assets:precompile 실행 중 mini_racer.rb 세그멘테이션 폴트 발생
I recently ran an update, I was about 20 days behind, and I ran into a consistent core dump from mini_racer.rb during rake themes:updateassets:precompile
This is a multisite set up and I am able to reproduce the problem on multiple machines by copying the state of /var/discourse to another machine and rerunning ./launcher rebuild app.
Realizing where the failure was I created an image without the precompile step.
When I reran the precompile command from within the app container the same “[BUG] Segmentation fault at 0x000016815713b548” error would happen consistently.
However, when I ran precompile for each site individually utilizing RAILS_DB, each site’s precompile step completed without a problem and a subsequent run of the original command without RAILS_DB specified passed and continues to pass now without a problem.
I am submitting this in case someone else has the problem and needs to get further or if I can do something to help track down the bug for the devs. If this is too much of a setup specific bug or is more appropriate as a bug against mini_racer let me know.
Below is additional information:
I have the state of the db saved off that allows me to reproduce the crash relatively easily.
coredump bt full output
This is what I could get out of the coredump not too much given the lack of symbols.
(gdb) bt full
#0  0x00007dbf36e168ee in ?? () from /lib/x86_64-linux-gnu/libgcc_s.so.1
No symbol table info available.
#1  0x00007dbf36e1864b in _Unwind_Backtrace () from /lib/x86_64-linux-gnu/libgcc_s.so.1
#2  0x00007dbf366558ff in __GI___backtrace (array=array@entry=0x7dbf36dee9e0 <trace>, size=size@entry=1024)
    at ./debug/backtrace.c:78
        arg = {array = 0x7dbf36dee9e0 <trace>, unwind_link = 0x7dbf3671a600 <global>, cfa = 99493855763264,
          cnt = 4, size = 1024}
#3  0x00007dbf36b1857b in rb_print_backtrace (errout=0x7dbf36713680 <_IO_2_1_stderr_>) at vm_dump.c:820
        n = <optimized out>
        trace = {0x7dbf36b1857b <rb_vm_bugreport+2411>, 0x7dbf36912840 <rb_bug_for_fatal_signal+256>,
          0x7dbf36a63f8b, 0x7dbf3657c050 <__restore_rt>, 0x0 <repeats 1020 times>}
        n = <optimized out>
#4  rb_vm_bugreport (ctx=ctx@entry=0x5a7d37ee1b40, errout=errout@entry=0x7dbf36713680 <_IO_2_1_stderr_>)
    at vm_dump.c:1151
        cmd = <optimized out>
        error = <optimized out>
        other_runtime_info = other_runtime_info
        vm = 0x5a7d32dfdb70
        ec = <optimized out>
#5  0x00007dbf36912840 in rb_bug_for_fatal_signal (default_sighandler=0x0, sig=sig@entry=11,
    ctx=ctx@entry=0x5a7d37ee1b40, fmt=fmt@entry=0x7dbf36c764d5 "Segmentation fault at %p") at error.c:1065
        pid = -1
        out = 0x7dbf36713680 <_IO_2_1_stderr_>
        file = <optimized out>
        line = 251
#6  0x00007dbf36a63f8b in sigsegv (sig=11, info=0x5a7d37ee1c70, ctx=0x5a7d37ee1b40) at signal.c:926
No locals.
#7  <signal handler called>
No locals.
#8  0x000002aa2ca82540 in ?? ()
#9  0x000002aa2cebaef0 in ?? ()
#10 0x00003b134cc41151 in ?? ()
#11 0x0000166e35e16221 in ?? ()
#12 0x000000000000000a in ?? ()
#13 0x00007dbf0e3fc6d8 in ?? ()
#14 0x000002aa2cd99226 in ?? ()
#15 0x000fff480e3fc858 in ?? ()
#16 0x0000000000000000 in ?? ()
Here is a full ./launcher rebuild app output
Failure starts at
[2024-11-02T01:47:24.999880 #1] INFO – : > cd /var/www/discourse && su discourse -c ‘SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile’
Full Build Output
root@bui /var/discourse (main)# ./launcher rebuild app
x86_64 arch detected.
