No se puede enviar cierto mensaje en el chat
For some reason on two different non-Meta forums, this exact message cannot be sent in chat:
firepup650@firepi:~/projects/python/bitbot $ sudo journalctl -fu h-bitbot
Sep 16 18:21:33 firepi systemd[1]: Starting h-bitbot.service - 9pfs's bitbot...
Sep 16 18:21:33 firepi systemd[1]: Started h-bitbot.service - 9pfs's bitbot.
Sep 16 18:21:34 firepi systemd[1]: h-bitbot.service: Main process exited, code=exited, status=1/FAILURE
Sep 16 18:21:34 firepi systemd[1]: h-bitbot.service: Failed with result 'exit-code'.
Sep 16 18:21:34 firepi systemd[1]: h-bitbot.service: Consumed 1.157s CPU time, no IP traffic.
Sep 16 18:21:39 firepi systemd[1]: h-bitbot.service: Scheduled restart job, restart counter is at 84.
Sep 16 18:21:39 firepi systemd[1]: Stopped h-bitbot.service - 9pfs's bitbot.
Sep 16 18:21:39 firepi systemd[1]: h-bitbot.service: Consumed 1.157s CPU time, no IP traffic.
Sep 16 18:21:39 firepi systemd[1]: Starting h-bitbot.service - 9pfs's bitbot...
Sep 16 18:21:39 firepi systemd[1]: Started h-bitbot.service - 9pfs's bitbot.
Sep 16 18:21:42 firepi systemd[1]: h-bitbot.service: Main process exited, code=exited, status=1/FAILURE
Removing either the ??? from the first line, or the last line of that log snippet causes it to send properly.
For some reason, I cannot reproduce this on Meta however.
It causes the error both at https://forum.obl.ong/ and https://amcforum.wiki/, it causes a 500 error, logs from AMC are:
Kinda long log
Message (28 copies reported)
Failed to handle exception in exception app middleware : ActiveRecord::ValueTooLong : PG::StringDataRightTruncation: ERROR:  value too long for type character varying(1000)
Backtrace
rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:72:in `exec_params'
activerecord-7.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:894:in `block (2 levels) in exec_no_cache'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:1027:in `block in with_raw_connection'
activesupport-7.1.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:999:in `with_raw_connection'
activerecord-7.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:893:in `block in exec_no_cache'
activesupport-7.1.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract_adapter.rb:1142:in `log'
activerecord-7.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:892:in `exec_no_cache'
activerecord-7.1.4/lib/active_record/connection_adapters/postgresql_adapter.rb:872:in `execute_and_clear'
activerecord-7.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:64:in `internal_exec_query'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:153:in `exec_insert'
activerecord-7.1.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:83:in `exec_insert'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:191:in `insert'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/query_cache.rb:25:in `insert'
activerecord-7.1.4/lib/active_record/persistence.rb:588:in `_insert_record'
activerecord-7.1.4/lib/active_record/persistence.rb:1252:in `_create_record'
activerecord-7.1.4/lib/active_record/counter_cache.rb:188:in `_create_record'
activerecord-7.1.4/lib/active_record/locking/optimistic.rb:84:in `_create_record'
activerecord-7.1.4/lib/active_record/encryption/encryptable_record.rb:184:in `_create_record'
activerecord-7.1.4/lib/active_record/attribute_methods/dirty.rb:240:in `_create_record'
activerecord-7.1.4/lib/active_record/callbacks.rb:445:in `block in _create_record'
activesupport-7.1.4/lib/active_support/callbacks.rb:110:in `run_callbacks'
activesupport-7.1.4/lib/active_support/callbacks.rb:952:in `_run_create_callbacks'
activerecord-7.1.4/lib/active_record/callbacks.rb:445:in `_create_record'
activerecord-7.1.4/lib/active_record/timestamp.rb:116:in `_create_record'
activerecord-7.1.4/lib/active_record/persistence.rb:1221:in `create_or_update'
activerecord-7.1.4/lib/active_record/callbacks.rb:441:in `block in create_or_update'
activesupport-7.1.4/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
activerecord-7.1.4/lib/active_record/autosave_association.rb:375:in `around_save_collection_association'
activesupport-7.1.4/lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport-7.1.4/lib/active_support/callbacks.rb:141:in `run_callbacks'
activesupport-7.1.4/lib/active_support/callbacks.rb:952:in `_run_save_callbacks'
activerecord-7.1.4/lib/active_record/callbacks.rb:441:in `create_or_update'
activerecord-7.1.4/lib/active_record/timestamp.rb:127:in `create_or_update'
activerecord-7.1.4/lib/active_record/persistence.rb:751:in `save!'
activerecord-7.1.4/lib/active_record/validations.rb:55:in `save!'
activerecord-7.1.4/lib/active_record/transactions.rb:313:in `block in save!'
activerecord-7.1.4/lib/active_record/transactions.rb:365:in `block in with_transaction_returning_status'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:342:in `transaction'
activerecord-7.1.4/lib/active_record/transactions.rb:361:in `with_transaction_returning_status'
activerecord-7.1.4/lib/active_record/transactions.rb:313:in `save!'
activerecord-7.1.4/lib/active_record/suppressor.rb:56:in `save!'
/var/www/discourse/plugins/chat/app/services/chat/create_message.rb:159:in `save_message'
/var/www/discourse/app/services/service/base.rb:117:in `instance_exec'
/var/www/discourse/app/services/service/base.rb:117:in `call'
/var/www/discourse/app/services/service/base.rb:207:in `block (2 levels) in call'
/var/www/discourse/app/services/service/base.rb:207:in `each'
/var/www/discourse/app/services/service/base.rb:207:in `block in call'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
activerecord-7.1.4/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
activerecord-7.1.4/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/app/services/service/base.rb:207:in `call'
/var/www/discourse/app/services/service/base.rb:374:in `block in run!'
/var/www/discourse/app/services/service/base.rb:374:in `each'
/var/www/discourse/app/services/service/base.rb:374:in `run!'
/var/www/discourse/app/services/service/base.rb:367:in `run'
<internal:kernel>:90:in `tap'
/var/www/discourse/app/services/service/base.rb:234:in `call'
/var/www/discourse/lib/service_runner.rb:141:in `block in setup_and_run_service'
/var/www/discourse/lib/service_runner.rb:138:in `instance_eval'
/var/www/discourse/lib/service_runner.rb:138:in `setup_and_run_service'
/var/www/discourse/lib/service_runner.rb:121:in `call'
/var/www/discourse/lib/service_runner.rb:115:in `call'
/var/www/discourse/app/services/service/base.rb:235:in `call'
/var/www/discourse/plugins/chat/app/controllers/chat/api/channel_messages_controller.rb:71:in `create'
actionpack-7.1.4/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.1.4/lib/abstract_controller/base.rb:224:in `process_action'
actionpack-7.1.4/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.1.4/lib/abstract_controller/callbacks.rb:259:in `block in process_action'
/var/www/discourse/app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n-1.14.5/lib/i18n.rb:351:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:424:in `with_resolved_locale'
actionpack-7.1.4/lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack-7.1.4/lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack-7.1.4/lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport-7.1.4/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.1.4/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.1.4/lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack-7.1.4/lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord-7.1.4/lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack-7.1.4/lib/abstract_controller/base.rb:160:in `process'
actionview-7.1.4/lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack-7.1.4/lib/action_controller/metal.rb:227:in `dispatch'
actionpack-7.1.4/lib/action_controller/metal.rb:309:in `dispatch'
actionpack-7.1.4/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.1.4/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.1.4/lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack-7.1.4/lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack-7.1.4/lib/action_dispatch/journey/router.rb:124:in `each'
actionpack-7.1.4/lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack-7.1.4/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.1.4/lib/action_dispatch/routing/route_set.rb:882:in `call'
railties-7.1.4/lib/rails/engine.rb:536:in `call'
railties-7.1.4/lib/rails/railtie.rb:226:in `public_send'
railties-7.1.4/lib/rails/railtie.rb:226:in `method_missing'
actionpack-7.1.4/lib/action_dispatch/routing/mapper.rb:31:in `block in <class:Constraints>'
actionpack-7.1.4/lib/action_dispatch/routing/mapper.rb:60:in `serve'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.9/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.9/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.9/lib/rack/head.rb:12:in `call'
actionpack-7.1.4/lib/action_dispatch/http/permissions_policy.rb:36:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:393:in `call'
2 Me gusta
Está intentando insertar en la tabla de chat y la columna está limitada a 1000 caracteres.
Quizás intente esto en el explorador de datos:
SELECT
    column_name,
    data_type,
    character_maximum_length
FROM
    information_schema.columns
WHERE
    table_name = 'chat_messages'
    AND column_name IN ('cooked', 'message')
¿Hay alguna longitud máxima definida de alguna manera en su esquema?
2 Me gusta
El value too long for type character varying(1000) me indica que está relacionado con el extracto. Esto es sorprendente porque técnicamente limitamos los extractos a 150 caracteres, por lo que este caso nunca debería ocurrir. Al principio pensé que era un error en nuestro generador de extractos, pero al mirar el código del extracto en el chat vi esto:
def build_excerpt
  # solo muestra la URL si el mensaje completo es una URL, porque no podemos extraer oneboxes
  return message if UrlHelper.relaxed_parse(message).is_a?(URI)
  # los mensajes solo de carga se representan mejor como el nombre del archivo
  return uploads.first.original_filename if cooked.blank? && uploads.present?
  # esto puede devolver un valor en blanco para algunas cosas complejas como citas, eso es aceptable
  PrettyText.excerpt(cooked, EXCERPT_LENGTH, strip_links: true, keep_mentions: true)
Una depuración rápida ha demostrado que en realidad nunca llegamos a PrettyText.excerpt y nos detenemos en el primer return. Aparentemente, los ??? hacen que nuestro código piense que esto es una URL:
[1] pry(main)> UrlHelper.relaxed_parse("???\ntest").is_a?(URI)
=> true
3 Me gusta
Hemos identificado la solución, pero llevará tiempo implementarla en la rama principal.
2 Me gusta
La corrección se ha fusionado: SECURITY: Correctly parse URLs in chat excerpts · discourse/discourse@1da97de · GitHub
4 Me gusta
Este tema se cerró automáticamente 3 días después de la última respuesta. Ya no se permiten nuevas respuestas.
