Обмен темами не работает: настройки и переводы недоступны в конструкторе тем
Continuing the discussion from I cannot save Theme settings in theme creator:
Now I cannot see settings and theme translations at all.
And the share button at the bottom doesn’t work either.
I reported something similar not too long ago:
1 лайк
I know, but what I’m mostly missing right now are the translations and the ability to share. You hadn’t mentioned those. Also, I was worried that a single note on the topic might get overlooked.
1 лайк
yea theme creator is a bit broken at the moment and we’re looking into it.
3 лайка
These issues should be resolved now
3 лайка
This topic was automatically closed after 5 days. New replies are no longer allowed.
