I’m migrating my current forum to discourse and do have around 100k topics. Need to do 301 redirect. I do see option for 301 redirection in admin->customize->permalinks. How many max url I can add and how to do bulk import?
thanks!
thanks!
What are you importing from? Most importers will create those permalink redirects. 100K is no problem.
@pfaffman I’m importing question2answer, using [this import](https://gist.github.com/Communiteq (formerly DiscourseHosting)/769eff2014d5482f0ab776de03dc3349). It is creating only few links, and not for all.
You can look at some other scripts to see how they create the permalinks. I am pretty busy right now, but I if you’ve got a budget I can probably help.
