Configure an S3 compatible object storage provider for uploads
@Falco - It could be good to add a warning for Scaleway, that it only supports 1,000 parts for multipart upload, while AWS supports 10,000. This is not a problem for regular uploads, but it is an issue for backup uploads over a certain size as the S3 SDK will use 10,000 parts unless manually modified and fail.
https://www.scaleway.com/en/docs/storage/object/api-cli/multipart-uploads/
Great finding! Please add it to the OP wiki if you can.
Thank you, also I would to add that you can use any of these tools to copy from cloud to cloud, especially to/from S3 compatible object storage, for example, Rclone, Shargate, Gs Richcopy360 and GoodSync. all of these are compatible with similar clouds
We have just discovered a problem, Cloudflare R2 doesnā€™t allow public-read from the S3 endpoint URL, rather only the custom domain or a random r2.dev domain.
(Pre-signed downloads work, just no direct public access is supported.)
But discourse only uses the CDN URL for embedded images, and not direct downloads, which use the S3 endpoint URL.
Is there a way to make it use the CDN URL for all files, or force the use of a presigned url?
Related:
The workaround mentioned in that post works, add ?dl=1 fixes it, because its forces discourse to use a presigned S3 URL.
Fixed in 2023-03-16 now R2 working with Discourse like charm with free plan
I also see this with some frequency (every several months) even though my Discourse is running in AWS Lightsail and Iā€™m uploading to AWS S3. So Iā€™m not sure itā€™s wasabiā€™s fault.
Would it be possible to catch this error and alert the admin? I do check the disk space and remove old backups when I upgrade but sometimes thatā€™s too late and the forum goes down for no disk space.
I am fairly certain that the issue was that automatic OS reboots for security updates were happening while the backup was running. Make sure that you schedule your OS reboots and your backups at different times. It was after Iā€™d moved that site from wasabi that I came up with this explanation, but Iā€™m pretty sure thatā€™s what it was.
uptime says itā€™s been up for 300 days so I donā€™t think thatā€™s the problem. But along similar lines, I had Discourse backups scheduled at 2:00 am and Lightsail snapshots at 2:30 am, so maybe the upload sometimes isnā€™t complete and the snapshot messes with it. Iā€™ve separated the two operations by an hour- weā€™ll see if it makes a difference.
Regardless I think itā€™s reasonable to warn admins if the upload fails, for whatever reason.
I think that itā€™s time that you do kernel upgrades and reboot. :slight_smile:
Could you be running out of ram?
After implementing remote Backblaze backups, I see this error in my dashboard:
The server is configured to upload files to S3, but there is no S3 CDN configured. This can lead to expensive S3 costs and slower site performance. See ā€œUsing Object Storage for Uploadsā€ to learn more.
I didnā€™t configure uploading of files, I only configured backups via this config:
DISCOURSE_S3_REGION: "s3.us-west-00X"
DISCOURSE_S3_INSTALL_CORS_RULE: false
DISCOURSE_S3_ENDPOINT: https://s3.us-west-00X.backblazeb2.com
DISCOURSE_S3_ACCESS_KEY_ID: mykeyid
DISCOURSE_S3_SECRET_ACCESS_KEY: myaccesskey
DISCOURSE_S3_BUCKET: community-forum
DISCOURSE_S3_BACKUP_BUCKET: community-forum/backups
DISCOURSE_BACKUP_LOCATION: s3
Did I do something wrong?
Something seems misconfigured, I notice when I try uploading a file to a post, I received this error:
Unsupported value for canned acl 'public-readā€™
Any assistance would be appreciated.
Remove this if you donā€™t want uploads to go to s3.
You saved the day brother. :+1:t3: Thanks so much!
Did that seem to work?
It has happened once in the past month since I separated the two processes by an hour, so it didnā€™t ā€œfixā€ it, and it doesnā€™t happen often enough to say whether it helped.
