你好,请问有人能帮忙吗?
我从管理后台更新网站后,出现了 500 错误。
随后,我按照此帖子的建议,通过控制台手动更新并重建了应用:Manually update Discourse and Docker image to latest
然而,现在显示无法访问该网站(见下方代码)。
6a2d56837370: Pull complete
933885f686e0: Pull complete
aecf6df6a6bb: Pull complete
33fcdcfe61e2: Pull complete
12726a4d34c8: Pull complete
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Downloaded newer image for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20240825-0027: Pulling from discourse/base
Status: Image is up to date for discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-09-06T21:09:11.924233 #1] INFO -- : Reading from stdin
I, [2024-09-06T21:09:11.948135 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2024-09-06T21:09:11.954933 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2024-09-06T21:09:11.962398 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2024-09-06T21:09:11.970316 #1] INFO -- : File > /root/install_postgres chmod: +x chown:
I, [2024-09-06T21:09:11.977886 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2024-09-06T21:09:11.978953 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.979881 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.980742 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.981529 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.982197 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.982796 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.983436 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.984111 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.989137 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-09-06T21:09:11.990088 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-09-06T21:09:11.990775 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-09-06T21:09:11.991225 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-09-06T21:09:11.991785 #1] INFO -- : > if [ -f /root/install_postgres ]; then
/root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-09-06T21:09:14.358212 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-09-06T21:09:14.358757 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-09-06T21:09:14.368506 #1] INFO -- : File > /usr/local/bin/create_db chmod: +x chown:
I, [2024-09-06T21:09:14.379487 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2024-09-06T21:09:14.383790 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2024-09-06T21:09:14.384318 #1] INFO -- : > sleep 5
2024-09-06 21:09:14.499 UTC [36] LOG: starting PostgreSQL 13.16 (Debian 13.16-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-09-06 21:09:14.501 UTC [36] LOG: listening on IPv4 address "0.0.0.0", port 5432
2024-09-06 21:09:14.501 UTC [36] LOG: listening on IPv6 address "::", port 5432
2024-09-06 21:09:14.507 UTC [36] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-09-06 21:09:14.520 UTC [45] LOG: database system was shut down at 2024-09-06 21:09:02 UTC
2024-09-06 21:09:14.536 UTC [36] LOG: database system is ready to accept connections
I, [2024-09-06T21:09:19.389587 #1] INFO -- :
I, [2024-09-06T21:09:19.390196 #1] INFO -- : > /usr/local/bin/create_db
2024-09-06 21:09:19.488 UTC [55] postgres@postgres ERROR: database "discourse" already exists
2024-09-06 21:09:19.488 UTC [55] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
2024-09-06 21:09:19.562 UTC [58] postgres@discourse ERROR: role "discourse" already exists
2024-09-06 21:09:19.562 UTC [58] postgres@discourse STATEMENT: create user discourse;
NOTICE: extension "hstore" already exists, skipping
NOTICE: extension "pg_trgm" already exists, skipping
NOTICE: extension "vector" already exists, skipping
I, [2024-09-06T21:09:20.325777 #1] INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
UPDATE 0
I, [2024-09-06T21:09:20.326007 #1] INFO -- : > echo postgres installed!
I, [2024-09-06T21:09:20.330120 #1] INFO -- : postgres installed!
I, [2024-09-06T21:09:20.337776 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2024-09-06T21:09:20.344536 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2024-09-06T21:09:20.351809 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2024-09-06T21:09:20.352682 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.353953 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.355364 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-09-06T21:09:20.362199 #1] INFO -- :
I, [2024-09-06T21:09:20.363404 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.364252 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.365811 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.366936 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.368067 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-09-06T21:09:20.369481 #1] INFO -- : > echo redis installed
I, [2024-09-06T21:09:20.372856 #1] INFO -- : redis installed
I, [2024-09-06T21:09:20.373572 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-09-06T21:09:20.379893 #1] INFO -- : logfile ""
I, [2024-09-06T21:09:20.380212 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-09-06T21:09:20.382757 #1] INFO -- : > sleep 10
104:C 06 Sep 2024 21:09:20.400 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
104:C 06 Sep 2024 21:09:20.401 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=104, just started
104:C 06 Sep 2024 21:09:20.401 # Configuration loaded
104:M 06 Sep 2024 21:09:20.402 * monotonic clock: POSIX clock_gettime
104:M 06 Sep 2024 21:09:20.404 * Running mode=standalone, port=6379.
