Not seeing the user pref panel for Discourse AI
A user named ばこん noticed that the /u/username/preferences/ai page was missing from their self-hosted instance and on meta. They inquired if this was intentional or if the page had been moved. sam responded that the page is present in the default install and suggested it might be specific to ばこん’s setup. ばこん later confirmed that the page had been added back and thanked sam.
Hey, I noticed that the /u/username/preferences/ai page seems to have disappeared recently, both on my self-hosted instance and here on meta.
Was this page intentionally removed, or moved elsewhere?
I’m running the latest Discourse AI plugin on my server.
Just wondering if this was a UI change or something else. Thanks!
probably specific to your install somehow, it is certainly there on our default install…
scrolling can sometimes get you on this one.
I just checked, and it has been added! Thank you very much!
