Install and configure the WP Discourse Wordpress plugin for Discourse
To install and configure the WP Discourse Wordpress plugin for Discourse, follow these steps in order, watching the videos at the top of each topic:
  1. Install the plugin: Install the plugin
  2. Connect to Discourse: Connect to Discourse
  3. Set up Publishing: Set up Publishing
  4. Set up Commenting: Set up Commenting
  5. Set up DiscourseConnect: Set up DiscourseConnect
Note that the two main plugin features, Publishing and DiscourseConnect, can be used separately or together. Additional settings may need to be changed depending on your setup, and further guidance can be found in the relevant topics or by replying to the topic for support.
To get started with the WP Discourse Plugin, go through each of these topics in order and watch the videos at the top of the topic.
The two main plugin features, Publishing and DiscourseConnect don’t have to be used together. You can just set up Publishing (and Commenting), and not use DiscourseConnect, or just set up DiscourseConnect, or set up both. There’s a short description of each feature at the top of their topic.
You may also need to change some of the settings not mentioned in the videos, depending on your setup. All of the settings are explained in their relevant topic, but if you have any questions about them, reply to the topic and someone will get back to you shortly. You may also find these other WP Discourse topics useful, depending on your needs
Discourse comments are not reflected on Wordpress blog
Where can I find API key?
SSO Configured but Not Working
How to kick start a community?
WP Discourse 1.0.0 release
WP Discourse 1.4.0 Release
How to connect my wordpress site to discourse forum
Possible to create a news site with pics and videos
Api key for activate
Embedding Discourse to wordpress
Can it be done with CSS? Grouping categories on category page
Quick Question about Programmatic Link to Existing Topic
Discourse+woocoomerce subscription
Integration with wordpress
Update group membership using external database
Switching to Discourse Subscriptions from WordPress Subscriptions
WordPress SSO + Normal User registration?
Create users - SSO
Create users - SSO
OAuth 2 and other discourse sites?
Migrate WordPress Comments to Discourse
Managing Subscriptions through Wordpress (Ultimate Member + Paid Memberships Pro)
Error Log Missing
How does Discourse work with WordPress sites?
DiscourseConnect Won't Let Me Log Back In
Landing Pages Blog :small_airplane:
Disable posting wordpress articles to Discourse when they're updated
Wordpress plugin not redirect to discourse login automatically
Option to publish posts to Discourse not showing up
How to use same wordpress`s user database for discourse forum?
Wanting to start a closed community... should I Require Approval or Invite-only?
Login w/ Discourse w/o SSO?
Duplicate Content
Issues with setting up ajax comments
Wordpress integration/Plugin
Go from a Wordpress + Discourse structure to a Discourse site only?
Is there a plugin to make my forum a shop?
Deactivate auto publish discourse to post wordpress
Manage group membership in Discourse with WP Discourse SSO
Announcing v1.0 of WP Discourse
Wordpress SSO stuck in redirect loop
Open WP as a subdomain of Discourse (different hostings, only DNS pointing)
Basic forum access/integration with Wordpress site
Calling out for volunteer Community Managers :mega:
Embedding Topic topic-map or Topic Summary on Other Site
Posts and pages aren't uploading from WP discourse plugin
Is it possible to authenticate a Wordpress login via Discourse?
Does a social login WP plugin address Discourse expectation for email verification? (with WP as SSO provider)
WordPress in a Discourse iFrame?
WordPress Integration Questions
Protecting Discourse
Does discourse have discourse integration with wordpress in video
Administrators Index
Wordpress Multisite with Multiple Discourse Instances
Discourse member login on Wordpress home page
Wordpress register with discourse
Can my Wordpress members automatically become members of Discourse?
