Internal Server Error when accepting group join
Hello,
On a discourse instance we use groups where owners have to validate people.
Recently, we started seeing errors when owners try to accept people into groups. I’m not sure if it applies to particular groups, owners or users.
A pop up “Internal Server Error” is shown, and the frontend still believes the request was successful (the UI shows the user as “accepted”). However when reloading we can see that it’s not the case and the request is still pending.
This error leaves 2 log messages:
A fatal
Message (44 copies reported)
I18n::InvalidLocale ("" is not a valid locale)
lib/freedom_patches/translate_accelerator.rb:129:in `translate_no_override'
lib/freedom_patches/translate_accelerator.rb:226:in `translate'
app/controllers/groups_controller.rb:488:in `handle_membership_request'
app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
app/controllers/application_controller.rb:423:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:277:in `call'
Backtrace
i18n (1.14.5) lib/i18n.rb:380:in `enforce_available_locales!'
i18n (1.14.5) lib/i18n.rb:213:in `translate'
actionpack (7.0.8.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
i18n (1.14.5) lib/i18n.rb:351:in `with_locale'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.1) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.1) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.8.1) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.1) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.0.8.1) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.1) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.1) lib/action_dispatch/routing/route_set.rb:852:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.1) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.1) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.1) lib/rails/rack/logger.rb:27:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.1) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
railties (7.0.8.1) lib/rails/engine.rb:530:in `call'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Env
1/44
hostname	redacted
process_id	188
application_version	755f8de6d42fcb198dab1616e5b753c38a308643
HTTP_HOST	redacted
REQUEST_URI	/groups/51/handle_membership_request.json
REQUEST_METHOD	PUT
HTTP_USER_AGENT	Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36
HTTP_ACCEPT	*/*
HTTP_REFERER	redacted/g/com_stats/requests
HTTP_X_FORWARDED_FOR	redacted
HTTP_X_REAL_IP	redacted
username	redacted
time	7:25 pm
params
user_id	345
accept	true
and a warning
Failed to handle exception in exception app middleware : I18n::InvalidLocale : "" is not a valid locale
Backtrace
i18n-1.14.5/lib/i18n.rb:380:in `enforce_available_locales!'
i18n-1.14.5/lib/i18n.rb:213:in `translate'
/var/www/discourse/lib/freedom_patches/translate_accelerator.rb:129:in `translate_no_override'
/var/www/discourse/lib/freedom_patches/translate_accelerator.rb:226:in `translate'
/var/www/discourse/app/controllers/groups_controller.rb:488:in `handle_membership_request'
actionpack-7.0.8.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:215:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
i18n-1.14.5/lib/i18n.rb:351:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:423:in `with_resolved_locale'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.0.8.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.0.8.1/lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord-7.0.8.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:151:in `process'
actionview-7.0.8.1/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack-7.0.8.1/lib/action_controller/metal.rb:188:in `dispatch'
actionpack-7.0.8.1/lib/action_controller/metal.rb:251:in `dispatch'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:852:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.9/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.9/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.9/lib/rack/head.rb:12:in `call'
actionpack-7.0.8.1/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:393:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.9/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.9/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack-7.0.8.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster-2.19.1/lib/logster/middleware/reporter.rb:40:in `call'
railties-7.0.8.1/lib/rails/rack/logger.rb:40:in `call_app'
railties-7.0.8.1/lib/rails/rack/logger.rb:27:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/request_id.rb:26:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.9/lib/rack/method_override.rb:24:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.9/lib/rack/sendfile.rb:110:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:191:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:277:in `call'
railties-7.0.8.1/lib/rails/engine.rb:530:in `call'
railties-7.0.8.1/lib/rails/railtie.rb:226:in `public_send'
railties-7.0.8.1/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.9/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.9/lib/rack/urlmap.rb:58:in `each'
rack-2.2.9/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Env
1/44
hostname	redacted
process_id	188
current_db	default
time	7:25 pm
I’ve seen a couple of these recently. It’s because the particular user that’s being accepted to the group has a blank locale for some reason (rather than null or a specific value like en).
A fix has been put in place to prevent this error:
If you update your site and pull that fix in that should stop those errors and allow those users to be accepted to the group. :+1:
Indeed, that fixed it. Thanks !
