Converter to change gregorian date to jalali on view layer of discourse
Thank you :slight_smile:
I have a question about making plugins for discourse.
Iran calendar is Solar hijri or jalali, I want to make a converter to change gregorian date to jalali on view layer of discourse (without changing database).
wordpress has a plugin that convert all dates on website to jalali.
I want to do exact same thing and globally override the date method on view layer and display jalali date if forum language is persian.
How can I do this without changing discourse core codes and database ?
2 curtidas
Any help ? :worried:
1 curtida
I’ve looked at a few sites here that I thought might be using different calendars.
A Chinese site is using English and Gregorian dates.
Hebrew sites look to be using Hebrew month names with Gregorian years.
I’m guessing this hasn’t come up before because much of the world uses Gregorian / countries with alternate calendar systems also understand Gregorian?
I know the database has a great many timestamp fields, I wouldn’t mess with those.
Sorry, but I am completely ignorant about converting one calendar to another.
Do you know of any Gems that do this?
1 curtida
Thank you for your response.
You are right, a lot of countries use gregorian dates. But most people (I guess +99%) of people in Iran use jalali calendar.
I found this gem called parsi date but I’m not familiar with ruby language and I don’t know how to use it.
as I said before, I don’t want to change discourse’s core or database. just changing the dates on view layer would be great.
ps : jalali date is not just about month names. years and month length are different too.
for example :
29
Apr
2017
to jalali :
09
Ű§Ű±ŰŻÛŒŰšÙ‡ŰŽŰȘ ( ordibehesht )
1396
Maybe you can do that with a simple js script JalaliJSCalendar
6 curtidas
are you looking for a date-convertor or do you want to know how to change the dates in discourse in a plugin without knowing ruby?
if you want the second one, a simple-stupid way is to change it in the front-end side using js, with the data in json pages. e.g. check this page:
https://meta.discourse.org/t/converter-to-change-gregorian-date-to-jalali-on-view-layer-of-discourse/61671.json
all the post information exists there! if you search for “2017” you’ll find some dates there, and you can then use some third party calendars and change between the two.
so far we’ve used this simple way a lot. it’ll work for short-time until you learn ruby+discourse!
4 curtidas
@Trash Thank you, I know how to convert dates to jalali. I did this in PHP before. I just don’t know how to do it in Ruby on Rails Project.
@Pad_Pors Thanks, I want to do the second one.
Which .rb file generates this json file ?
1 curtida
you don’t need to generate the json files, it already exists and you only need to use it.
@Alavi1412 can help you better about this.
1 curtida
@Pad_Pors
I’m not trying to generate json file. I want to change date before sending to client.
2 curtidas
So not try to change the source code.
You just need a javascript to select the date element at your page and change it and add it to your page.
I think Topic controller is making this for you but for changing this you need to know some Ruby.
I suggest you to create a very simple plugin and change the date by selecting elements completely in javascript
Hi
Is it possible for anyone to write a date conversion plugin written by Jalali?
We need such a plugin.
If anyone can guide, thank you.
OlĂĄ,
Esse Ă©, na verdade, um processo simples.
Passo a passo: habilitar datas Shamsi no frontend do Discourse
1) Criar um Componente de Tema
  1. Vá para Admin → Personalizar → Temas
  2. Clique em Componentes
  3. Clique em Adicionar → Criar novo
  4. Nomeie-o: Conversor de Data Shamsi (Ou o que vocĂȘ quiser)
2) Adicionar o script (Seção Head)
Dentro do componente:
  1. Abra Comum → Head
  2. Cole tudo abaixo
  3. Salvar
CĂłdigo:
<script>
(function () {
  // Aplica apenas quando o idioma do site Ă© Persa
  if (!document.documentElement.lang.startsWith("fa")) return;
  const formatter = new Intl.DateTimeFormat(
    "fa-IR-u-ca-persian",
    { dateStyle: "medium" }
  function toDate(value) {
    if (!value) return null;
    // época (segundos ou ms)
    if (/^\\d{10,13}$/.test(value)) {
      const n = Number(value);
      return new Date(value.length === 10 ? n * 1000 : n);
    const d = new Date(value);
    return isNaN(d) ? null : d;
  function process(el) {
    if (el.dataset.shamsi === "1") return;
    const date =
      toDate(el.getAttribute("datetime")) ||
      toDate(el.dataset.time) ||
      toDate(el.getAttribute("title"));
    if (!date) return;
    el.textContent = formatter.format(date);
    el.dataset.shamsi = "1";
  function run(root = document) {
    root.querySelectorAll("time, .relative-date").forEach(process);
  // carregamento inicial
  run();
  // lida com rolagem infinita / atualizaçÔes ao vivo
  new MutationObserver(muts => {
    muts.forEach(m => m.addedNodes.forEach(n => {
      if (n.nodeType === 1) run(n);
  }).observe(document.documentElement, { childList: true, subtree: true });
</script>
___
Alternativamente, vocĂȘ pode carregar o que eu exportei e atribuĂ­-lo aos seus temas.
discourse-shamsi-date.zip (1.1 KB)
Como funciona
O Discourse jĂĄ envia datas Gregorianas normais para o seu navegador; este script nĂŁo altera os dados, ele apenas substitui a forma como o texto da data Ă© exibido na pĂĄgina, convertendo-o para Shamsi (Jalali) usando o prĂłprio navegador.
O que o script faz (visĂŁo geral)
  1. Encontra esses elementos <time>
  2. LĂȘ a data Gregoriana real de datetime
  3. Converte para Shamsi
  4. Substitui apenas o texto visĂ­vel
  5. Repete isso sempre que novas postagens sĂŁo carregadas
É isso. Nada mais.
Isso lhe darĂĄ datas como esta:
VocĂȘ pode ver isso online na nossa instĂąncia: https://forums.7ho.st
Boa sorte
1 curtida