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20240825-0027: Pulling from discourse/base
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Image is up to date for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-11-02T01:44:52.378303 #1]  INFO -- : Reading from stdin
I, [2024-11-02T01:44:52.383987 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-11-02T01:44:52.385967 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-11-02T01:44:52.387891 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-11-02T01:44:52.389701 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-11-02T01:44:52.391627 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-11-02T01:44:52.391731 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.392012 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.392219 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.396485 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.396649 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.396807 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.396996 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.397152 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.397320 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-02T01:44:52.397485 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-11-02T01:44:52.397611 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-11-02T01:44:52.397743 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-11-02T01:44:52.397920 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-11-02T01:44:53.461893 #1]  INFO -- : Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
I, [2024-11-02T01:44:53.462006 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-11-02T01:44:53.464711 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-11-02T01:44:53.467297 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-11-02T01:44:53.468393 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-11-02T01:44:53.468514 #1]  INFO -- : > sleep 5
2024-11-02 01:44:53.506 UTC [39] LOG:  starting PostgreSQL 13.16 (Debian 13.16-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14) 12.2.0, 64-bit
2024-11-02 01:44:53.507 UTC [39] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-11-02 01:44:53.507 UTC [39] LOG:  listening on IPv6 address "::", port 5432
2024-11-02 01:44:53.518 UTC [39] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-11-02 01:44:53.533 UTC [48] LOG:  database system was shut down at 2024-11-02 00:16:33 UTC
2024-11-02 01:44:53.542 UTC [39] LOG:  database system is ready to accept connections
I, [2024-11-02T01:44:58.469404 #1]  INFO -- :
I, [2024-11-02T01:44:58.469488 #1]  INFO -- : > /usr/local/bin/create_db
2024-11-02 01:44:58.512 UTC [58] postgres@postgres ERROR:  database "discourse" already exists
2024-11-02 01:44:58.512 UTC [58] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2024-11-02 01:44:58.550 UTC [61] postgres@discourse ERROR:  role "discourse" already exists
2024-11-02 01:44:58.550 UTC [61] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
NOTICE:  version "0.7.4" of extension "vector" is already installed
I, [2024-11-02T01:44:58.875599 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
UPDATE 0
I, [2024-11-02T01:44:58.875658 #1]  INFO -- : > echo postgres installed!
I, [2024-11-02T01:44:58.876655 #1]  INFO -- : postgres installed!
I, [2024-11-02T01:44:58.876751 #1]  INFO -- : > sudo -u postgres createdb zab_discourse || exit 0
2024-11-02 01:44:58.901 UTC [99] postgres@postgres ERROR:  database "zab_discourse" already exists
2024-11-02 01:44:58.901 UTC [99] postgres@postgres STATEMENT:  CREATE DATABASE zab_discourse;
createdb: error: database creation failed: ERROR:  database "zab_discourse" already exists
I, [2024-11-02T01:44:58.902590 #1]  INFO -- :
I, [2024-11-02T01:44:58.902722 #1]  INFO -- : > sudo -u postgres psql zab_discourse
I, [2024-11-02T01:44:58.903456 #1]  INFO -- : grant all privileges on database zab_discourse to discourse;
grant all privileges on database devsite_discourse to discourse;
I, [2024-11-02T01:44:58.929995 #1]  INFO -- : > /bin/bash -c 'sudo -u postgres psql zab_discourse <<< "alter schema public owner to discourse;"'
I, [2024-11-02T01:44:58.957252 #1]  INFO -- : ALTER SCHEMA
I, [2024-11-02T01:44:58.957405 #1]  INFO -- : > /bin/bash -c 'sudo -u postgres psql zab_discourse <<< "create extension if not exists hstore;"'
I, [2024-11-02T01:44:58.984839 #1]  INFO -- : CREATE EXTENSION
I, [2024-11-02T01:44:58.984945 #1]  INFO -- : > /bin/bash -c 'sudo -u postgres psql zab_discourse <<< "create extension if not exists pg_trgm;"'
I, [2024-11-02T01:44:59.011819 #1]  INFO -- : CREATE EXTENSION
I, [2024-11-02T01:44:59.011953 #1]  INFO -- : > sudo -u postgres createdb devsite_discourse || exit 0
2024-11-02 01:44:59.036 UTC [121] postgres@postgres ERROR:  database "devsite_discourse" already exists
2024-11-02 01:44:59.036 UTC [121] postgres@postgres STATEMENT:  CREATE DATABASE devsite_discourse;
createdb: error: database creation failed: ERROR:  database "devsite_discourse" already exists
I, [2024-11-02T01:44:59.037669 #1]  INFO -- :
I, [2024-11-02T01:44:59.037823 #1]  INFO -- : > sudo -u postgres psql devsite_discourse
I, [2024-11-02T01:44:59.038719 #1]  INFO -- : grant all privileges on database devsite_discourse to discourse;
I, [2024-11-02T01:44:59.065215 #1]  INFO -- : > /bin/bash -c 'sudo -u postgres psql devsite_discourse <<< "alter schema public owner to discourse;"'
I, [2024-11-02T01:44:59.092386 #1]  INFO -- : ALTER SCHEMA
I, [2024-11-02T01:44:59.092489 #1]  INFO -- : > /bin/bash -c 'sudo -u postgres psql devsite_discourse <<< "create extension if not exists hstore;"'
I, [2024-11-02T01:44:59.119000 #1]  INFO -- : CREATE EXTENSION
I, [2024-11-02T01:44:59.119113 #1]  INFO -- : > /bin/bash -c 'sudo -u postgres psql devsite_discourse <<< "create extension if not exists pg_trgm;"'
I, [2024-11-02T01:44:59.145739 #1]  INFO -- : CREATE EXTENSION
I, [2024-11-02T01:44:59.147856 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-11-02T01:44:59.149569 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-11-02T01:44:59.151148 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-11-02T01:44:59.151243 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.151529 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.151730 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-11-02T01:44:59.152726 #1]  INFO -- :
I, [2024-11-02T01:44:59.152872 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.156046 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.156392 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.156816 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.157150 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-11-02T01:44:59.157493 #1]  INFO -- : > echo redis installed
I, [2024-11-02T01:44:59.158307 #1]  INFO -- : redis installed
I, [2024-11-02T01:44:59.158379 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-11-02T01:44:59.159827 #1]  INFO -- : logfile ""
I, [2024-11-02T01:44:59.159884 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-11-02T01:44:59.160479 #1]  INFO -- : > sleep 10
151:C 02 Nov 2024 01:44:59.164 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
151:C 02 Nov 2024 01:44:59.164 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=151, just started
151:C 02 Nov 2024 01:44:59.164 # Configuration loaded
151:M 02 Nov 2024 01:44:59.164 * monotonic clock: POSIX clock_gettime
151:M 02 Nov 2024 01:44:59.164 * Running mode=standalone, port=6379.
