Restore problem: relation "theme_fields" does not exist
@tgxworld, I think this is in your wheelhouse.
Trying to restore a backup from Discourse 2.1.0.beta5 - https://github.com/discourse/discourse version 8da2d8df3d5f7196f1c267b8a664597a725241ac or "Discourse 2.1.0.beta5 - https://github.com/discourse/discourse version bed34b52b51ab903bcb7854cc1efb2bf4107ddfb" to f4ae53d52b70a6577a60388f3550f168a4706b5f
I get
# discourse restore mineral-rights-forum-2018-08-23-033241-v20180812150839.tar.gz
bundler: failed to load command: script/discourse (script/discourse)
ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR:  relation "theme_fields" does not exist
LINE 8:                WHERE a.attrelid = '"theme_fields"'::regclass
:               SELECT a.attname, format_type(a.atttypid, a.atttypmod),
                     pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod,
                     c.collname, col_description(a.attrelid, a.attnum) AS comment
                FROM pg_attribute a
                LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum
                LEFT JOIN pg_type t ON a.atttypid = t.oid
                LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation
                 AND a.attnum > 0 AND NOT a.attisdropped
               ORDER BY a.attnum
I tried restoring a backup from Beta 4 and it fails the same way, so I think it’s a problem with the current Discourse restoring, not the way that backups are created.
EDIT: It looks like the first time that I restore it works, but if I restore again, it fails. I’ve not yet tested this on more than one database.
Going to have to ship this into the Support category, there could be some sort of bug here, but we need a proper repro that works consistently.
Can you consistently make this fail?
Me too got this issue now.
What I did:
I did a backup with discourse 2.5.0.beta4.
as root
git clone https://github.com/discourse/discourse_docker.git /var/discourse
cd /var/discourse
cp /var/production-backup/var/discourse/containers/app.yml /var/discourse/containers/
mkdir -p /var/discourse/shared/standalone/backups/default/
cp /var/production-backup/var/discourse/shared/standalone/backups/default/whonix-forum-2020-05-21-132423-v20200506044956.tar.gz /var/discourse/shared/standalone/backups/default/
./launcher enter app
discourse enable_restore
discourse restore whonix-forum-2020-05-21-132423-v20200506044956.tar.gz
result:
root@host-app:/var/www/discourse# discourse restore whonix-forum-2020-05-21-132423-v20200506044956.tar.gz
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.1/lib/patches/db/pg.rb:110:in `exec'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.1/lib/patches/db/pg.rb:110:in `async_exec'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:65:in `block (2 levels) in query'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:64:in `block in query'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/abstract_adapter.rb:722:in `block (2 levels) in log'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/abstract_adapter.rb:721:in `block in log'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/abstract_adapter.rb:712:in `log'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/postgresql/database_statements.rb:63:in `query'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/postgresql_adapter.rb:820:in `column_definitions'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/abstract/schema_statements.rb:114:in `columns'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/schema_cache.rb:76:in `columns'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/connection_adapters/schema_cache.rb:82:in `columns_hash'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/model_schema.rb:488:in `load_schema!'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/attributes.rb:247:in `load_schema!'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/attribute_decorators.rb:50:in `load_schema!'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/model_schema.rb:478:in `block in load_schema'
  /usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/model_schema.rb:475:in `load_schema'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/model_schema.rb:352:in `columns_hash'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/dynamic_matchers.rb:60:in `block in valid?'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/dynamic_matchers.rb:60:in `all?'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/dynamic_matchers.rb:60:in `valid?'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/dynamic_matchers.rb:11:in `respond_to_missing?'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/scoping/named.rb:209:in `respond_to?'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/scoping/named.rb:209:in `valid_scope_name?'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3/lib/active_record/scoping/named.rb:187:in `scope'
  /var/www/discourse/app/models/theme_field.rb:8:in `<class:ThemeField>'
  /var/www/discourse/app/models/theme_field.rb:3:in `<top (required)>'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/kernel.rb:16:in `require'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:381:in `const_get'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:381:in `block (2 levels) in eager_load'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:723:in `block in ls'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:720:in `foreach'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:720:in `ls'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:376:in `block in eager_load'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:368:in `synchronize'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:368:in `eager_load'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:483:in `each'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:483:in `eager_load_all'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/application/finisher.rb:122:in `block in <module:Finisher>'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/initializable.rb:32:in `instance_exec'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/initializable.rb:32:in `run'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/initializable.rb:61:in `block in run_initializers'
  /usr/local/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
  /usr/local/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
  /usr/local/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
  /usr/local/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
  /usr/local/lib/ruby/2.6.0/tsort.rb:347:in `each'
  /usr/local/lib/ruby/2.6.0/tsort.rb:347:in `call'
  /usr/local/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
  /usr/local/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
  /usr/local/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/initializable.rb:60:in `run_initializers'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/application.rb:363:in `initialize!'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/railtie.rb:190:in `public_send'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3/lib/rails/railtie.rb:190:in `method_missing'
  /var/www/discourse/config/environment.rb:7:in `<top (required)>'
  script/discourse:264:in `require'
  script/discourse:264:in `load_rails'
  script/discourse:119:in `restore'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
  /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/thor-1.0.1/lib/thor/base.rb:485:in `start'
  script/discourse:284:in `<top (required)>'
Happened twice. Dunno how to proceed from here.