On the bright side, I noticed there is a backup status section on the admin page that shows available disk space, which saves me from constantly opening a terminal and doing a df just to check for stuck backups. I customized the text to remind myself that I expect around 80 GB free.
Thatā€™s a good idea.
I saw the image before I read that you had customized the text and was wondering what logic was at play to determine that was ā€œgoodā€!
I just couldnā€™t get this to work with Scaleway using the Bitnami Discourse image.
The env variables were set but clearly werenā€™t being read/applied correctly (or at all?).
So Iā€™ve set the S3 variables in the admin panel and set the region directly in the rails console (still hoping that this just becomes a text field):
SiteSetting.s3_region="fr-par"
It gave me a validation error, but I just commented out the validation check before updating the setting, then put it in again.
The Bitnami image isnā€™t packaged by us and donā€™t follow our recommendations. Everything documented here is only tested against the official install.
This has been solved by enabling ā€œs3 use cdn url for all uploadsā€, an option recently added by discourse.
since we were using R2 before, we needed to use discourse remap to manually replace the broken links, and synced s3 files just in case, and then we rebaked all posts.
Iā€™m trying to set this up with idrive e2, which is s3 compatible. However Iā€™m getting a not very helpful error/stack trace at the end of ./launcher rebuild app:
I, [2023-10-14T15:08:08.026184 #1]  INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:upload_assets
rake aborted!
Aws::S3::Errors::InternalError: We encountered an internal error, please try again.
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/raise_response_errors.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/sse_cpk.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/dualstack.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/plugins/accelerate.rb:56:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/checksum_algorithm.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/jsonvalue_converter.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/idempotency_token.rb:19:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/param_converter.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/request_callback.rb:71:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/aws-sdk-core/plugins/response_paging.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/seahorse/client/plugins/response_target.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-core-3.130.2/lib/seahorse/client/request.rb:72:in `send_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/client.rb:12369:in `put_object'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/aws-sdk-s3-1.114.0/lib/aws-sdk-s3/object.rb:1472:in `put'
/var/www/discourse/lib/s3_helper.rb:78:in `upload'
/var/www/discourse/lib/tasks/s3.rake:41:in `block in upload'
/var/www/discourse/lib/tasks/s3.rake:41:in `open'
/var/www/discourse/lib/tasks/s3.rake:41:in `upload'
/var/www/discourse/lib/tasks/s3.rake:197:in `block (2 levels) in <main>'
/var/www/discourse/lib/tasks/s3.rake:197:in `each'
/var/www/discourse/lib/tasks/s3.rake:197:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
Tasks: TOP => s3:upload_assets
I, [2023-10-14T15:08:16.413098 #1]  INFO -- : Installing CORS rules...
skipping
Uploading: assets/admin-2ebebf57104b0beb47a1c82fe5a8c6decd07f60a706640345fed296a094d1536.js
This is the config Iā€™ve been using, but Iā€™ve also tried it with DISCOURSE_S3_CONFIGURE_TOMBSTONE_POLICY and DISCOURSE_S3_HTTP_CONTINUE_TIMEOUT
  DISCOURSE_USE_S3: true
  DISCOURSE_S3_REGION: Dallas
  DISCOURSE_S3_ENDPOINT: https://y0o9.tx21.idrivee2-4.com
  DISCOURSE_S3_ACCESS_KEY_ID: <snip>
  DISCOURSE_S3_SECRET_ACCESS_KEY: <snip>
  DISCOURSE_S3_BUCKET: discourse
Note Iā€™m not using it for backups (thatā€™s already setup in the UI with backblaze) nor DISCOURSE_CDN_URL because Iā€™m not sure idrive supports that - I planned on experimenting with that once I got some actual files in the bucket.
Looks like itā€™s not compatible enough with S3 for Discourse needs.
If you want to dig further the next step would be reproducing this in a development install and getting the exact API call that fails.
