Scheda utente "Ultima visita"
This theme component will allow you to include the “last seen” user statistic in user profile cards.
Repo: GitHub - tshenry/discourse-last-seen-user-card-theme-component
Before
After
About
In addition to my own interest in having this stat added to user cards, there’s been some discussion on here that inspired this theme component’s creation:
Installation
Follow this guide here:
Please feel free to post if there are any questions, problems, or suggestions!
46 Mi Piace
This is fantastic. I will use this function a lot as I assess new members’ engagement and chase particular people down who I work with closely.
2 Mi Piace
This has had a minor update:
  • Reduced the amount of code by switching from a full template override to using the existing plugin outlet to achieve the same positioning.
For anyone that uses this or is interested in using it, there are four metadata positions on the user card. Currently, starting from the left it goes last post, date joined, last seen, and time read. Which position would you prefer the "last seen" metadata to be displayed?
  • First
  • Second
  • Third (where it is currently)
  • Fourth
0 voters
I imagine it’s not extremely important to most, but I’m curious if there is a preference that I can consider for a future update.
4 Mi Piace
I don’t mind where it is so long as it is there.
1 Mi Piace
I’ve update this to position “Last Seen” first in the list. Thanks to all that voiced their opinion :grin:
8 Mi Piace
@tshenry Is it compatible with latest Discourse? It’s not working although installed.
I just checked and it’s working on the latest tests-passed. Did you make sure to refresh the page after adding the component to your main theme?
3 Mi Piace
Did you check on mobile view as well?
1 Mi Piace
Ah, good point! Fun fact - this component was created before mobile user cards existed! Because of that, it was only set up to work on desktop.
I’ve just pushed an update that should support both environments:
8 Mi Piace
I’ve got the update, thanks.
2 Mi Piace
Reviving this one: Just to confirm that it still works like a charm and is super useful!
This makes it super quick easy to check if the user is in fact still an active member. Before I always had to open full profile to decide if it’s worth the time so send a private message to the user.
Would love to see that in core!
4 Mi Piace
Sì!! Dovrebbe assolutamente essere nel core secondo me. Nel frattempo, grazie mille a @tshenry!
3 Mi Piace
Ho notato che dall’ultimo aggiornamento di Discourse, il testo “Last Seen” nella scheda utente è molto più grande del resto ed è anche in grassetto. Ho controllato ed è racchiuso in <h3> quindi ho annullato questo inserendo
#user-card .last-seen-metadata h3 {
    font-size: unset;
    font-weight: unset;
nel CSS del tema.
Non ho idea se questo sia un effetto intenzionale, quindi volevo condividere la mia esperienza.
2 Mi Piace
Probabilmente no.
4 Mi Piace
Ho aggiunto una pull request per il componente qui per rimuovere il tag heading per corrispondere alla modifica di Discourse:
8 Mi Piace
Grazie mille per la spiegazione e anche per la PR! :slight_smile:
2 Mi Piace
Grazie mille per questa correzione! Sarà inclusa nel branch stable 3.3.x?
Gli aggiornamenti dei componenti del tema sono completamente separati dagli aggiornamenti principali, puoi aggiornarli in qualsiasi momento dall’interfaccia di amministrazione indipendentemente dagli aggiornamenti principali.
2 Mi Piace
Oops, mi dispiace, ho dimenticato che questo è un componente del tema e non fa parte del core.
2 Mi Piace
Funziona benissimo, ma per qualche motivo per me appare per ultimo nella lista (dopo cheers).
1 Mi Piace
