With docker rolling out version 19.03.0, the discourse launcher is now failing to start the instance after rebuilding with the following message:
/usr/bin/docker: --network is not a valid mac address.
See '/usr/bin/docker run --help'.
This is the command run (some items changed for security):
+ /usr/bin/docker run --shm-size=512m -d --restart=always -e LANG=en_US.UTF-8 -e RAILS_ENV=production -e UNICORN_WORKERS=2 -e UNICORN_SIDEKIQS=1 -e RUBY_GLOBAL_METHOD_CACHE_SIZE=131072 -e RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000 -e RUBY_GC_HEAP_INIT_SLOTS=400000 -e RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5 -e DISCOURSE_DB_SOCKET=/var/run/postgresql -e DISCOURSE_DB_HOST= -e DISCOURSE_DB_PORT= -e DISCOURSE_HOSTNAME=discourse.mydomain.com -e VIRTUAL_HOST=discourse.mydomain.com -e DISCOURSE_DEVELOPER_EMAILS=admin@mydomain.com -e DISCOURSE_SMTP_ADDRESS=mail.mydomain.com -e DISCOURSE_SMTP_PORT=587 -e DISCOURSE_SMTP_USER_NAME=discourse@mydomain.com -e DISCOURSE_SMTP_PASSWORD=MySuperDuperPass -h vps-discourse -e DOCKER_HOST_IP=172.17.0.1 --name discourse -t --expose 80 --mac-address --network reverse-proxy --network reverse-proxy local_discourse/discourse /sbin/boot
I am using this with behind a reverse proxy (running on network named reverse-proxy). It has always worked, until today. It seems it expects a mac address value that is not being provided.
Note that --mac-address does appear and is populated, but that --network line is specific to your setup and deviates from a standard standalone Discourse install.
@codinghorror Thatās all well and great, but then, if standard standalone installs is the only way Discourse is supposed to operate, why provide support for yml container configuration in ./containers, and including examples of this in ./samples? The file I used is fully commented with instructions on operation, specifically this area:
# any extra arguments for Docker?
# docker_args:
The only thing I am using is:
docker_args: "--network reverse-proxy"
Which again, has been working great for a year now. So, obviously something has changed. Please understand I am not trying to be confrontational (it would be kind of silly since I am asking for help), but I am indeed trying to make the point that I am using options that are made available through the Discourse samples.
Perhaps if I understood how that mac address is being generated it could point me to an environment change issue, thatās what Iām hoping.
I see this in launcher:
if [ -z "$SKIP_MAC_ADDRESS" ] ; then
mac_address="--mac-address $($docker_path run $user_args -i --rm -a stdout -a stderr $image /bin/sh -c "echo $hostname | md5sum | sed 's/^\(..\)\(..\)\(..\)\(..\)\(..\).*$/02:\1:\2:\3:\4:\5/'")"
fi
Will dissect and see if I can figure it out.
UPDATE: And looking at this, I see that I can use --skip-mac-address. Doing this brings up my instance just fine, so it seems the process that figures out the mac address is the issue.
So, in summary. The build operation succeeds no matter what, but in the build operation (./launcher rebuild myinstance), the last step of starting the container fails due to the mac address somehow not being set.
However, I can simply do ./launcher start myinstance after that and then it starts fine, and the mac address is there as well, Itās strange thatās all.
I have the same problem. @codinghorror Here are the steps to reproduce and a lead to fix this regression
Step to reproduct:
Set in containers config (app): docker_args: "--network reverse-proxy"
rebuild ./launcher rebuild app
see error /usr/bin/docker: --network is not a valid mac address
Itās a bug introduced by commit bfc79e7 (GitHub - discourse/discourse_docker: A Docker image for Discourse) merge_user_args is called by set_template_info, but set_template_info is called twice when rebuild (run_run and run_bootstrap)
So instead of user_args equals $user_args $docker_args, we have $user_args $docker_args $docker_args
Docker doesnāt allow to configure the same network mutiple times docker: network "reverse-proxy" is specified multiple times
Thank you to roolback this commit or make idempotent merge_user_args
