat_channels" already exists
You may be able to have a search and see how others have handled similar issues. I believe you may need to drop the table, but it’s not something I’m familiar with.
