已故社区成员的最佳实践
We had a member of our community pass away last week. Are there any communities that have best practices for working with this?
Some thoughts—
  • create a group called RIP or In Memoriam
  • have a message on their profile page
I’m wondering how other communities have dealt with this or if there are any features that might be useful.
Thanks
13 个赞
I am sorry to hear you have lost a member of your community. My condolences! I think you are pretty much on the right track.
There is a procedure for this in the legal empowerment network community:
  1. change account status to tribute and change email address to community+username@foo.com
  2. As needed/appropriate:
    • Write tribute forum post and tag it #tribute
    • Update profile page with tribute bio, linking to tribute forum post
    • Update network champion for organization if appropriate
    • Draft and send out tribute via mailer (if core member or close partner)
    • Post replies to discourse post as appropriate
Step 1 is dependent on a wordpress user meta field used to keep track of members. Members can be active, dormant, tribute, or unreachable. community@foo.com is an email address for the helpdesk used in case later there is something going on with the account that needS attention.
Here’s an example: Profile - nomboniso - Grassroots Justice Network Community Discussions
19 个赞
Sorry to hear that, Steve. Always a tough one for community managers.
Here are some things you could do:
  • If the platform allows, you can explore the option to ‘memorialize’ the profile with a suitable message.
  • If you can get in touch with the family (depending on the nature of the community), you could explore the option of giving them the user credentials to read & respond to messages in the memorial thread. This can be tricky because you want to ensure the right people have access. Trickier if the community member was using a work email for the community, in which case you might need the permission from their company.
  • Depending on the nature of the community, you can see if they can support the family in any way.
  • Lastly, if you have the access to a legal team, would be useful to get their advice and inputs on any initiatives you plan, especially around data privacy, security etc.
Again, most of this depends on the kind of community you’re running. I wrote a bit about this here: https://artplusmarketing.com/dealing-with-death-on-the-internet-f30ea8c735a3
11 个赞
This is a tough one indeed. Thank you for the thoughtful topic, and the replies.
13 个赞
Hi all,
today we received info that a long standing member of a forum I host has died.
Here’s what I’ve done so far - very similar to the previous posts:
  1. Create a ‘in memoriam’ group and add a flair to show on the deceased account.
  2. anonymise the user email address
what has been suggested by the community is to lock all the user’s posts so they can’t be edited by anyone except ‘admin’ to create a lasting record of their community input.
Does anyone know a way to permanently lock all posts by a user?
Thanks all,
Dave
6 个赞
Locking the posts like that is likely not necessary and adds UI noise to every post - plus, edit histories are public and such edits can be rolled back if needed.
4 个赞
不幸的是,这个话题与我产生了关联。我将该用户的头衔设置为“In Memoriam”(纪念),并移除了该账户的特权和信任度,以避免其成为接管目标。
作为将电子邮件地址匿名化以明确目的的替代方案,我仍使用了 .invalid 顶级域名,以明确用途并消除任何基于电子邮件的接管风险。我认为无法通过 UI 完成此操作(我可能记错了),但我成功通过 Rails 控制台实现了:
u = User.find_by_username("deceasedUser")
UserEmail.where(user_id: u.id).each() do |e|
    e.email = "deceasedUser@in-memoriam.invalid"
    e.save!
6 个赞
我正在尝试确定为已故会员设置账户的最佳方式。
我可以将账户设置为信任级别 0。这会移除大部分访问权限,但并未限制几项功能。我该如何阻止以下操作:
  1. 发送出站电子邮件
  2. 接收私人消息
任何建议都将有所帮助。
1 个赞
最简单的方法可能是使用用户管理页面上的“停用帐户”按钮。这也会阻止电子邮件的发送,因为这就像电子邮件地址尚未验证一样。
停用用户后,在选择私人消息收件人时不会出现该用户,并且用户卡会显示用户已被停用,而不是提供私人消息按钮。
1 个赞
感谢您的回复。我研究了停用账户。使用此方法存在以下缺点:
  • 帖子将从搜索结果中移除。这使得停用方法变得不可取,因为我们有已故会员拥有超过 5,000 篇帖子。
  • 系统自动化有可能删除不活跃账户。
我研究了账户的停用和暂停。两者都有负面属性。
你在哪里找到的信息?
我搜索已停用测试用户的帖子没有问题。
您是以管理员还是普通用户身份登录的?
作为一个没有任何版主权限的测试用户
我的社区的一位成员于两年前去世。
虽然他无疑以创作一些杰出作品而闻名,但社区的生活和运作方式有时会让用户在不被注意的情况下变得不活跃。
至少公开地,没有人询问近况(我通过电子邮件收到一位家人的通知),我也没有对该账户采取任何具体行动,也没有设置任何形式的纪念功能,因为我相信如果要做公告,应该由家人发布,或在获得家人授权后发布。我曾询问他们,但从未收到任何回复。
所以这个账户仍然原封不动,尽管它让我感到难过,因为它似乎被遗忘了,尽管它对这个社区来说是多么珍贵。:frowning:
6 个赞
我也不赞成在这种情况下停用用户,因为该功能目前的运作方式。停用的用户将不再显示在搜索结果中,也不会显示在用户列表中,并且无法被提及。这使得他们的帖子非常难以找到,除非你还记得一些关键词!
一个有趣的功能请求是,在停用用户时将其设为一项选项。在某些(可以说大多数)情况下,您不希望用户或其帖子轻易被找到,但在其他情况下(例如,当员工离开公司时),我认为这并非如此理想。
我看到我在 2020 年(当时是 Namati 和现已更名的 Grassroots Justice Network 的社区经理)给出的建议(此处)在那里仍然有效。我认为它效果很好。
我认为只需将电子邮件地址更改为您正在检查的地址即可。如果有人试图写信给该人,您可以回复告知他们已故。您还可以编辑他们的用户偏好设置以关闭电子邮件通知和电子邮件摘要。
2 个赞
我为我的论坛使用了以下步骤。
我创建了一个“纪念小组”(In Memoriam Group)。该小组设置为带有黑色丝带的徽章,该徽章会添加到成员的头像上。
当有成员去世时,我执行以下操作:
管理员 > 用户的页面(针对该用户)。
  1. 我将其信任等级设置为 0
  2. 我将其小组设置为“纪念小组”。
在公开个人资料页面 => 偏好设置 => 电子邮件下
  1. 我将所有选项更改为“从不”(Never)
  2. 取消选中“活动摘要”(activity summary)的选项
在公开个人资料页面 => 偏好设置 => 通知下
  1. 将通知更改为“从不”(Never)
  2. 取消选中“当有人分享链接时通知我”(notify when someone shares a link)的复选框。
  3. 禁用任何实时通知
在公开个人资料页面 => 偏好设置 => 用户下
  1. 取消选中“允许其他用户向我发送私人消息和聊天直接消息”(Allow other users to send me personal messages and chat direct messages)。
这将阻止任何电子邮件或通知,并阻止用户向已故成员发送消息。
希望这对有类似需求的人有所帮助。
6 个赞
我做过同样的事情。不过,如果能有一种简单的一键式方法来完成所有这些就太好了!!
4 个赞
