Tag Intersection Navigator
:information_source: Summary A Discourse plugin that extends the Tag Intersections interface to provide an improved experience for navigating combinations of tags
:hammer_and_wrench: Repository Link https://github.com/merefield/discourse-tag-intersection-navigator
:open_book: Install Guide How to install plugins in Discourse
:heart: Sponsorship Please consider becoming an ongoing sponsor of my open source work at a level that suits your or your organisation’s resources and needs to ensure this plugin gets the maintenance it deserves and continues to work for your site in the future.
Enjoying this plugin? Please :star: it on GitHub ! :pray:
Features
Enhances the existing Tag Intersections capability to:
  • Allow it to be empty or used with just one tag
    • This makes for a more user friendly and flexible user experience, allowing you to drill in and out of combinations of tags
  • Support for different filters instead of just Latest.
  • Provide a way to make it the default on your desktop Homepage
  • Supported by Bars
Important
:warning: you must not use the word “everything” as a tag on your instance. :warning:
Settings
Three are just four settings:
  • to enable the plugin
  • determine which string is used to describe “everything” in the routing - I advise you don’t change this, but you can experiment with alternative options. You must avoid using the same string as a tag
  • to make the interface the Homepage for desktop (default OFF)
  • include a community link in sidebar/header dropdown (default ON)
Limitations/A Roadmap?
Hire me or submit a PR to add the following:
  • Like core intersections, does not yet work with a combo of Category - but this continues to fall back to the Category/Tag interface :white_check_mark:
  • Sub-categories are not yet supported
  • There are no Topic counts on the navigation tabs and their
    visibility/availability is presently not determined by availability of the corresponding topic list population count.
  • Respect availability/ordering of filter settings.
  • The interface is not offered on mobile due to lack of real-estate.
Credits
Great thanks to its sponsor, @pensarfrentealtiempo :folded_hands:
When (not if) I want to keep my frontpage as it is, how can I reach this intersection thing?
@Jagster as of FEATURE: add community link, make homepaging default OFF · merefield/discourse-tag-intersection-navigator@15e6e65 · GitHub
There’s now a setting for a Community Section Link.
The “Homepaging” is now default OFF:
thanks to @awesomerobot for helping out here and I’ll try to remember to refine the solution when his lovely PR goes in.
Ok, the path is /tags/intersection/everything/everything. Now I understand why I got 404 all the time.
Thanks.
One small beauty glitch, nothing serious.
Every of my users can that much English :winking_face_with_tongue:
BTW, I know mobiles aren’t supported, but it works just fine in mobiles. Only that is different is they can see Latest etc. menu, and most of mobile-users can show such four point menu. If there would be hot, top etc. then it would be crowded.
But I like this system. Nice.
Ha. I will localise. What a silly dropped ball. Thanks.
that’s done
What is the core limitation here forcing you to extend the backend? I thought we have native controller support for this.
On this route, core backend OOTB lacks support for:
  • zero or one tag
  • different filters (it’s all “Latest” otherwise)
There is now support for this route in Bars so you can add sidebars to your tags intersection (maybe home) page. :tada:
Thanks for sharing this plugin @merefield it is quite interesting and thought-provoking :smiley:
I found one little issue when the everything word is customized.
When the discourse_tag_intersection_navigator_all_word setting is customized to anything other than everything, the hardcoded intersectionRoute fails.
The easiest way to reproduce this issue is by changing these 2 settings, and then navigating to homepage:
  • discourse_tag_intersection_navigator_all_word: anything
  • discourse_tag_intersection_navigator_make_intersection_homepage: true
I propose a potential solution for your review:
That’s merged, thanks for the contribution!
It no longer does.
I’ve implemented Category filter integration:
:tada:
@merefield does it support negative tags like search does by chance?
(didn’t get to testing it yet)
-#foo -tags:bar or something
No, it does not.
Thanks for the reply
I’ll leave a feature request in issues
And a feature request for search field
(I don’t actually need them, they are just the logical conclusion of completely replacing search for general use)
(negative tags are the worst documented feature I know. For sure there are worse documented ones I have no idea about)
thanks.
Just to manage expectations - I don’t foresee this plugin expanding any in capability for the time being without funding or incoming PRs. It will be enough to provide any free maintenance
Also I would say we’d need to be careful adding too many bells and whistles as not to clutter or over-complicate the interface which atm is fairly intuitive and fills the available space on desktop quite nicely without being overbearing. Features such as those you mention would definitely need to be behind options but I respect some people might find them useful.
I can not select sub-category. It has a 404 error if sub-category selected.
Good catch. I’ll make a note that that’s not supported at this time. (Done: note in limitations in OP)
Thanks for your interest