104:M 06 Sep 2024 21:09:20.404 # Server initialized
104:M 06 Sep 2024 21:09:20.405 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
104:M 06 Sep 2024 21:09:20.406 * Loading RDB produced by version 7.0.7
104:M 06 Sep 2024 21:09:20.406 * RDB age 19 seconds
104:M 06 Sep 2024 21:09:20.406 * RDB memory usage when created 16.25 Mb
104:M 06 Sep 2024 21:09:20.464 * Done loading RDB, keys loaded: 3363, keys expired: 2.
104:M 06 Sep 2024 21:09:20.465 * DB loaded from disk: 0.059 seconds
104:M 06 Sep 2024 21:09:20.465 * Ready to accept connections
I, [2024-09-06T21:09:30.386531 #1] INFO -- :
I, [2024-09-06T21:09:30.387145 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-09-06T21:09:30.392326 #1] INFO -- : thpoff is installed!
I, [2024-09-06T21:09:30.392856 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-09-06T21:09:30.507128 #1] INFO -- :
I, [2024-09-06T21:09:30.507386 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-09-06T21:09:30.595075 #1] INFO -- :
I, [2024-09-06T21:09:30.595318 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-09-06T21:09:30.680859 #1] INFO -- :
I, [2024-09-06T21:09:30.681407 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-09-06T21:09:30.684425 #1] INFO -- :
I, [2024-09-06T21:09:30.687845 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2024-09-06T21:09:30.693618 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2024-09-06T21:09:30.699134 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2024-09-06T21:09:30.704312 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2024-09-06T21:09:30.709358 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2024-09-06T21:09:30.713986 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2024-09-06T21:09:30.714205 #1] INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
rm /root/install_postgres
fi
sv start postgres || exit 1
in /etc/service/unicorn/run
I, [2024-09-06T21:09:30.715803 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34680/34680), done.
I, [2024-09-06T21:09:34.830734 #1] INFO -- : HEAD is now at 274e18622 FIX: Video uploads sometimes hang indefinitely (#28523)
I, [2024-09-06T21:09:34.831387 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-09-06T21:09:35.010034 #1] INFO -- :
I, [2024-09-06T21:09:35.010752 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
git remote set-branches --add origin main
git remote set-branches origin tests-passed
git fetch --depth 1 origin tests-passed
else
git fetch --tags --prune-tags --prune --force origin
fi
From https://github.com/discourse/discourse
- [deleted] (none) -> origin/0-a-gjs-ace
- [deleted] (none) -> origin/better-respect-End-key-in-topics
- [deleted] (none) -> origin/category-experts-approved-webhook-event
- [deleted] (none) -> origin/chat-sound-respects-indicator-pref
- [deleted] (none) -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.2
- [deleted] (none) -> origin/dependabot/bundler/sass-embedded-1.77.8
- [deleted] (none) -> origin/dependabot/bundler/sassc-embedded-1.77.8
- [deleted] (none) -> origin/dependabot/npm_and_yarn/ember-cli-deprecation-workflow-3.0.2
- [deleted] (none) -> origin/dependabot/npm_and_yarn/ember/test-helpers-4.0.1
- [deleted] (none) -> origin/dependabot/npm_and_yarn/eslint-9.7.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/sass-1.77.8
- [deleted] (none) -> origin/detect-default-readonly
- [deleted] (none) -> origin/dev/remove-header-widgets
- [deleted] (none) -> origin/feature/site-text-result-selected-lang
- [deleted] (none) -> origin/fix/add-user-to-user-directory-when-activated
- [deleted] (none) -> origin/issue/fix-bookmark-clearing-reminder
- [deleted] (none) -> origin/native-class-components-2
- [deleted] (none) -> origin/native-class-components-3
- [deleted] (none) -> origin/notifications_id_bigint
- [deleted] (none) -> origin/prevent-desktop-notifications-on-mobile
- [deleted] (none) -> origin/ux/admin-plugins-ui-guidelines
274e18622..deb751dfe main -> origin/main
* [new branch] 0-a-testem -> origin/0-a-testem
* [new branch] add-about-config-description -> origin/add-about-config-description
* [new branch] add-tag-group-log -> origin/add-tag-group-log
* [new branch] burning-uppy-mixins -> origin/burning-uppy-mixins
* [new branch] change-text-for-approved-post-webhook-event -> origin/change-text-for-approved-post-webhook-event
7f254be61..488081d93 coco/generic-importer -> origin/coco/generic-importer
* [new branch] dependabot/bundler/omniauth-google-oauth2-1.1.3 -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.3
* [new branch] dependabot/bundler/sass-embedded-1.78.0 -> origin/dependabot/bundler/sass-embedded-1.78.0
* [new branch] dependabot/bundler/sassc-embedded-1.78.0 -> origin/dependabot/bundler/sassc-embedded-1.78.0
* [new branch] dependabot/bundler/test-prof-1.4.2 -> origin/dependabot/bundler/test-prof-1.4.2
