How to add subcategory
In a discussion titled “How to add subcategory” under the Support category, Sidi_Codet asks how to contribute a “Blog” section similar to a visual example they shared. merefield explains that users with sufficient privileges can create a new category via /categories, then set a “Parent Category” in its settings to make it a subcategory. They also note that categories can be added to the Top Menu under “Basic Setup”. Sidi_Codet clarifies their goal: to have the subcategory banner displayed within the parent category, as shown in their reference image. Moin provides the solution — enabling “show subcategory list above topics in this category” in the parent category’s settings. Sidi_Codet gratefully thanks Moin, jokingly awarding them a “CEO Position” for the helpful tip.
Could Someone please let me know how I can contribute something like this to our community?
I mean the “Blog” Part
On the Categories page (/categories), if you have sufficient privileges you can find and hit the + New Category button, which will allow you to create a new Category. On the settings of that Category, you can find “Parent Category” … set that to the desired parent and once you hit the New Category button you will create a Subcategory to that Parent Category.
btw, you can also add Categories to the Top Menu in this setting under “Basic Setup”:
Thank you, but the main point I’m trying to make is that I want the subcategory banner to be displayed within the parent category, similar to the reference I provided earlier.
In the settings of the parent category you can choose “show subcategory list above topics in this category”
@Moin, you deserve a CEO Position, Thank you very much.