151:M 02 Nov 2024 01:44:59.164 # Server initialized
151:M 02 Nov 2024 01:44:59.164 * Loading RDB produced by version 7.0.7
151:M 02 Nov 2024 01:44:59.164 * RDB age 5306 seconds
151:M 02 Nov 2024 01:44:59.164 * RDB memory usage when created 15.44 Mb
151:M 02 Nov 2024 01:44:59.184 * Done loading RDB, keys loaded: 4432, keys expired: 0.
151:M 02 Nov 2024 01:44:59.184 * DB loaded from disk: 0.020 seconds
151:M 02 Nov 2024 01:44:59.184 * Ready to accept connections
I, [2024-11-02T01:45:09.161564 #1]  INFO -- :
I, [2024-11-02T01:45:09.162064 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-11-02T01:45:09.169486 #1]  INFO -- : thpoff is installed!
I, [2024-11-02T01:45:09.170159 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-11-02T01:45:09.217931 #1]  INFO -- :
I, [2024-11-02T01:45:09.217977 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-11-02T01:45:09.258998 #1]  INFO -- :
I, [2024-11-02T01:45:09.259044 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-11-02T01:45:09.299487 #1]  INFO -- :
I, [2024-11-02T01:45:09.299574 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-11-02T01:45:09.300769 #1]  INFO -- :
I, [2024-11-02T01:45:09.301842 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-11-02T01:45:09.303806 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-11-02T01:45:09.305607 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-11-02T01:45:09.307455 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-11-02T01:45:09.309203 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-11-02T01:45:09.310924 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-11-02T01:45:09.311007 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2024-11-02T01:45:09.313238 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34680/34680), done.
I, [2024-11-02T01:45:11.364546 #1]  INFO -- : HEAD is now at 274e18622 FIX: Video uploads sometimes hang indefinitely (#28523)
I, [2024-11-02T01:45:11.364756 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-11-02T01:45:11.441460 #1]  INFO -- :
I, [2024-11-02T01:45:11.441520 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-a-gjs-ace
 - [deleted]             (none)     -> origin/better-respect-End-key-in-topics
 - [deleted]             (none)     -> origin/category-experts-approved-webhook-event
 - [deleted]             (none)     -> origin/chat-sound-respects-indicator-pref
 - [deleted]             (none)     -> origin/d-button-noautoclass
 - [deleted]             (none)     -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.2
 - [deleted]             (none)     -> origin/dependabot/bundler/sass-embedded-1.77.8
 - [deleted]             (none)     -> origin/dependabot/bundler/sassc-embedded-1.77.8
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/ember-cli-deprecation-workflow-3.0.2
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/ember/test-helpers-4.0.1
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/eslint-9.7.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/sass-1.77.8
 - [deleted]             (none)     -> origin/detect-default-readonly
 - [deleted]             (none)     -> origin/dev/add-skeleton-of-section-landing-page-and-items
 - [deleted]             (none)     -> origin/dev/remove-header-widgets
 - [deleted]             (none)     -> origin/feature/site-text-result-selected-lang
 - [deleted]             (none)     -> origin/fix/add-user-to-user-directory-when-activated
 - [deleted]             (none)     -> origin/issue/fix-bookmark-clearing-reminder
 - [deleted]             (none)     -> origin/loic-drop-compiled-js-column
 - [deleted]             (none)     -> origin/mt/converter
 - [deleted]             (none)     -> origin/mt/uploads-command
 - [deleted]             (none)     -> origin/native-class-components-2
 - [deleted]             (none)     -> origin/native-class-components-3
 - [deleted]             (none)     -> origin/notifications_id_bigint
 - [deleted]             (none)     -> origin/prevent-desktop-notifications-on-mobile
 - [deleted]             (none)     -> origin/tobiaseigen-patch-3
 - [deleted]             (none)     -> origin/tobiaseigen-patch-5
 - [deleted]             (none)     -> origin/update-composer-media-optimization-requirements
 - [deleted]             (none)     -> origin/ux/admin-plugins-ui-guidelines
   274e18622..deeed5b8c  main                    -> origin/main
 * [new branch]          0-a-dl                  -> origin/0-a-dl
 * [new branch]          0-a-more-topics-api     -> origin/0-a-more-topics-api
 * [new branch]          add-live-reload-disable-option -> origin/add-live-reload-disable-option
 * [new branch]          add-outlet-user-card    -> origin/add-outlet-user-card
 * [new branch]          add-shift-detect        -> origin/add-shift-detect
 * [new branch]          add-verbose-logging-for-google-oauth -> origin/add-verbose-logging-for-google-oauth
