투표 후 버튼을 하단으로 조정하기
:information_source: Summary Adjust the post-voting button to the bottom
:hammer_and_wrench: Repository GitHub - Lhcfl/discourse-post-voting-mobile-fix · GitHub
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
As shown in the figure, this theme component has only one function: adjust the post-voting button to the bottom.
8개의 좋아요
Thank you, this is a great theme-component, it makes my mobile interface look much cleaner.
4개의 좋아요
Thank you for this module, it is very necessary for mobile. However, when I click on the sorting section, its shape is distorted. What can be done about it?
1개의 좋아요
I encountered this problem early in the release, and suffered from no way to reproduce it stably. I tried the method you gave, but failed to reproduce.
1개의 좋아요
Only problem is mobile, desktop version is fine.
You can test it here. Maybe it’s because of a plugin I’m using.
Thank you for your help. I pushed a fix, it should work.
1개의 좋아요
it works great, thanks for the support so fast.
Is there a chance to update this component? Or I suggest adding a mobile view to the plugin itself. On mobile, having the voting on the left makes the screen smaller, it makes more sense to have it on the bottom or top. Thanks.
yeah I was planning to update it today :slightly_smiling_face:
2개의 좋아요
I fixed it temporarily, further fixes will need to wait for discourse-post-voting upgrade.
4개의 좋아요
thank you very much, you are the best :slight_smile:
