Hi everyone, I’m getting started on developing things for Discourse, and I’m working on a theme component.
Link: https://github.com/NateDhaliwal/discourse-persistent-banner
When putting it on Theme Creator, the settings don’t appear, even though I have a settings.yml. Any ideas?
Moin
September 20, 2024, 8:28am
Do you see any error messages at theme creator?
https://github.com/NateDhaliwal/discourse-persistent-banner/blob/main/settings.yml#L4-L4
I think you have to use the same quotation marks at the beginning and end.
https://github.com/NateDhaliwal/discourse-persistent-banner/blob/main/settings.yml#L12-L12
This could also be a problem. I would try default: ""
https://github.com/NateDhaliwal/discourse-persistent-banner/blob/main/settings.yml#L16-L21
Maybe you want to add “block” to the choices. Otherwise you have to use the revert button to choose that again.
Whoops, just realised I was clicking on ‘Create new’ instead of importing it…
But now, when I try using the URL, it says that about.json is invalid or doesn’t exist, asking me if it is a theme.
About.json:
https://github.com/NateDhaliwal/discourse-persistent-banner/blob/main/about.json
Is there something wrong?
merefield
(Robert)
September 20, 2024, 10:48am
4
Missing comma after license URL.
@merefield Would version be in ""?
merefield
(Robert)
September 20, 2024, 10:58am
6
Probably that too. Just look at examples.
Thanks! One last one, I can’t seem to get the variable to display.
https://github.com/NateDhaliwal/discourse-persistent-banner/blob/main/common/header.html
Was it because I didn’t initialise it properly? I tried following the guide…
Would I have to use
import Component from "@glimmer/component";
export default class PracticeComponent extends Component {
get bannerLinks() {
return JSON.parse(settings.banner_links);
then?
merefield
(Robert)
September 20, 2024, 11:13am
10
Look at the billions of examples
merefield
(Robert)
September 20, 2024, 11:22am
11
You only need to use a gjs file if you need to process stuff with javascript, otherwise an hbs template file might suffice. Experiment.
I’m not sure if I’m going in the right direction.
I made javascripts/persistent-banner.hbs with this:
https://github.com/NateDhaliwal/discourse-persistent-banner/blob/main/javascripts/persistent-banner.hbs
But nothing shows up. Tried putting it in different places, still won’t work.
Tried looking at example, but many don’t seem to help.
Any advice?
Moin
September 21, 2024, 11:51am
13
In which plugin outlet do you want to put your banner?
Take a look at Using Plugin Outlet Connectors from a Theme or Plugin
You could use Add a featured topic list to your Discourse homepage as an example
You can use the Plugin outlet locations theme component to find the names and locations of the plugin outlets. “above-main-container” for example is the top one above the topic list, but not above the sidebar.
Looking at the code of a Theme component which adds something similar is also a great way to learn.
merefield
(Robert)
September 21, 2024, 11:57am
14
You do not need and should not put script tags in hbs files. They should be limited to the content of the template.
Don’t stab in the dark, read the guides:
There's a new component API in Octane! For this section, we'll be focusing on the differences between the new style, known as Glimmer components, and classic components, and how to upgrade. "Classic" components refer to older-style components that do...
So… I managed to get it working without using a hbs file, but instead using the <script> tag with handlebars, and it now works.
I use it like this for now, but I’ll continue to try using a hbs file instead.
Lilly
( Lilly)
September 22, 2024, 3:24am
16
created a quick pull request for you so you can see the way to split up the files properly. feel free to merge or just have a look at the branch .
main ← Lillinator:split-into-handlebars-files
opened 03:22AM - 22 Sep 24 UTC
split into the handlebars file for you :)
also removed the header.html file
Thanks so much! It works now!
Lilly
( Lilly)
September 22, 2024, 3:15pm
18
No worries Nate. Keep up the experimenting, reading and looking at other examples. In no time you’ll be much better than I am at this dev stuff
Thanks for the encouragement!
system
(system)
Closed
October 22, 2024, 10:58pm
20
