In a Support thread titled How to reset Proofreader settings, bksubhuti reports losing the “Proofread” option from the composer context menu after experimenting with custom AI prompts for Pali diacritics and switching models (from OpenRouter to Gwen). They attempted to reset AI settings via Rails console but encountered issues, including a corrupted command string and failed rebuilds. bksubhuti later notes that custom prompts still work, but other AI helper features like Proofread are missing. Moin asks for details on the AI helper’s configuration and whether the “Proofread” tab is visible under settings. In post 4, bksubhuti confirms the issue was resolved after their “SOS-helper” rebuilt Discourse — though the root cause remains unclear. They suspect a bug when pasting instructions into the custom prompt field, which may have corrupted the AI helper’s state. Despite the disruption, they note that user groups (10–15% active) were unaffected, and the system now functions normally. They express gratitude for the help and clarify they no longer need a custom persona, as the default setup suffices. The thread highlights potential instability in the AI helper plugin during configuration changes, especially with custom prompts, and underscores the value of manual rebuilds for recovery.
Hi, I was fixing my open router issues and changed to gwen and things were good.
Then I wanted to try to make a custom persona or have the prompt be geared towards pali language diacritic marks. I somehow removed proof-read from the context menu of the composer. gpt is making me go in circles.
Can someone help me?
Will this reset all the ai stuff? cd /var/discourse ./launcher enter app rails console PluginStoreRow.where(plugin_name: “discourse-ai”).destroy_all exit ./launcher rebuild app
I’m a big fan of reset and start all over, but i’m not trusting gpt+ on this suggestion and the ai plugin is now built-in for discourse and might operate differently.
Unless you really know how to fix this for me.. I’d rather reset. I’m going in circles.
Then I’ll try again to fix.
Can I suggest a simple mode for ai settings.. it is too intense.
Something was broken. No matter what I changed in the trust levels, it did not change after save. I tried rebuilding in the console and the web console kept disconnecting leaving the discourse rebuild unfinished. Then I had my “SOS-helper” help me and after he rebuilt it, everything was working as it should. I’m not sure what happened, but it is working now.
I’m not sure, but I noticed a bug when I wanted to past instructions into the custom ai prompt on the composer. Then it would only correct the instructions. It might be related. It would be common to want to paste instructions into the custom prompt.
I don’t need that since i have a persona now.
I appreciate your help.. something was odd.
My discourse was down for 1 hour but we are a small 300 member group with ~10-15% active, so it did not affect a huge number of users.
The solution was that there was some type of bug, now it is resolved from a rebuild.