Can you restore it via the UI ?
No.
> [2020-05-22 12:11:36] 'Patrick' has started the restore!
> [2020-05-22 12:11:36] Marking restore as running...
> [2020-05-22 12:11:36] Making sure /var/www/discourse/tmp/restores/default/2020-05-22-121136 exists...
> [2020-05-22 12:11:36] Copying archive to tmp directory...
> [2020-05-22 12:11:40] Unzipping archive, this may take a while...
> [2020-05-22 12:11:47] Extracting dump file...
> [2020-05-22 12:11:58] Validating metadata...
> [2020-05-22 12:11:58]   Current version: 20200522004855
> [2020-05-22 12:11:58]   Restored version: 20200506044956
> [2020-05-22 12:11:58] Enabling readonly mode...
> [2020-05-22 12:11:58] Pausing sidekiq...
> [2020-05-22 12:11:58] Waiting up to 60 seconds for Sidekiq to finish running jobs...
> [2020-05-22 12:12:06] Creating missing functions in the discourse_functions schema...
Then even hours later, nothing happening.
Reload page.
Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site’s feedback category.
root@whonix:/var/discourse# ./launcher logs app
> run-parts: executing /etc/runit/1.d/00-ensure-links
> run-parts: executing /etc/runit/1.d/00-fix-var-logs
> run-parts: executing /etc/runit/1.d/anacron
> run-parts: executing /etc/runit/1.d/cleanup-pids
> Cleaning stale PID files
> run-parts: executing /etc/runit/1.d/copy-env
> Started runsvdir, PID is 38
> ok: run: redis: (pid 52) 0s
> ok: run: postgres: (pid 51) 0s
> chgrp: invalid group: ‘syslog’
> rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
> rsyslogd: activation of module imklog failed [v8.1901.0 try https://www.rsyslog.com/e/2145 ]
> supervisor pid: 47 unicorn pid: 77
`root@whonix:/var/discourse# ./launcher enter app`
Possible.
root@whonix-app:/var/www/discourse#
tail shared/standalone/log/rails/production.log
Unexpected error in Message Bus : PG::UndefinedTable: ERROR:  relation "user_auth_tokens" does not exist
LINE 1: SELECT "user_auth_tokens".* FROM "user_auth_tokens" WHERE ((...
Job exception: PG::UndefinedTable: ERROR:  relation "application_requests" does not exist
LINE 1: SELECT "application_requests"."id" FROM "application_request...
Something is not right about your backup.
Can you extract it on local and load it into a PG database? The gzip contains 2 files … 1 backups of PG and 1 uploads directory.
Thank you for help!
I’ve created a new backup from the still fully functional old production server.
Purged both docker and discourse from newer stage server. Re-installed both docker and discourse according official instructions. Then went with command line restoration instructions.
The backup was created with docker-engine 17.05.0~ce-0~debian-stretch and to be restored with docker-ce-cli 5:19.03.9~3-0~debian-buster. This also results in a newer postgres version. (old: 10; new: 12)
Is it a legitimate approach to backup an outdated docker/postgres version and try to restore on an up to date docker/discourse installation?
Getting a different error this time.
ERROR:  could not create unique index "index_incoming_referers_on_path_and_incoming_domain_id"
DETAIL:  Key (path, incoming_domain_id)=(/wiki/Tor_Browser, 3) is duplicated.
EXCEPTION: psql failed: DETAIL:  Key (path, incoming_domain_id)=(/wiki/Tor_Browser, 3) is duplicated.
Full log:
root@whonix-app:/var/www/discourse# discourse restore whonix-forum-2020-05-25-065253-v20200506044956.tar.gz
Starting restore: whonix-forum-2020-05-25-065253-v20200506044956.tar.gz
[STARTED]
'system' has started the restore!
Making sure /var/www/discourse/tmp/restores/default/2020-05-25-132224 exists...
  Current version: 20200524181959
Pausing sidekiq...
Restoring dump file... (this may take a while)
[cut]
ALTER TABLE
[cut lots of duplicate ALTER TABLE lines]
ALTER TABLE
CREATE INDEX
[cut lots of duplicate CREATE INDEX lines]
CREATE INDEX
/var/www/discourse/lib/backup_restore/database_restorer.rb:95:in `restore_dump'
/var/www/discourse/lib/backup_restore/database_restorer.rb:26:in `restore'
/var/www/discourse/lib/backup_restore/restorer.rb:49:in `run'
script/discourse:143:in `restore'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Trying to rollback...
Rolling back...
Cleaning stuff up...
Dropping functions from the discourse_functions schema...
Removing tmp '/var/www/discourse/tmp/restores/default/2020-05-25-132224' directory...
Unpausing sidekiq...
Disabling readonly mode...
Marking restore as finished...
Notifying 'system' of the end of the restore...
Finished!
[FAILED]
Restore done.
I wonder how’s that possible since my old production discourse server is still fully functional. And it’s the second backup I try.
Postgres 10 or postgres 12?
EDIT:
root@whonix-app:/var/www/discourse# rails c
[1] pry(main)> IncomingReferer.where(path: "/wiki/Tor_Browser")
=> [#<IncomingReferer:0x0000561cba422f48
  path: "/wiki/Tor_Browser",
  incoming_domain_id: 3>]
[2] pry(main)>
EDIT2:
[6] pry(main)> IncomingReferer.where("path LIKE '%/wiki/Tor_Browser%'")
=> [#<IncomingReferer:0x0000561cc08882a8
  incoming_domain_id: 3>,
 #<IncomingReferer:0x0000561cc08b3f48
  path: "/wiki/Tor_Browser/Download_Confirmation_Screen",
 #<IncomingReferer:0x0000561cc08b3e08
  path: "/wiki/Tor_Browser/Internal_Updater",
 #<IncomingReferer:0x0000561cc08b3cf0
<page break> --- Press enter to continue ( q<enter> to break ) --- <page break>
  incoming_domain_id: 113>,
 #<IncomingReferer:0x0000561cc08b3bb0
  path: "/wiki/Tor_Browser/Advanced_Users",
  incoming_domain_id: 617>,
 #<IncomingReferer:0x0000561cc08b3a70
 #<IncomingReferer:0x0000561cc08b38e0
  incoming_domain_id: 1513>,
 #<IncomingReferer:0x0000561cc08b37f0
 #<IncomingReferer:0x0000561cc08b3700
  incoming_domain_id: 1552>,
 #<IncomingReferer:0x0000561cc08b34a8
 #<IncomingReferer:0x0000561cc08b3318
 #<IncomingReferer:0x0000561cc08b3188
  path: "/wiki/Tor_Browser_without_Tor",
 #<IncomingReferer:0x0000561cc08b2f08
 #<IncomingReferer:0x0000561cc08b2cb0
 #<IncomingReferer:0x0000561cc08b2bc0
 #<IncomingReferer:0x0000561cc08b2ad0
  incoming_domain_id: 4560>,
 #<IncomingReferer:0x0000561cc08b28f0
  incoming_domain_id: 4559>,
 #<IncomingReferer:0x0000561cc08b25f8
  incoming_domain_id: 4560>]
[7] pry(main)>
[8] pry(main)>
Yes, this is supported.
→ Corrupt indexes in PG12, how do I fix?
I am getting the same error as the OP regarding “theme_fields” even on a brand new Discourse installation.