* [new branch] dependabot/npm_and_yarn/sass-1.78.0 -> origin/dependabot/npm_and_yarn/sass-1.78.0
* [new branch] dev-faster-tests -> origin/dev-faster-tests
* [new branch] dev-migrate-user-password -> origin/dev-migrate-user-password
* [new branch] dev/add-outlet-to-categories-only -> origin/dev/add-outlet-to-categories-only
* [new branch] dev/bulk-import-chats -> origin/dev/bulk-import-chats
* [new branch] dev/clear-trackers-for-uninstalled-checks -> origin/dev/clear-trackers-for-uninstalled-checks
* [new branch] dev/glimmer-post-menu -> origin/dev/glimmer-post-menu
* [new branch] dev/port-outlet-wrapper-to-stable -> origin/dev/port-outlet-wrapper-to-stable
* [new branch] dev/remove-deprecated-respect-plugin-positional-argument -> origin/dev/remove-deprecated-respect-plugin-positional-argument
* [new branch] drop-old-notification-id-columns -> origin/drop-old-notification-id-columns
* [new branch] ember-native-class -> origin/ember-native-class
* [new branch] feature/add-user-to-topic_tags_changed-event -> origin/feature/add-user-to-topic_tags_changed-event
* [new branch] fontawesome-6-framework -> origin/fontawesome-6-framework
* [new branch] fontawesome-6-upgrade -> origin/fontawesome-6-upgrade
* [new branch] full-width-login-modal-mobile -> origin/full-width-login-modal-mobile
* [new branch] getting-started-fixes -> origin/getting-started-fixes
* [new branch] glint -> origin/glint
* [new branch] issue/hide-historical-bpv-data -> origin/issue/hide-historical-bpv-data
* [new branch] loic-refactor-services -> origin/loic-refactor-services
+ a25ac32bc...97bd38cf4 mt/converter -> origin/mt/converter (forced update)
* [new branch] revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting -> origin/revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting
d3ad2ecda..381cf8548 stable -> origin/stable
274e18622..deb751dfe tests-passed -> origin/tests-passed
* [new branch] ux-1pw-ignore -> origin/ux-1pw-ignore
* [new branch] ux/convert-chat-plugin-ui -> origin/ux/convert-chat-plugin-ui
* [new branch] ux/getting-started-link-fix -> origin/ux/getting-started-link-fix
t [tag update] beta -> beta
t [tag update] latest-release -> latest-release
* [new tag] v3.3.1 -> v3.3.1
* [new tag] v3.4.0.beta1 -> v3.4.0.beta1
I, [2024-09-06T21:09:35.920328 #1] INFO -- :
I, [2024-09-06T21:09:35.920932 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
git pull
else
git -c advice.detachedHead=false checkout tests-passed
fi
Switched to a new branch 'tests-passed'
I, [2024-09-06T21:09:40.293928 #1] INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2024-09-06T21:09:40.294182 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-09-06T21:09:40.307374 #1] INFO -- :
I, [2024-09-06T21:09:40.307665 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-09-06T21:09:40.313403 #1] INFO -- :
I, [2024-09-06T21:09:40.313653 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-09-06T21:09:40.317917 #1] INFO -- :
I, [2024-09-06T21:09:40.318150 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-09-06T21:09:40.323052 #1] INFO -- :
I, [2024-09-06T21:09:40.323368 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-09-06T21:09:40.328389 #1] INFO -- :
I, [2024-09-06T21:09:40.328931 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-09-06T21:09:40.333819 #1] INFO -- :
I, [2024-09-06T21:09:40.334031 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2024-09-06T21:09:40.338273 #1] INFO -- :
I, [2024-09-06T21:09:40.338499 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-09-06T21:09:40.344500 #1] INFO -- :
I, [2024-09-06T21:09:40.345175 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-09-06T21:09:40.351488 #1] INFO -- :
I, [2024-09-06T21:09:40.351715 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2024-09-06T21:09:40.358369 #1] INFO -- :
I, [2024-09-06T21:09:40.358654 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-09-06T21:09:40.365209 #1] INFO -- :
I, [2024-09-06T21:09:40.365507 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2024-09-06T21:09:40.373210 #1] INFO -- :
I, [2024-09-06T21:09:40.373502 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-09-06T21:09:40.379740 #1] INFO -- :
I, [2024-09-06T21:09:40.379967 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-09-06T21:09:40.394263 #1] INFO -- :
I, [2024-09-06T21:09:40.394509 #1] INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-09-06T21:09:40.398136 #1] INFO -- :
I, [2024-09-06T21:09:40.398726 #1] INFO -- : Replacing # redis with if [ ! -d /shared/redis_data ]; then
fi
sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-09-06T21:09:40.401363 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-09-06T21:09:41.375371 #1] INFO -- :
I, [2024-09-06T21:09:41.375948 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-ai.git
Cloning into 'discourse-ai'...
