Feature Request: Add Support for \nicefrac in Discourse Math Rendering
Summary
Please add support for the \nicefrac{a}{b} command in Discourse math rendering. This diagonal-style fraction is compact and ideal for inline expressions, improving readability without disrupting line spacing.
Why \nicefrac?
- Produces clean, diagonal (slashed) fractions like
$ \nicefrac{1}{2} $ - More elegant than
1/2and less bulky than\dfrac{1}{2} - Common in physics, statistics, and mathematical writing
Implementation Notes
Discourse might be able to support math via KaTeX or MathJax, depending on the installed plugin. This feature request outlines implementation for both:
MathJax
MathJax might support \nicefrac if an extension is loaded:
MathJax.Hub.Config({
TeX: {
extensions: ["AMSmath.js", "nicefrac.js"]
This could mean no core changes are needed — so you could just update the plugin config to enable the extension.
KaTeX
KaTeX does not support \nicefrac natively. It might be possible that the following workaround macro can be added:
macros: {
"\\nicefrac": "\\raisebox{.5ex}{\\footnotesize #1}/\\raisebox{-.25ex}{\\footnotesize #2}"
Alternatively, it might be worth investigating support through third-party KaTeX extensions such as katex-extension.
Reproduction
Try rendering the following:
$\nicefrac{3}{4}$
Result in KaTeX:
`KaTeX parse error:
Undefined control sequence: \nicefrac
Result in MathJax (if extension not loaded):
`MathJax parse error:LaTeX Error: Command \nicefrac undefinedUndefined control sequence: \nicefrac
Expected Behavior
$ \nicefrac{3}{4} $renders a proper diagonal fraction- Might be able to work consistently across both KaTeX and MathJax
installsproviders - Hopefully, No parse errors or user confusion
Motivation
\nicefracis widely used in LaTeX documents and teaching materials- Inline fractions appear more naturally in text
- Improves math formatting in STEM-heavy Discourse communities
References
Thank you for considering this small but valuable improvement to math rendering in Discourse!
