Un grande grazie a @joebuhlig per discourse-biobook, che ha ispirato questo lavoro. E anche a @angus, @fzngagan e @alxpck per aver sollecitato i vari miglioramenti fondamentali necessari per rendere possibile questo progetto.
Ospitato da noi? I componenti del tema sono disponibili per l’uso nei nostri piani Standard, Business ed Enterprise.
Thanks this is beautiful and something I’ve been thinking about for a while. I know this is a theme component so not sure it changes any functionality, but asking anyways. Does this happen to enable users to search each other by their attributes?
For instance if a custom attribute for users is University Attended and a user wanted to find everyone who went to a particular school could they search for Stanford and have all the users pull up here? I saw this link that seemed to maybe imply that but having trouble interpreting it.
might be out of the scope, but i found this post linked on another one that seemed to be headed down that route.
Unfortunately not, this doesn’t add the ability to filter users by their metadata. It does add a group dropdown, so maybe that could work for you? You could have groups for each university, people could join those groups, and then they would appear in the dropdown
Hi, David
i have a confusion, when i use search or select a group, my personal user card always shows, whether i am in the group or not in.
can you help me,
how to remove my card if i’m not in the select group or i’m not the search name.
Ah okay. I see. I meant this link and @fzngagan’s PR, but i see it was declined.
The only thing with the groups approach you mentioned is I think it would put a lot of manual onus on the moderators/admin of the forum to put people in groups as they join or worse, as they update their profile.
I’m trying to think of a workaround. Perhaps if there was a way to automate the segmentation of users into groups by a custom attribute, dropdown though so its exact matches? Curious if you know of anything like that.
I’ll look around.
I setup your component on my local setup and results are amazing. Appreciate the efforts.
I noticed there’s a hidden site setting enable_new_user_card_route but it doesn’t seem to change the results here. Is the setting required for anything here?
Nope, that setting is not required for this. It changes the route used for “normal” user cards, so that they’re much more efficient. We’ll be changing the default to true in the next few weeks.
We are running the master, which says it is even with tests-passed, but I am still having the problem with missing details on the cards, just as on the screenshot @cjk77 posted. Do we need to switch to tests-passed to get this working?
You shouldn’t run master in production - it sometimes contains commits which have not yet passed continuous integration tests. tests-passed is much safer, and only a few minutes behind.
But yes, this theme should work on master. Can you share a link to your site so I can take a look?
