Configure Discord Login for Discourse
:bookmark: This guide explains how to set up and configure Discord as a login option for your Discourse forum, including how to restrict access to specific Discord guilds.
:person_raising_hand: Required user level: Administrator
Once configured, Discord will appear as a login option alongside other authentication methods on your forum:
Setting up Discord OAuth2
Creating a Discord application
  1. Visit the Discord developer portal
  2. Click “New Application”
  3. Enter a name, upload an icon, and add a description for your application
    • These details will be shown to users during the login process
Configuring OAuth2 settings
  1. Navigate to the “OAuth2” tab in the left sidebar
  1. Copy the “Client ID” and “Client Secret”
    • If the secret isn’t visible, click “Reset Secret” to generate a new one
  2. Add your redirect URL:
    • Format: https://your-discourse-site.com/auth/discord/callback
    • :warning: Do not include a trailing slash
  3. Click “Save Changes”
Enabling Discord login in Discourse
  1. In your Discourse admin settings, enter the Client ID in the discord_client_id setting
  2. Enter the Client Secret in the discord_client_secret setting
  3. Enable the enable_discord_logins setting
Restricting access to specific Discord guilds
You can limit Discord login to members of specific Discord guilds (servers).
Finding your guild ID
  1. Open Discord in your browser
  2. Navigate to any channel in your guild
  3. Look at the URL: https://discordapp.com/channels/{guild_id}/{channel_id}
  4. Copy the first number (guild_id) from the URL
    • Example: In https://discordapp.com/channels/123/456, the guild ID is 123
Configuring guild restrictions
  1. In your Discourse admin settings, locate the discord_trusted_guilds setting
  2. Add your guild ID(s)
    • You can add multiple guild IDs if needed
When guild restriction is enabled:
  • Members of trusted guilds will log in normally
  • Other users will see an error message
  • You can customize this message under Customize → Text, search for discord.not_in_allowed_guild
:warning: If you’re using guild restrictions for security, disable all other login methods in your Discourse settings.
Next steps
Consider setting up the chat-integration plugin to push important Discourse topics to your Discord channels.
A post was split to a new topic: Add more scopes to discord login
Aren’t the channel IDs on discord now starting with discord.com ? When I use discord on the web it’s always been discord.com/channels/[guild_id]/[channel_id] for the last couple years or so.
It appears that this guide is quite out of date. In Discourse admin interface one can specify:
  • Enable Discord logins
  • Discord client ID
  • Discord secret
  • Discord trusted guilds (optional)
Meanwhile in the Discord developers interface, we have:
  • Name
  • Description (optional)
  • Application ID
  • Public Key
  • Interactions Endpoint URL (optional)
  • Linked Roles Verification URL (optional)
Assuming that
  • Discord client ID is the Application ID, and
  • Discord secret is the same as Public Key, and
  • leaving optionals blank,
this results in Discord error while trying to authenticate:
If I try setting Interactions Endpoint URL to
https://forum.example.com/auth/discord/callback, I get
Validation errors:
    interactions_endpoint_url: The specified interactions endpoint url could not be verified.
in Discord dev interface.
What is the correct procedure for setting this up?