 * [new branch]          auto-grid-images        -> origin/auto-grid-images
 * [new branch]          chat-uppy-upload        -> origin/chat-uppy-upload
 * [new branch]          chunk-size              -> origin/chunk-size
 * [new branch]          cleanup-mobile-topic-footer-area -> origin/cleanup-mobile-topic-footer-area
 + 7f254be61...4264fe0d6 coco/generic-importer   -> origin/coco/generic-importer  (forced update)
 * [new branch]          dependabot/bundler/activejob-7.1.5 -> origin/dependabot/bundler/activejob-7.1.5
 * [new branch]          dependabot/bundler/activemodel-7.1.5 -> origin/dependabot/bundler/activemodel-7.1.5
 * [new branch]          dependabot/bundler/omniauth-google-oauth2-1.2.0 -> origin/dependabot/bundler/omniauth-google-oauth2-1.2.0
 * [new branch]          dependabot/bundler/rackup-1.0.1 -> origin/dependabot/bundler/rackup-1.0.1
 * [new branch]          dependabot/bundler/rails-81d7e7502c -> origin/dependabot/bundler/rails-81d7e7502c
 * [new branch]          dependabot/bundler/sass-embedded-1.80.5 -> origin/dependabot/bundler/sass-embedded-1.80.5
 * [new branch]          dependabot/bundler/sassc-embedded-1.80.1 -> origin/dependabot/bundler/sassc-embedded-1.80.1
 * [new branch]          dependabot/npm_and_yarn/glimmer/component-2.0.0 -> origin/dependabot/npm_and_yarn/glimmer/component-2.0.0
 * [new branch]          dependabot/npm_and_yarn/jsuites-5.7.0 -> origin/dependabot/npm_and_yarn/jsuites-5.7.0
 * [new branch]          dependabot/npm_and_yarn/sass-1.80.5 -> origin/dependabot/npm_and_yarn/sass-1.80.5
 * [new branch]          dependabot/npm_and_yarn/webpack-5.96.1 -> origin/dependabot/npm_and_yarn/webpack-5.96.1
 * [new branch]          deprecate-template-overrides -> origin/deprecate-template-overrides
 * [new branch]          dev-faster-tests        -> origin/dev-faster-tests
 * [new branch]          dev-fix-chat-types      -> origin/dev-fix-chat-types
 * [new branch]          dev-nginx-conf          -> origin/dev-nginx-conf
 * [new branch]          dev/automation-scriptable-add-with-class -> origin/dev/automation-scriptable-add-with-class
 * [new branch]          dev/convert-theme-install-modal-gjs -> origin/dev/convert-theme-install-modal-gjs
 * [new branch]          dev/glimmer-post-menu   -> origin/dev/glimmer-post-menu
 * [new branch]          dev/port-outlet-wrapper-to-stable -> origin/dev/port-outlet-wrapper-to-stable
 * [new branch]          dev/remap-enhancements  -> origin/dev/remap-enhancements
 * [new branch]          dev/remove-admin-flag-translations -> origin/dev/remove-admin-flag-translations
 * [new branch]          dev/remove-deprecated-respect-plugin-positional-argument -> origin/dev/remove-deprecated-respect-plugin-positional-argument
 * [new branch]          dev/use-new-filestore-download-method -> origin/dev/use-new-filestore-download-method
 + 59bf25001...86f856e04 devcontainer            -> origin/devcontainer  (forced update)
 * [new branch]          drawer-composer-positioning -> origin/drawer-composer-positioning
 * [new branch]          ember-native-class      -> origin/ember-native-class
 * [new branch]          events-ui               -> origin/events-ui
 * [new branch]          feature-searchable-fields-link -> origin/feature-searchable-fields-link
 * [new branch]          feature/add-user-to-topic_tags_changed-event -> origin/feature/add-user-to-topic_tags_changed-event
 + a0042745d...0093ed7e3 feature/bulk-dismiss-buttons-confirmation -> origin/feature/bulk-dismiss-buttons-confirmation  (forced update)
 * [new branch]          feature/custom-fields-for-existing-users -> origin/feature/custom-fields-for-existing-users
 * [new branch]          fix-safari-below-18-detection -> origin/fix-safari-below-18-detection
 * [new branch]          glint                   -> origin/glint
 * [new branch]          issue/fix-plugin-actions-outlet -> origin/issue/fix-plugin-actions-outlet
 * [new branch]          loic-experiment-model-value-type -> origin/loic-experiment-model-value-type
 * [new branch]          loic-fix-post-revision-serializer -> origin/loic-fix-post-revision-serializer
 + 26e2ddbde...653ec4e50 loic-rails-7.2          -> origin/loic-rails-7.2  (forced update)
 * [new branch]          loic-refactor-create-thread-service -> origin/loic-refactor-create-thread-service
 * [new branch]          mt/idb                  -> origin/mt/idb
 * [new branch]          perf-chat-auto-join-take-42 -> origin/perf-chat-auto-join-take-42
 * [new branch]          post-badge-poc          -> origin/post-badge-poc
 * [new branch]          refactor_deditor_textarea -> origin/refactor_deditor_textarea
 * [new branch]          render-glimmer-granular -> origin/render-glimmer-granular
 * [new branch]          revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting -> origin/revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting
 * [new branch]          safari-hacks-sayonara   -> origin/safari-hacks-sayonara
 * [new branch]          sidebar-a11y-viewport-zoom -> origin/sidebar-a11y-viewport-zoom
   d3ad2ecda..1da4243cc  stable                  -> origin/stable
 * [new branch]          tag-name-transformer    -> origin/tag-name-transformer
 * [new branch]          testing_debian_12       -> origin/testing_debian_12
   274e18622..deeed5b8c  tests-passed            -> origin/tests-passed
 * [new branch]          virtual-keyboard-fix-login -> origin/virtual-keyboard-fix-login
 * [new branch]          whats-new-notify-plugins -> origin/whats-new-notify-plugins
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.3.1                  -> v3.3.1
 * [new tag]             v3.3.2                  -> v3.3.2
 * [new tag]             v3.4.0.beta1            -> v3.4.0.beta1
 * [new tag]             v3.4.0.beta2            -> v3.4.0.beta2
I, [2024-11-02T01:45:11.905583 #1]  INFO -- :
I, [2024-11-02T01:45:11.905644 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-11-02T01:45:14.469334 #1]  INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2024-11-02T01:45:14.469386 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-11-02T01:45:14.493302 #1]  INFO -- :
I, [2024-11-02T01:45:14.493361 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-11-02T01:45:14.495021 #1]  INFO -- :
I, [2024-11-02T01:45:14.495051 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-11-02T01:45:14.496347 #1]  INFO -- :
I, [2024-11-02T01:45:14.496374 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-11-02T01:45:14.497688 #1]  INFO -- :
I, [2024-11-02T01:45:14.497722 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-11-02T01:45:14.499000 #1]  INFO -- :
I, [2024-11-02T01:45:14.499046 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-11-02T01:45:14.500340 #1]  INFO -- :
I, [2024-11-02T01:45:14.500394 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-11-02T01:45:14.501795 #1]  INFO -- :
I, [2024-11-02T01:45:14.501830 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-11-02T01:45:14.503581 #1]  INFO -- :
I, [2024-11-02T01:45:14.503645 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-11-02T01:45:14.505356 #1]  INFO -- :
I, [2024-11-02T01:45:14.505407 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-11-02T01:45:14.507140 #1]  INFO -- :
I, [2024-11-02T01:45:14.507171 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-11-02T01:45:14.508805 #1]  INFO -- :
I, [2024-11-02T01:45:14.508834 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-11-02T01:45:14.510535 #1]  INFO -- :
I, [2024-11-02T01:45:14.510564 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-11-02T01:45:14.512167 #1]  INFO -- :
I, [2024-11-02T01:45:14.512192 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-11-02T01:45:14.525397 #1]  INFO -- :
I, [2024-11-02T01:45:14.525458 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-11-02T01:45:14.526543 #1]  INFO -- :
I, [2024-11-02T01:45:14.526605 #1]  INFO -- : Replacing # redis with if [ ! -d /shared/redis_data ]; then
fi
sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-11-02T01:45:14.527049 #1]  INFO -- : > cd /var/www/discourse/plugins && mkdir -p plugins
I, [2024-11-02T01:45:14.528359 #1]  INFO -- :
I, [2024-11-02T01:45:14.528402 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-11-02T01:45:15.116533 #1]  INFO -- :
I, [2024-11-02T01:45:15.116669 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions
Cloning into 'discourse-reactions'...
I, [2024-11-02T01:45:15.612542 #1]  INFO -- :
I, [2024-11-02T01:45:15.612646 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-bbcode
Cloning into 'discourse-bbcode'...
I, [2024-11-02T01:45:15.885350 #1]  INFO -- :
I, [2024-11-02T01:45:15.885442 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-saml
Cloning into 'discourse-saml'...
I, [2024-11-02T01:45:16.121383 #1]  INFO -- :
I, [2024-11-02T01:45:16.121446 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-yearly-review
Cloning into 'discourse-yearly-review'...
I, [2024-11-02T01:45:16.396790 #1]  INFO -- :
I, [2024-11-02T01:45:16.396864 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-calendar
Cloning into 'discourse-calendar'...
I, [2024-11-02T01:45:17.104029 #1]  INFO -- :
I, [2024-11-02T01:45:17.104092 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-whos-online
Cloning into 'discourse-whos-online'...
I, [2024-11-02T01:45:17.376311 #1]  INFO -- :
I, [2024-11-02T01:45:17.376369 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-oauth2-basic
Cloning into 'discourse-oauth2-basic'...
I, [2024-11-02T01:45:17.634119 #1]  INFO -- :
I, [2024-11-02T01:45:17.634179 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-activity-pub
Cloning into 'discourse-activity-pub'...
I, [2024-11-02T01:45:18.135201 #1]  INFO -- :
I, [2024-11-02T01:45:18.135264 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-chat-integration
Cloning into 'discourse-chat-integration'...