I, [2024-09-06T21:09:43.378168 #1] INFO -- :
I, [2024-09-06T21:09:43.378418 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-cakeday.git
Cloning into 'discourse-cakeday'...
I, [2024-09-06T21:09:44.053579 #1] INFO -- :
I, [2024-09-06T21:09:44.053738 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-chat-integration.git
Cloning into 'discourse-chat-integration'...
I, [2024-09-06T21:09:44.792206 #1] INFO -- :
I, [2024-09-06T21:09:44.792555 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-checklist.git
Cloning into 'discourse-checklist'...
I, [2024-09-06T21:09:45.423200 #1] INFO -- :
I, [2024-09-06T21:09:45.423548 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-docs.git
Cloning into 'discourse-docs'...
I, [2024-09-06T21:09:46.034856 #1] INFO -- :
I, [2024-09-06T21:09:46.035347 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-footnote.git
Cloning into 'discourse-footnote'...
I, [2024-09-06T21:09:46.600352 #1] INFO -- :
I, [2024-09-06T21:09:46.600812 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-github.git
Cloning into 'discourse-github'...
I, [2024-09-06T21:09:47.223540 #1] INFO -- :
I, [2024-09-06T21:09:47.224027 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-graphviz.git
Cloning into 'discourse-graphviz'...
I, [2024-09-06T21:09:47.957830 #1] INFO -- :
I, [2024-09-06T21:09:47.958247 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-math.git
Cloning into 'discourse-math'...
I, [2024-09-06T21:09:49.398988 #1] INFO -- :
I, [2024-09-06T21:09:49.399439 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-patreon.git
Cloning into 'discourse-patreon'...
I, [2024-09-06T21:09:50.128576 #1] INFO -- :
I, [2024-09-06T21:09:50.129164 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions.git
Cloning into 'discourse-reactions'...
I, [2024-09-06T21:09:50.837034 #1] INFO -- :
I, [2024-09-06T21:09:50.838015 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2024-09-06T21:09:51.505606 #1] INFO -- :
I, [2024-09-06T21:09:51.505770 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-spoiler-alert.git
Cloning into 'discourse-spoiler-alert'...
I, [2024-09-06T21:09:52.085695 #1] INFO -- :
I, [2024-09-06T21:09:52.085899 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-subscriptions.git
Cloning into 'discourse-subscriptions'...
I, [2024-09-06T21:09:52.965401 #1] INFO -- :
I, [2024-09-06T21:09:52.965884 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-yearly-review.git
Cloning into 'discourse-yearly-review'...
I, [2024-09-06T21:09:53.543561 #1] INFO -- :
I, [2024-09-06T21:09:53.543968 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-adplugin.git
Cloning into 'discourse-adplugin'...
I, [2024-09-06T21:09:54.268697 #1] INFO -- :
I, [2024-09-06T21:09:54.269203 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-akismet.git
Cloning into 'discourse-akismet'...
I, [2024-09-06T21:09:54.896822 #1] INFO -- :
I, [2024-09-06T21:09:54.897057 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-assign.git
Cloning into 'discourse-assign'...
I, [2024-09-06T21:09:55.731145 #1] INFO -- :
I, [2024-09-06T21:09:55.731358 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-automation.git
Cloning into 'discourse-automation'...
I, [2024-09-06T21:09:56.428511 #1] INFO -- :
I, [2024-09-06T21:09:56.428721 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-calendar.git
Cloning into 'discourse-calendar'...
I, [2024-09-06T21:09:57.419699 #1] INFO -- :
I, [2024-09-06T21:09:57.419945 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-data-explorer.git
Cloning into 'discourse-data-explorer'...
I, [2024-09-06T21:09:58.127555 #1] INFO -- :
I, [2024-09-06T21:09:58.127808 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-gamification.git
Cloning into 'discourse-gamification'...
I, [2024-09-06T21:09:58.795750 #1] INFO -- :
I, [2024-09-06T21:09:58.795963 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-policy.git
Cloning into 'discourse-policy'...
I, [2024-09-06T21:09:59.406532 #1] INFO -- :
I, [2024-09-06T21:09:59.406741 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-templates.git
Cloning into 'discourse-templates'...
I, [2024-09-06T21:10:00.118127 #1] INFO -- :
I, [2024-09-06T21:10:00.118374 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-topic-voting.git
Cloning into 'discourse-topic-voting'...
I, [2024-09-06T21:10:00.793006 #1] INFO -- :
I, [2024-09-06T21:10:00.793758 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-user-notes.git
Cloning into 'discourse-user-notes'...
I, [2024-09-06T21:10:01.363811 #1] INFO -- :
I, [2024-09-06T21:10:01.364096 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-zendesk-plugin.git
Cloning into 'discourse-zendesk-plugin'...
I, [2024-09-06T21:10:02.106845 #1] INFO -- :
I, [2024-09-06T21:10:02.107632 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-09-06T21:10:02.119479 #1] INFO -- :
I, [2024-09-06T21:10:02.120380 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-09-06T21:10:02.126777 #1] INFO -- :
I, [2024-09-06T21:10:02.127871 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2024-09-06T21:10:02.131941 #1] INFO -- :
I, [2024-09-06T21:10:02.133199 #1] INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-09-06T21:10:02.134392 #1] INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-09-06T21:10:02.134854 #1] INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-09-06T21:10:02.138746 #1] INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-09-06T21:10:02.139920 #1] INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-09-06T21:10:02.141496 #1] INFO -- : > echo "done configuring web"
I, [2024-09-06T21:10:02.148744 #1] INFO -- : done configuring web
I, [2024-09-06T21:10:02.149314 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-09-06T21:10:02.713680 #1] INFO -- :
I, [2024-09-06T21:10:02.713870 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-09-06T21:10:04.665686 #1] INFO -- :
I, [2024-09-06T21:10:04.666337 #1] INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
rm -rf app/assets/javascripts/node_modules
fi
I, [2024-09-06T21:10:04.670072 #1] INFO -- :
I, [2024-09-06T21:10:04.670248 #1] INFO -- : > cd /var/www/discourse && if [ -f yarn.lock ]; then
su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
else
su discourse -c 'CI=1 pnpm install --frozen-lockfile'
fi
I, [2024-09-06T21:10:40.806033 #1] INFO -- : 检测到由 yarn 管理的 node_modules。正在执行一次性清理...
清理完成
范围:所有 19 个工作区项目
锁文件已是最新,跳过解析步骤
进度:已解析 1,已重用 0,已下载 0,已添加 0
包:+1760
进度:已解析 1760,已重用 0,已下载 0,已添加 0
进度:已解析 1760,已重用 0,已下载 56,已添加 48
进度:已解析 1760,已重用 0,已下载 188,已添加 172
进度:已解析 1760,已重用 0,已下载 308,已添加 295
进度:已解析 1760,已重用 0,已下载 372,已添加 363
进度:已解析 1760,已重用 0,已下载 377,已添加 366
进度:已解析 1760,已重用 0,已下载 462,已添加 450
进度:已解析 1760,已重用 0,已下载 547,已添加 536
进度:已解析 1760,已重用 0,已下载 606,已添加 595
进度:已解析 1760,已重用 0,已下载 678,已添加 667
进度:已解析 1760,已重用 0,已下载 838,已添加 829
进度:已解析 1760,已重用 0,已下载 931,已添加 916
进度:已解析 1760,已重用 0,已下载 1057,已添加 1048
进度:已解析 1760,已重用 0,已下载 1147,已添加 1136
进度:已解析 1760,已重用 0,已下载 1165,已添加 1152
进度:已解析 1760,已重用 0,已下载 1180,已添加 1164
进度:已解析 1760,已重用 0,已下载 1219,已添加 1210
进度:已解析 1760,已重用 0,已下载 1239,已添加 1225
进度:已解析 1760,已重用 0,已下载 1389,已添加 1380
进度:已解析 1760,已重用 0,已下载 1438,已添加 1433
包已从内容寻址存储硬链接到虚拟存储。
内容寻址存储位于:/home/discourse/.local/share/pnpm/store/v3
虚拟存储位于: node_modules/.pnpm
进度:已解析 1760,已重用 0,已下载 1464,已添加 1452
进度:已解析 1760,已重用 0,已下载 1533,已添加 1519
进度:已解析 1760,已重用 0,已下载 1558,已添加 1546
进度:已解析 1760,已重用 0,已下载 1651,已添加 1637
进度:已解析 1760,已重用 0,已下载 1725,已添加 1721
进度:已解析 1760,已重用 0,已下载 1759,已添加 1759
进度:已解析 1760,已重用 0,已下载 1760,已添加 1759
进度:已解析 1760,已重用 0,已下载 1760,已添加 1760,完成
.../@fortawesome/fontawesome-free postinstall$ node attribution.js
.../core-js@3.33.0/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../core-js@2.6.12/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../node_modules/@swc/core postinstall$ node postinstall.js
.../esbuild@0.23.1/node_modules/esbuild postinstall$ node install.js
.../core-js@2.6.12/node_modules/core-js postinstall: 完成
.../@fortawesome/fontawesome-free postinstall: Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com
.../@fortawesome/fontawesome-free postinstall: 许可证 - https://fontawesome.com/license/free (图标: CC BY 4.0, 字体: SIL OFL 1.1, 代码: MIT 许可证)
.../@fortawesome/fontawesome-free postinstall: 完成
.../core-js@3.33.0/node_modules/core-js postinstall: 完成
.../esbuild@0.23.1/node_modules/esbuild postinstall: 完成
.../node_modules/@swc/core postinstall: 完成
.../node_modules/lefthook postinstall$ node postinstall.js
.../node_modules/lefthook postinstall: 完成
devDependencies:
+ @babel/plugin-proposal-decorators 7.24.7
+ @discourse/lint-configs 1.3.9
+ @discourse/moment-timezone-names-translations 1.0.0
+ @fortawesome/fontawesome-free 5.15.4
+ @glint/core 1.4.1-unstable.ff9ea6c
+ @glint/environment-ember-loose 1.4.1-unstable.ff9ea6c
+ @glint/environment-ember-template-imports 1.4.1-unstable.ff9ea6c
+ @glint/template 1.4.1-unstable.ff9ea6c
+ @mixer/parallel-prettier 2.0.3
+ @swc/core 1.7.23
+ chart.js 3.5.1
+ chartjs-plugin-datalabels 2.2.0
+ chrome-launcher 1.1.2
+ chrome-remote-interface 0.33.2
+ concurrently 8.2.2
+ ember-template-lint 6.0.0
+ esbuild 0.23.1
+ eslint 8.57.0
+ jsdoc 4.0.3
+ lefthook 1.7.15
+ licensee 10.0.0
+ lint-to-the-future 2.0.0
+ lint-to-the-future-ember-template 1.2.0
+ lint-to-the-future-eslint 2.0.1
+ magnific-popup 1.1.0
+ moment 2.30.1
+ moment-timezone 0.5.45
+ pikaday 1.8.2
+ prettier 2.8.8
+ puppeteer-core 23.3.0
+ squoosh 2.0.0
+ terser 5.31.6
+ typescript 5.5.4
耗时 35.8 秒
I, [2024-09-06T21:10:40.806440 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --jobs $(($(nproc) - 1)) --retry 3'
I, [2024-09-06T21:10:48.675147 #1] INFO -- : 正在从 https://rubygems.org/ 获取 gem 元数据........
正在获取 net-imap 0.4.16
正在安装 net-imap 0.4.16
正在获取 css_parser 1.19.0
正在安装 css_parser 1.19.0
正在获取 uri 0.13.1
正在安装 uri 0.13.1
正在获取 faraday-net_http 3.3.0
正在安装 faraday-net_http 3.3.0
正在获取 logger 1.6.1
正在安装 logger 1.6.1
正在获取 faraday 2.11.0
正在安装 faraday 2.11.0
正在获取 google-protobuf 4.28.0 (x86_64-linux)
正在安装 google-protobuf 4.28.0 (x86_64-linux)
正在获取 reline 0.5.10
正在安装 reline 0.5.10
正在获取 highline 3.1.1
正在安装 highline 3.1.1
正在获取 thor 1.3.2
正在安装 thor 1.3.2
正在获取 zeitwerk 2.6.18
正在安装 zeitwerk 2.6.18
正在获取 omniauth-oauth 1.2.1
正在安装 omniauth-oauth 1.2.1
正在获取 rexml 3.3.7
正在安装 rexml 3.3.7
正在获取 ruby-readability 0.7.2
正在安装 ruby-readability 0.7.2
正在获取 tzinfo-data 1.2024.2
正在安装 tzinfo-data 1.2024.2
捆绑完成!140 个 Gemfile 依赖项,现已安装 183 个 gems。
未安装 'test' 和 'development' 组中的 gems。
捆绑的 gems 已安装到 `./vendor/bundle`
1 个您直接依赖的 gem 正在寻求资助。
运行 `bundle fund` 以获取详细信息
I, [2024-09-06T21:10:48.675878 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-09-06T21:10:53.593625 #1] INFO -- : discourse-adplugin 已是最新的兼容版本
discourse-ai 已是最新的兼容版本
discourse-akismet 已是最新的兼容版本
discourse-assign 已是最新的兼容版本
discourse-automation 已是最新的兼容版本
discourse-cakeday 已是最新的兼容版本
discourse-calendar 已是最新的兼容版本
discourse-chat-integration 已是最新的兼容版本
discourse-checklist 已是最新的兼容版本
discourse-data-explorer 已是最新的兼容版本
discourse-docs 已是最新的兼容版本
discourse-footnote 已是最新的兼容版本
discourse-gamification 已是最新的兼容版本
discourse-github 已是最新的兼容版本
discourse-graphviz 已是最新的兼容版本
discourse-math 已是最新的兼容版本
discourse-patreon 已是最新的兼容版本
discourse-policy 已是最新的兼容版本
discourse-reactions 已是最新的兼容版本
discourse-solved 已是最新的兼容版本
discourse-spoiler-alert 已是最新的兼容版本
discourse-subscriptions 已是最新的兼容版本
discourse-templates 已是最新的兼容版本
discourse-topic-voting 已是最新的兼容版本
discourse-user-notes 已是最新的兼容版本
discourse-yearly-review 已是最新的兼容版本
discourse-zendesk-plugin 已是最新的兼容版本
docker_manager 已是最新的兼容版本
I, [2024-09-06T21:10:53.593955 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-09-06T21:10:53.596275 #1] INFO -- : > sleep 10
860:C 06 Sep 2024 21:10:53.607 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
860:C 06 Sep 2024 21:10:53.607 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=860, just started
860:C 06 Sep 2024 21:10:53.607 # Configuration loaded
860:M 06 Sep 2024 21:10:53.608 * monotonic clock: POSIX clock_gettime
860:M 06 Sep 2024 21:10:53.609 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
860:M 06 Sep 2024 21:10:53.609 # Failed listening on port 6379 (TCP), aborting.
I, [2024-09-06T21:11:03.599469 #1] INFO -- :
I, [2024-09-06T21:11:03.600184 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2024-09-06 21:11:19.267 UTC [988] discourse@discourse ERROR: relation "user_required_fields_versions" already exists
2024-09-06 21:11:19.267 UTC [988] discourse@discourse STATEMENT: CREATE TABLE "user_required_fields_versions" ("id" bigserial primary key, "created_at" timestamp(6) NOT NULL, "updated_at" timestamp(6) NOT NULL)
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled: (StandardError)
PG::DuplicateTable: ERROR: relation "user_required_fields_versions" already exists
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in `block (2 levels) in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:1027:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:999:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in `block in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:1142:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:53:in `raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:521:in `internal_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:131:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/query_cache.rb:25:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:47:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/schema_statements.rb:304:in `create_table'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration/default_strategy.rb:10:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1047:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1017:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1017:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1036:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:566:in `create_table'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration/compatibility.rb:115:in `create_table'
/var/www/discourse/db/migrate/20240531053226_create_user_required_fields_version.rb:5:in `change'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:986:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:970:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:969:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:227:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:968:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1178:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1529:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1580:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1528:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1503:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1503:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1448:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1600:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1448:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1274:in `up'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/migration.rb:1249:in `migrate'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4/lib/active_record/tasks/database_tasks.rb:251:in `migrate'
/var/www/discourse/lib/tasks/db.rake:259:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateTable: ERROR: relation "user_required_fields_versions" already exists (ActiveRecord::StatementInvalid)
Caused by:
PG::DuplicateTable: ERROR: relation "user_required_fields_versions" already exists (PG::DuplicateTable)
Tasks: TOP => db:migrate
I, [2024-09-06T21:11:19.326623 #1] INFO -- : gem install tokenizers -v 0.4.4 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed tokenizers-0.4.4-x86_64-linux
1 gem installed
gem install tiktoken_ruby -v 0.0.9 -i /var/www/discourse/plugins/discourse-ai/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed tiktoken_ruby-0.0.9-x86_64-linux
1 gem installed
gem install sawyer -v 0.9.2 -i /var/www/discourse/plugins/discourse-github/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed sawyer-0.9.2
1 gem installed
gem install octokit -v 5.6.1 -i /var/www/discourse/plugins/discourse-github/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed octokit-5.6.1
1 gem installed
gem install stripe -v 11.1.0 -i /var/www/discourse/plugins/discourse-subscriptions/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed stripe-11.1.0
1 gem installed
gem install inflection -v 1.0.0 -i /var/www/discourse/plugins/discourse-zendesk-plugin/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed inflection-1.0.0
1 gem installed
gem install multipart-post -v 2.2.3 -i /var/www/discourse/plugins/discourse-zendesk-plugin/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed multipart-post-2.2.3
1 gem installed
gem install faraday-multipart -v 1.0.4 -i /var/www/discourse/plugins/discourse-zendesk-plugin/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed faraday-multipart-1.0.4
1 gem installed
gem install zendesk_api -v 1.38.0.rc1 -i /var/www/discourse/plugins/discourse-zendesk-plugin/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed zendesk_api-1.38.0.rc1
1 gem installed
== 20240416105733 AddRankToPollVotes: migrating ===============================
-- add_column(:poll_votes, :rank, :integer, {:null=>false, :default=>0})
-> 0.0075s
== 20240416105733 AddRankToPollVotes: migrated (0.0127s) ======================
== 20240528132059 AddCompanionUserToLlmModel: migrating =======================
-- add_column(:llm_models, :user_id, :integer)
-> 0.0020s
-- add_column(:llm_models, :enabled_chat_bot, :boolean, {:null=>false, :default=>false})
-> 0.0016s
== 20240528132059 AddCompanionUserToLlmModel: migrated (0.0044s) ==============
== 20240528144216 SeedOpenAiModels: migrating =================================
== 20240528144216 SeedOpenAiModels: migrated (0.0013s) ========================
== 20240531053226 CreateUserRequiredFieldsVersion: migrating ==================
-- create_table(:user_required_fields_versions)
I, [2024-09-06T21:11:19.327304 #1] INFO -- : Terminating async processes
I, [2024-09-06T21:11:19.327364 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36
I, [2024-09-06T21:11:19.327410 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 104
2024-09-06 21:11:19.327 UTC [36] LOG: received fast shutdown request
104:signal-handler (1725657079) Received SIGTERM scheduling shutdown...
2024-09-06 21:11:19.332 UTC [36] LOG: aborting any active transactions
2024-09-06 21:11:19.335 UTC [36] LOG: background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-09-06 21:11:19.341 UTC [46] LOG: shutting down
104:M 06 Sep 2024 21:11:19.372 # User requested shutdown...
104:M 06 Sep 2024 21:11:19.373 * Saving the final RDB snapshot before exiting.
2024-09-06 21:11:19.379 UTC [36] LOG: database system is shut down
104:M 06 Sep 2024 21:11:19.464 * DB saved on disk
104:M 06 Sep 2024 21:11:19.464 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 864 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
11de27f0f4b363f5d4cce624f33cf6cfa9955eee9287915186f907810b3d19f5
root@hub:/var/discourse# ^C
我不是开发人员,平时帮我的人接下来一周都联系不上,所以我真的不知道还能尝试什么了。
如果能得到任何帮助,我将不胜感激
