Сломанная верстка для входа администратора
After last update to 3.4.0.beta2-dev version, when one of our Admin users login he got a broken layout as on screenshot.
Master admin user layout looks just fine.
Any idea ?
Have you tried safe mode to rule out and theme / plugin / theme component issues?
2 лайка
Any errors in the browser console?
Edit: Apparently yes
2 лайка
@ondrej the safe-mode doesn’t help and leads to the same issue.
1 лайк
Hi
Are you using Cloudflare? Cloudflare’s auto-minify will cause this.
4 лайка
Thank you guys, it is solved now…
Indeed was issue with Cloudflare, even Rocket Loader was off, Auto Minify was on, and after disabling and purge cache, layout back to normal!
3 лайка