I, [2024-11-02T01:45:18.547366 #1]  INFO -- :
I, [2024-11-02T01:45:18.547520 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-11-02T01:45:18.548862 #1]  INFO -- :
I, [2024-11-02T01:45:18.548924 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-11-02T01:45:18.549768 #1]  INFO -- :
I, [2024-11-02T01:45:18.549811 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-11-02T01:45:18.550730 #1]  INFO -- :
I, [2024-11-02T01:45:18.550812 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-11-02T01:45:18.550997 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-11-02T01:45:18.551180 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-11-02T01:45:18.551321 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-11-02T01:45:18.551461 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-11-02T01:45:18.551585 #1]  INFO -- : > echo "done configuring web"
I, [2024-11-02T01:45:18.552334 #1]  INFO -- : done configuring web
I, [2024-11-02T01:45:18.552445 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-11-02T01:45:19.016908 #1]  INFO -- : Successfully installed bundler-2.5.18
1 gem installed
I, [2024-11-02T01:45:19.016957 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-11-02T01:45:19.497022 #1]  INFO -- :
I, [2024-11-02T01:45:19.497168 #1]  INFO -- : > cd /var/www/discourse && if [ -f yarn.lock ]; then
  if [ -d node_modules/.pnpm ]; then
    echo "This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up..."
    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +
  fi
  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
else
  su discourse -c 'CI=1 pnpm install --frozen-lockfile'
fi
I, [2024-11-02T01:45:31.691162 #1]  INFO -- : Detected yarn-managed node_modules. Performing one-time cleanup...
cleanup done
Scope: all 19 workspace projects
Lockfile is up to date, resolution step is skipped
Progress: resolved 1, reused 0, downloaded 0, added 0
Packages: +1830
Progress: resolved 1830, reused 0, downloaded 232, added 309
Progress: resolved 1830, reused 0, downloaded 551, added 630
Progress: resolved 1830, reused 0, downloaded 844, added 923
Progress: resolved 1830, reused 0, downloaded 1050, added 1128
Progress: resolved 1830, reused 0, downloaded 1313, added 1391
Progress: resolved 1830, reused 0, downloaded 1547, added 1625
Progress: resolved 1830, reused 0, downloaded 1738, added 1825
Packages are hard linked from the content-addressable store to the virtual store.
  Content-addressable store is at: /home/discourse/.local/share/pnpm/store/v3
  Virtual store is at:             node_modules/.pnpm
Progress: resolved 1830, reused 0, downloaded 1743, added 1830, done
.../core-js@2.6.12/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../core-js@3.33.0/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../node_modules/@swc/core postinstall$ node postinstall.js
.../core-js@2.6.12/node_modules/core-js postinstall: Done
.../esbuild@0.24.0/node_modules/esbuild postinstall$ node install.js
.../core-js@3.33.0/node_modules/core-js postinstall: Done
.../lefthook@1.8.2/node_modules/lefthook postinstall$ node postinstall.js
.../node_modules/@swc/core postinstall: Done
.../esbuild@0.24.0/node_modules/esbuild postinstall: Done
.../lefthook@1.8.2/node_modules/lefthook postinstall: Done
devDependencies:
+ @babel/plugin-proposal-decorators 7.25.9
+ @discourse/lint-configs 1.4.2
+ @discourse/moment-timezone-names-translations 1.0.0
+ @fortawesome/fontawesome-free 6.6.0
+ @glint/core 1.5.0
+ @glint/environment-ember-loose 1.4.1-unstable.ff9ea6c
+ @glint/environment-ember-template-imports 1.4.1-unstable.ff9ea6c
+ @glint/template 1.4.1-unstable.ff9ea6c
+ @mixer/parallel-prettier 2.0.3
+ @swc/core 1.7.42
+ chart.js 3.5.1
+ chartjs-plugin-datalabels 2.2.0
+ chrome-launcher 1.1.2
+ chrome-remote-interface 0.33.2
+ concurrently 9.0.1
+ ember-template-lint 6.0.0
+ esbuild 0.24.0
+ eslint 8.57.0
+ jsdoc 4.0.4
+ lefthook 1.8.2
+ licensee 11.1.0
+ lint-to-the-future 2.2.0
+ lint-to-the-future-ember-template 1.2.0
+ lint-to-the-future-eslint 2.1.3
+ magnific-popup 1.1.0
+ moment 2.30.1
+ moment-timezone 0.5.45
+ pikaday 1.8.2
+ prettier 2.8.8
+ puppeteer-core 23.6.1
+ squoosh 2.0.0
+ terser 5.36.0
+ typescript 5.6.3
Done in 12.1s
I, [2024-11-02T01:45:31.692597 #1]  INFO -- : File > /var/www/discourse/config/multisite.yml  chmod:   chown:
I, [2024-11-02T01:45:31.692679 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --jobs $(($(nproc) - 1)) --retry 3'
I, [2024-11-02T01:46:03.708554 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/........
Fetching base64 0.2.0
Fetching mutex_m 0.2.0
Fetching rack 2.2.10
Fetching date 3.3.4
Fetching timeout 0.4.1
Fetching msgpack 1.7.3
Fetching cgi 0.4.1
Fetching openssl 3.2.0
Fetching diffy 3.4.3
Fetching digest 3.1.1
Fetching dry-initializer 3.1.1
Fetching excon 1.1.1
Fetching execjs 2.10.0
Fetching uri 0.13.1
Fetching json 2.7.5
Installing mutex_m 0.2.0
Installing base64 0.2.0
Installing timeout 0.4.1
Installing diffy 3.4.3
Installing cgi 0.4.1 with native extensions
Installing uri 0.13.1
Installing digest 3.1.1 with native extensions
Installing msgpack 1.7.3 with native extensions
Fetching logger 1.6.1
Installing dry-initializer 3.1.1
Fetching stringio 3.1.1
Fetching webrick 1.8.2
Installing openssl 3.2.0 with native extensions
Fetching thor 1.3.2
Installing execjs 2.10.0
Installing excon 1.1.1
Fetching zeitwerk 2.7.1
Installing date 3.3.4 with native extensions
Installing logger 1.6.1
Installing json 2.7.5 with native extensions
Fetching memory_profiler 1.1.0
Installing stringio 3.1.1 with native extensions
Installing rack 2.2.10
Fetching nio4r 2.7.4
Fetching ostruct 0.6.0
Installing webrick 1.8.2
Installing thor 1.3.2
Installing memory_profiler 1.1.0
Installing zeitwerk 2.7.1
Installing ostruct 0.6.0
Installing nio4r 2.7.4 with native extensions
Fetching parallel 1.26.3
Fetching rexml 3.3.9
Installing parallel 1.26.3
Fetching i18n 1.14.6
Fetching google-protobuf 4.28.3 (x86_64-linux)
Fetching jwt 2.9.3
Installing i18n 1.14.6
Installing rexml 3.3.9
Fetching net-protocol 0.2.2
Fetching reline 0.5.10
Installing net-protocol 0.2.2
Installing jwt 2.9.3
Installing reline 0.5.10
Fetching net-http 0.4.1
Installing net-http 0.4.1
Fetching uglifier 4.2.1
Fetching oj 3.16.6
Fetching tzinfo-data 1.2024.2
Fetching loofah 2.23.1
Fetching ruby-readability 0.7.2
Installing uglifier 4.2.1
Fetching css_parser 1.19.1
Installing loofah 2.23.1
Installing oj 3.16.6 with native extensions
Installing css_parser 1.19.1
Fetching sprockets 3.7.5
Installing google-protobuf 4.28.3 (x86_64-linux)
Fetching activesupport 7.1.4.2
Installing sprockets 3.7.5
Installing tzinfo-data 1.2024.2
Fetching highline 3.1.1
Fetching faraday-net_http 3.3.0
Installing faraday-net_http 3.3.0
Installing activesupport 7.1.4.2
Fetching omniauth-oauth 1.2.1
Installing highline 3.1.1
Installing omniauth-oauth 1.2.1
Installing ruby-readability 0.7.2
Fetching activemodel 7.1.4.2
Fetching actionview 7.1.4.2
Fetching activejob 7.1.4.2
Installing activemodel 7.1.4.2
Installing activejob 7.1.4.2
Installing actionview 7.1.4.2
Fetching activerecord 7.1.4.2
Fetching psych 5.1.2
Installing psych 5.1.2 with native extensions
Fetching actionpack 7.1.4.2
Installing activerecord 7.1.4.2
Installing actionpack 7.1.4.2
Fetching irb 1.14.1
Installing irb 1.14.1
Fetching faraday 2.12.0
Fetching railties 7.1.4.2
Installing faraday 2.12.0
Installing railties 7.1.4.2
Fetching puma 6.4.3
Installing puma 6.4.3 with native extensions
Fetching net-imap 0.5.0
Installing net-imap 0.5.0
Fetching actionmailer 7.1.4.2
Installing actionmailer 7.1.4.2
Bundle complete! 146 Gemfile dependencies, 185 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
Post-install message from i18n:
PSA: I18n will be dropping support for Ruby < 3.2 in the next major release (April 2025), due to Ruby's end of life for 3.1 and below (https://endoflife.date/ruby). Please upgrade to Ruby 3.2 or newer by April 2025 to continue using future versions of this gem.
1 installed gem you directly depend on is looking for funding.
  Run `bundle fund` for details
I, [2024-11-02T01:46:03.708676 #1]  INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
I, [2024-11-02T01:46:13.441831 #1]  INFO -- : gem install macaddr -v 1.0.0 -i /var/www/discourse/plugins/discourse-saml/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed macaddr-1.0.0
1 gem installed
gem install uuid -v 2.3.7 -i /var/www/discourse/plugins/discourse-saml/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed uuid-2.3.7
1 gem installed
gem install ruby-saml -v 1.17.0 -i /var/www/discourse/plugins/discourse-saml/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed ruby-saml-1.17.0
1 gem installed
gem install omniauth-saml -v 1.10.5 -i /var/www/discourse/plugins/discourse-saml/gems/3.3.4 --no-document --ignore-dependencies --no-user-install
Successfully installed omniauth-saml-1.10.5
1 gem installed
Multisite migrator is running using 1 threads
Migrating default
Migrating secondsite
Migrating thirdsite
Seeding default
Seeding secondsite
Seeding thirdsite
I, [2024-11-02T01:46:13.442015 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-11-02T01:46:14.333860 #1]  INFO -- : discourse-activity-pub is already at latest compatible version
discourse-bbcode is already at latest compatible version
discourse-calendar is already at latest compatible version
discourse-chat-integration is already at latest compatible version
discourse-oauth2-basic is already at latest compatible version
discourse-reactions is already at latest compatible version
discourse-saml is already at latest compatible version
discourse-whos-online is already at latest compatible version
discourse-yearly-review is already at latest compatible version
docker_manager is already at latest compatible version
I, [2024-11-02T01:46:14.334006 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-11-02T01:46:14.335023 #1]  INFO -- : > sleep 10
2421:C 02 Nov 2024 01:46:14.338 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
2421:C 02 Nov 2024 01:46:14.338 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=2421, just started
2421:C 02 Nov 2024 01:46:14.338 # Configuration loaded
2421:M 02 Nov 2024 01:46:14.339 * monotonic clock: POSIX clock_gettime
2421:M 02 Nov 2024 01:46:14.339 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
2421:M 02 Nov 2024 01:46:14.339 # Failed listening on port 6379 (TCP), aborting.
