Heractiveer ontdekkingszoekopdracht (volgens gebruikersinstellingen)
I accidently clicked disable AI powered search on my main account, I can’t seem to find a way to reenable this. Is it possible?
Thanks
Hmm, this should show under Discourse Meta - The Official Support Forum for Discourse. Is this a regression @keegan ?
I don’t think so… Search discoveries is currently disabled on Meta which is why we can’t see the setting here.
I can still see it when I test it out locally…
@shuao23 If you the site has the feature enabled (i.e. SiteSetting.ai_bot_enabled = true and SiteSetting.ai_bot_discover_persona is set) it should be configurable for each user at: /my/preferences/ai by toggling :check_box_with_check: Enable search discoveries.
Nice, I can go to the link, but for some reason the self hosted instance we use doesn’t have that tab
Ah yes, thanks for pointing that. There was actually a Contribute > Bug here, I just pushed a fix:
