La instalación del desarrollo falla al ejecutar bin/rails db:migrate
Basically, I am trying to do a dev install on my Pi, following this guide. I ran bin/rails db:create, which worked fine. Then when trying to run bin/rails db:migrate, it ends by saying something about oxipng binary file not working? It tells me to either put a proper binary file or use some command (I cannot remember it exactly, I’ll tell you why).
But, um, my VNC lagged out when doing this (I think the processing was too much? I did a bin/ember-cli -u even with this oxipng thing. Anyway, I then clicked on something and all I say was a grey screen. I closed the VNC session and tried to reconnect. Nothing happened for a long time. I disconnected and reconnected my Pi (yes, force shut down. Very bad.). As such, I don’t know that oxipng message much.
Tried again to run bin/rails db:migrate, and this was the error (same error as well when running RAILS_ENV=test bin/rails db:create db:migrate):
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrating ===========
-- execute("DELETE FROM web_hook_event_types WHERE (name, id) IN (('category_experts_approved', 1901), ('category_experts_unapproved', 1902))")
   -> 0.0011s
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrated (0.0029s) ==
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:16:in `expire_cache'
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:42:in `reload_types'
/home/natedhaliwal/discourse-f/app/models/flag.rb:37:in `reset_flag_settings!'
(eval):78:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `eval'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:58:in `block in open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:57:in `open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:36:in `block in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activesupport-7.1.4.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/transactions.rb:212:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:35:in `run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:26:in `block in run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/discourse-seed-fu.rb:29:in `seed'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:264:in `block (2 levels) in <main>'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:53:in `block in synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:49:in `synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:34:in `synchronize'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:234:in `block in <main>'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block (2 levels) in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:44:in `block in with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/rake_module.rb:59:in `with_application'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:41:in `with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:20:in `perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:156:in `invoke_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:73:in `block in invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:149:in `with_argv'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:69:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands.rb:18:in `<main>'
<internal:/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
bin/rails aborted!
ActiveRecord::RecordNotFound: Couldn't find Upload with 'id'=-6 (ActiveRecord::RecordNotFound)
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:119:in `resolve_original'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `each'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
Tasks: TOP => db:migrate
When running it with --trace, I get:
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails db:create db:migrate --trace
** Invoke db:create (first_time)
** Invoke db:force_skip_persist (first_time)
** Execute db:force_skip_persist
** Invoke db:load_config (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute db:load_config
** Execute db:create
Database 'discourse_test' already exists
Database 'discourse_test_multisite' already exists
** Invoke db:migrate (first_time)
** Invoke set_locale (first_time)
** Execute set_locale
** Invoke assets:precompile:theme_transpiler (first_time)
** Execute assets:precompile:theme_transpiler
** Execute db:migrate
bin/rails aborted!
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
Any thoughts on what I should do?
Hmm, la respuesta es probablemente esta línea:
ActiveRecord::RecordNotFound: No se pudo encontrar Upload con 'id'=-6 (ActiveRecord::RecordNotFound)
¿Eliminaste un icono recientemente?
¿Un icono? ¿Te refieres a un icono de imagen (por ejemplo, FA)?
Abre la consola de Rails e inspecciona la tabla uploads para verificar que falta el ID = -6:
RAILS_ENV=test bin/rails console
Upload.find_by(id: -6)
El error indica que el registro con ID = -6 ha sido eliminado. Deberás actualizar los datos de semilla o los fixtures correspondientemente en tu entorno de prueba.
Hola, yo también estoy teniendo este problema, pero me quedé atascado antes de que terminara la instalación, así que no tengo bin/rails… ¿cómo puedo solucionarlo? Y no puedo entrar a la aplicación (./launcher enter app) la carpeta bin está vacía.
@woozievert, por favor comparte el rastreo detallado de tu error
mismo error:
FALLÓ
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' falló con retorno #<Process::Status: pid 1962 exit 1>
Ubicación del fallo: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec falló con los parámetros {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
falló el arranque con código de salida 1
**FALLÓ EL ARRANQUE** por favor desplázate hacia arriba y busca mensajes de error anteriores, puede haber más de uno.
./discourse-doctor puede ayudar a diagnosticar el problema.
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
/var/www/discourse/lib/site_icon_manager.rb:119:in `resolve_original'
/var/www/discourse/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/var/www/discourse/lib/site_icon_manager.rb:70:in `each'
/var/www/discourse/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/var/www/discourse/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Tareas: TOP => db:migrate
(Ver traza completa ejecutando la tarea con --trace)
Te respondí aquí y olvidé responderte, lo siento.
Ejecuté esto y obtuve nil.
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails aborted!
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails console
Loading test environment (Rails 7.1.4.1)
irb(main):001> Upload.find_by(id: -6)
=> nil
irb(main):002>
¿En qué paso te encuentras actualmente? ¿Ya has clonado Discourse?
Estoy usando la instalación de Docker
Me acabo de encontrar con esto al crear una nueva base de datos local y migrar.
Lamentablemente, creo que fue introducido por FIX: reset cache after flags are seed by lis2 · Pull Request #28801 · discourse/discourse · GitHub. Las migraciones nuevas desde cero ya no son posibles.
@kris.kotlarek, ¿podrías echarle un vistazo, por favor? Creo que tocar la caché de Redis en el inicializador podría ser el problema.
Gracias por el informe @NateDhaliwal
Kris arregló el problema con
¡Deberíamos estar bien ahora!
