Плагин вкладок BBCode для Discourse
Download nodeloc/discourse-bbcode-tabs
Demo (重发)【测试留档】tianlicloud 香港精品 - 评测 - NodeLoc
Demo Image
Discourse BBCode Tabs Plugin
This plugin adds support for tabbed content in Discourse posts using BBCode syntax. It allows users to create multiple tabs with different content that can be switched between without reloading the page.
Features
  • Create tabbed interfaces in posts using simple BBCode syntax
  • Full markdown support inside tabs
  • Tabs work with both light and dark themes
  • Responsive design for mobile devices
  • Keyboard navigation (arrow keys) between tabs
  • Tab selection is remembered between page loads
Installation
Follow the plugin installation guide:
cd /var/discourse
git clone https://github.com/nodeloc/discourse-bbcode-tabs.git plugins/discourse-bbcode-tabs
./launcher rebuild app
Settings
This plugin provides several site settings that can be configured in the Discourse admin interface under Plugins > BBCode Tabs:
  • bbcode_tabs_enabled: Enable or disable the BBCode Tabs plugin (default: true)
  • bbcode_tabs_first_tab_active: Automatically select the first tab by default (default: true)
  • bbcode_tabs_remember_selection: Remember tab selection between page loads (default: true)
Usage
You can add tabbed content to your posts using the following BBCode syntax:
[tabs]
[tab=Tab Title 1]
Content for tab 1
[/tab]
[tab=Tab Title 2]
Content for tab 2
[/tab]
[tab=Tab Title 3]
Content for tab 3
[/tab]
[/tabs]
The first tab will be selected by default.
Examples
Basic Example
[tabs]
[tab=一列]
在此填写你的文本,在此填写你的文本,在此填写你的文本,在此填写你的文本
[/tab]
[tab=二列]
[/tab]
[/tabs]
This will create two tabs labeled “一列” and “二列” with the specified content in each tab.
5 лайков
You can request to enter the plugin-authors group so that you can post this in the Plugin category.
2 лайка
This is quite cool. I can definitely see a lot of value added
2 лайка
Not
@cuo_wu You don’t need to clone the repo manually. You just need to add it to the app.yml file (also, the command is slightly wrong).
Nice plugin though! I can see many use cases for this.
1 лайк
My mistake. :laughing:
2 лайка
