Переместите кнопку после голосования вниз
:information_source: Summary Adjust the post-voting button to the bottom
:hammer_and_wrench: Repository GitHub - Lhcfl/discourse-post-voting-mobile-fix
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
As shown in the figure, this theme component has only one function: adjust the post-voting button to the bottom.
8 лайков
Thank you, this is a great theme-component, it makes my mobile interface look much cleaner.
4 лайка
Thank you for this module, it is very necessary for mobile. However, when I click on the sorting section, its shape is distorted. What can be done about it?
1 лайк
I encountered this problem early in the release, and suffered from no way to reproduce it stably. I tried the method you gave, but failed to reproduce.
1 лайк
Only problem is mobile, desktop version is fine.
You can test it here. Maybe it’s because of a plugin I’m using.
Thank you for your help. I pushed a fix, it should work.
1 лайк
it works great, thanks for the support so fast.
Is there a chance to update this component? Or I suggest adding a mobile view to the plugin itself. On mobile, having the voting on the left makes the screen smaller, it makes more sense to have it on the bottom or top. Thanks.
yeah I was planning to update it today :slightly_smiling_face:
2 лайка
I fixed it temporarily, further fixes will need to wait for discourse-post-voting upgrade.
4 лайка
thank you very much, you are the best :slight_smile:
