Current behaviour is: When impersonating a user’s account, the last seen date is affected by this action. This behaviour is confusing for other users and our staff since they assume, that the user was actually online at this date/time.
My suggestion is to not count the impersonation towards the last seen date.
I have to disagree with this. I am aware of a few forums from my communities that my friends and I have been a part of where the admins behind those forums would maliciously use ”impersonate” to try to get people into trouble.
Staff should have access to the staff logs that show when and who impersonated an account. You should make everyone on your team aware of it.
Admins could always reset that date in the database anyway, or prevent updating the last seen date using a plugin. If you cannot trust the admins then there is nothing you can do.
One thing that I think could actually help is sending a message to the user that they were impersonated. Yea, this could be undone by plugin makers but most malicious admins are usually teens that get scared by those kinds of stuff or adults that wouldn’t be really able to afford hiring someone to do program the plugin for them.
I think we’re getting a bit distracted from the subject here. The last seen being updated when a user is being impersonated is more confusing than useful.
If we need more auditing about impersonation then that’s a different thing.
By the way, I think you’re making some dangerous assumptions here.
Acompanhamento rápido aqui para nosso caso de uso.
Devido à natureza do nosso tópico, os usuários se preocupam muito com a privacidade. Portanto, sempre que um usuário antigo e principal “costumava ser” principal reaparece e tem uma data de “Última vez visto” recente devido a alguma personificação de administrador, alguns de nossos usuários ficam preocupados ou um tanto confusos…
Se você estiver usando o novo recurso de personificação (habilitado definindo a configuração oculta do site experimental_impersonation como true), o carimbo de data/hora last_seen_at não será mais tocado ao personificar um usuário.
Ainda estamos planejando a implementação do novo recurso de personificação para fóruns hospedados no Discourse.
Entendo que a intenção do novo recurso de personificação é diminuir seu impacto, mas atualmente existem efeitos além de last_seen_at. Pelo que pude apurar, ao personificar, você é aquele usuário.
Clicou em uma notificação pendente? Agora ele a viu.
Abriu uma postagem não lida? Agora ele a leu.
Sabendo disso, eu o usaria apenas para solução de problemas com o conhecimento do usuário. Não teria problemas com os usuários sendo notificados e recebendo um registro de atividade em uma sessão de personificação.
Ok, mas quando meu último IP fica público para aquele usuário ver? Eu, como administrador, quando me passo por qualquer usuário, meu IP “vaza” ou estou errado?
