The discussion is about creating a plugin to override the QUERY_RESULT_MAX_LIMIT in the Data Explorer module. tkrunning initially attempted to create a plugin but struggled to get it working. However, sam advised against this approach and recommended submitting a PR to add a Global Setting instead. pfaffman shared a workaround by editing the plugin.rb file and proposed adding a default Global Setting. sam suggested using the Global Setting everywhere, eliminating the need for a constant. After some clarification, pfaffman understood that adding a default Global Setting with GlobalSetting.add_default would provide a default value if the setting is not configured. The agreed-upon solution involves adding a default Global Setting and replacing references to the old constant with the Global Setting, as agreed with by sam.
I naively attempted to create a plugin (which I’ve never done, other than running through the plugin tutorial some years ago) to override the limits set in the DataExplorer module, however I’m not getting it to work.
Am I on the right track or is this a completely wrong approach?
Note: I am setting the QUERY_RESULT_DEFAULT_LIMIT to 1 to make it easier to test if the custom limits are taking effect.
Apparently this hasn’t been a high priority for ranyone in the past 2 years, but I needed this today and solved it by editing the file by hand inside the container.
A workaround is something like the below in app.yml:
I would stop using the constant and instead use GlobalSetting.query_result_max_limit everywhere, you are already configuring a default, why configure it twice.
