Theme Developer Tutorial: 3. CSS in Themes
Technically, Discourse uses SCSS to author its stylesheets. However, we’re increasingly moving towards native CSS features as they mature, so the vast majority of themes won’t need to use SCSS features or syntaxes. We follow a variant of BEM for our CSS, you should be familiar with this when writing theme CSS.
This chapter will focus on Discourse-specific subjects, so if you don’t already have a passing familiarity with CSS, take some time to learn about it from CSS styling basics - Learn web development | MDN.
Authoring theme CSS
As we touched on in the last chapter, the main entrypoint for theme CSS is the common/common.scss file. For many themes, that’s all you’ll need.
You can also use desktop/desktop.scss and mobile/mobile.scss, although we’re increasingly moving away from these separate files and towards breakpoint-based styling in common.scss.
But for more complex situations, you can put additional scss in files like /stylesheets/my-styles.scss, and import from common.scss like @import "my-styles";
Using variables
Discourse makes extensive use of CSS variables for colors, font sizes, and other things which need to be shared throughout the stylesheets. You can find a full list of the color variables here, font variables here. Or alternatively, open your browser dev tools, select the <html> element, and scroll through all the available variables.
Let’s make use of this knowledge by updating our theme to use the theme colors for the banner! Open up the common.scss file, and update the color properties to use variables:
.custom-welcome-banner {
  background: var(--quaternary);
  color: var(--secondary);
  text-align: center;
  padding: 10px;
discourse_theme will sync this change up to your site instantly, and the change should appear in your browser.
Great! Now your banner’s colors will match the site color scheme, and automatically adjust based on light/dark modes.
For more information about the variables available, check out this document
Finding CSS selectors to style
The number of elements and classes in Discourse can feel quite overwhelming from a re-styling standpoint. The key to having a maintainable theme is to keep your changes as small as possible, and match the selectors used in Discourse core’s stylesheets.
For example, let’s assume you want to style all the buttons in Discourse. One approach would be to use DevTools and try to find every variation of every button and style it. But a better approach would be to see how core is styling buttons, and base your approach on that.
To explore re-styling Discourse in more detail, check out the Designer’s guide to Discourse themes
Or if you’re ready to explore more ways to add/change content in Discourse, let’s go to the next chapter
This document is version controlled - suggest changes on github.
Should not it be scss for themes, or stylesheets can actually be used too?
Both work. I prefer /stylesheets for consistency with core & plugins… although now I realise that the theme-skeleton uses scss/ so that’s what 99% of themes are using :sweat_smile:
Reckon I can just sneak this in here, and pretend I didn’t forget to make this change to the skeleton 6 years ago :shushing_face:
So would it make sense to rename scss to stylesheets in existing themes (and plugins? I’m in my phone and haven’t looked at my plugins)
Entirely up to you. They’re synonyms in our theme compiler, and we don’t have any plans to deprecate scss right now.
(If we did decide to deprecate, you’d get plenty of warning)
This only applies to themes. Plugins have always used /stylesheets as the convention.