E, [2020-06-04T16:32:44.492756 #2024] ERROR -- : PG::UndefinedTable: ERROR:  relation "theme_fields" does not exist
 (ActiveRecord::StatementInvalid)
/app/.global/gems/rack-mini-profiler-2.0.2/lib/patches/db/pg.rb:110:in `exec'
/app/.global/gems/rack-mini-profiler-2.0.2/lib/patches/db/pg.rb:110:in `async_exec'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:65:in `block (2 levels) in query'
/app/.global/gems/activesupport-6.0.1/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/app/.global/gems/activesupport-6.0.1/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/app/.global/gems/activesupport-6.0.1/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:64:in `block in query'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract_adapter.rb:718:in `block (2 levels) in log'
/opt/ruby/2.6/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract_adapter.rb:717:in `block in log'
/app/.global/gems/activesupport-6.0.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract_adapter.rb:708:in `log'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:63:in `query'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/postgresql_adapter.rb:817:in `column_definitions'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/abstract/schema_statements.rb:114:in `columns'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/schema_cache.rb:76:in `columns'
/app/.global/gems/activerecord-6.0.1/lib/active_record/connection_adapters/schema_cache.rb:82:in `columns_hash'
/app/.global/gems/activerecord-6.0.1/lib/active_record/model_schema.rb:490:in `load_schema!'
/app/.global/gems/activerecord-6.0.1/lib/active_record/attributes.rb:247:in `load_schema!'
/app/.global/gems/activerecord-6.0.1/lib/active_record/attribute_decorators.rb:51:in `load_schema!'
/app/.global/gems/activerecord-6.0.1/lib/active_record/model_schema.rb:480:in `block in load_schema'
/app/.global/gems/activerecord-6.0.1/lib/active_record/model_schema.rb:477:in `load_schema'
/app/.global/gems/activerecord-6.0.1/lib/active_record/model_schema.rb:352:in `columns_hash'
/app/.global/gems/activerecord-6.0.1/lib/active_record/dynamic_matchers.rb:60:in `block in valid?'
/app/.global/gems/activerecord-6.0.1/lib/active_record/dynamic_matchers.rb:60:in `all?'
/app/.global/gems/activerecord-6.0.1/lib/active_record/dynamic_matchers.rb:60:in `valid?'
/app/.global/gems/activerecord-6.0.1/lib/active_record/dynamic_matchers.rb:11:in `respond_to_missing?'
/app/.global/gems/activerecord-6.0.1/lib/active_record/scoping/named.rb:209:in `respond_to?'
/app/.global/gems/activerecord-6.0.1/lib/active_record/scoping/named.rb:209:in `valid_scope_name?'
/app/.global/gems/activerecord-6.0.1/lib/active_record/scoping/named.rb:186:in `scope'
/app/app/models/theme_field.rb:8:in `<class:ThemeField>'
/app/app/models/theme_field.rb:3:in `<top (required)>'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/kernel.rb:16:in `require'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:381:in `const_get'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:381:in `block (2 levels) in eager_load'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:723:in `block in ls'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:720:in `foreach'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:720:in `ls'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:376:in `block in eager_load'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:368:in `synchronize'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:368:in `eager_load'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:483:in `each'
/app/.global/gems/zeitwerk-2.3.0/lib/zeitwerk/loader.rb:483:in `eager_load_all'
/app/.global/gems/railties-6.0.1/lib/rails/application/finisher.rb:122:in `block in <module:Finisher>'
/app/.global/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `instance_exec'
/app/.global/gems/railties-6.0.1/lib/rails/initializable.rb:32:in `run'
/app/.global/gems/railties-6.0.1/lib/rails/initializable.rb:61:in `block in run_initializers'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:228:in `block in tsort_each'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:431:in `each_strongly_connected_component_from'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:349:in `block in each_strongly_connected_component'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:347:in `each'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:347:in `call'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:347:in `each_strongly_connected_component'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:226:in `tsort_each'
/opt/ruby/2.6/lib/ruby/2.6.0/tsort.rb:205:in `tsort_each'
/app/.global/gems/railties-6.0.1/lib/rails/initializable.rb:60:in `run_initializers'
/app/.global/gems/railties-6.0.1/lib/rails/application.rb:363:in `initialize!'
/app/.global/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `public_send'
/app/.global/gems/railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing'
/app/config/environment.rb:7:in `<top (required)>'
I get that repeated numerous times in my application log. I’m not clear what is triggering it. I’m on PostgreSQL 9.6, if that matters.
Are you running the latest version of Discourse? Is this an upgrade from an ancient version of Discourse?
This is a brand new fresh install of Discourse 2.4, no previous anything.
I also tried upgrading to Postgres 12. Error still appears in my logs.