I, [2024-11-02T01:46:24.336132 #1]  INFO -- :
I, [2024-11-02T01:46:24.336788 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2024-11-02T01:46:27.763769 #1]  INFO -- :
I, [2024-11-02T01:46:27.763895 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile:build'
...[ConfigLoader]
...[Babel: discourse-widget-hbs > applyPatches]
...[Babel: @embroider/macros > applyPatches]
...[Babel: pretty-text > applyPatches]
...[Babel: discourse-common > applyPatches]
...[Babel: @ember/legacy-built-in-components > applyPatches]
...[Babel: ember-source > applyPatches]
...[ember.js]
...[Babel: @ember/test-waiters > applyPatches]
...[Babel: ember-this-fallback > applyPatches]
...[Babel: float-kit > applyPatches]
...[Babel: select-kit > applyPatches]
...[@embroider/compat/app]
...[@embroider/webpack]
...[SourceMapConcat]
...[Babel: admin > applyPatches]
...[TerserWriter]
...[Babel: discourse > applyPatches]
...[TerserWriter]
...[Babel: discourse-plugins > applyPatches]
...[TerserWriter]
WARNING: 324 deprecations encountered while compiling scss. (we cannot correct these until the Ruby SCSS pipeline is updated)
I, [2024-11-02T01:47:24.999740 #1]  INFO -- : Building
Environment: production
building...
cleaning up
cleaning up...
Built project successfully. Stored in "dist/".
File sizes:
 - dist/assets/admin.js: 1.01 MB (168.25 kB gzipped)
 - dist/assets/browser-detect.js: 425 B (298 B gzipped)
 - dist/assets/browser-update.js: 1.51 kB (866 B gzipped)
 - dist/assets/chunk.01d054aef3c653c62c2a.d41d8cd9.js: 4.72 MB (1.06 MB gzipped)
 - dist/assets/chunk.07fa5ab2e87a3b80c964.d41d8cd9.js: 6.65 kB (2.49 kB gzipped)
 - dist/assets/chunk.0857e4424da1b1685568.css: 72.18 kB (12.65 kB gzipped)
 - dist/assets/chunk.17f58575131b376ae0f0.d41d8cd9.js: 104.3 kB (46.21 kB gzipped)
 - dist/assets/chunk.1d0f5564c42a2783dbff.d41d8cd9.js: 6.5 kB (2.66 kB gzipped)
 - dist/assets/chunk.25b6c64665fd934f15b5.d41d8cd9.js: 2.74 MB (862.88 kB gzipped)
 - dist/assets/chunk.3791bfbc27cb1a2c6225.d41d8cd9.js: 5.36 kB (2.1 kB gzipped)
 - dist/assets/chunk.42185037ba3b88c2b11e.d41d8cd9.js: 152 B (142 B gzipped)
 - dist/assets/chunk.47ba8e941c10eea28812.d41d8cd9.js: 4.06 kB (1.83 kB gzipped)
 - dist/assets/chunk.5cff553763d7b7e535c1.d41d8cd9.js: 58.57 kB (17.67 kB gzipped)
 - dist/assets/chunk.5dd7a1742f183470ce2e.d41d8cd9.js: 209 B (187 B gzipped)
 - dist/assets/chunk.77fccec40bbe9c02a975.d41d8cd9.js: 67.35 kB (12.62 kB gzipped)
 - dist/assets/chunk.9fbee0bfe336151cb5d8.d41d8cd9.js: 530.91 kB (102.85 kB gzipped)
 - dist/assets/chunk.a1e788be04b104e0f88f.d41d8cd9.js: 20.87 kB (8.13 kB gzipped)
 - dist/assets/chunk.a4690c92df7d1384eb25.d41d8cd9.js: 598.54 kB (162.87 kB gzipped)
 - dist/assets/chunk.d717210b6a9fb0ddc682.d41d8cd9.js: 40.92 kB (13.85 kB gzipped)
 - dist/assets/chunk.facc41f756431c9ccfe6.d41d8cd9.js: 451.43 kB (121.24 kB gzipped)
 - dist/assets/chunk.fb30f0df6513c61a1bb5.css: 20.97 kB (4.92 kB gzipped)
 - dist/assets/chunk.fb30f0df6513c61a1bb5.d41d8cd9.js: 209 B (188 B gzipped)
 - dist/assets/discourse.css: 171 B (156 B gzipped)
 - dist/assets/discourse.d41d8cd98f00b204e9800998ecf8427e.css: 0 B
 - dist/assets/embed-application.js: 1.19 kB (574 B gzipped)
 - dist/assets/google-tag-manager.js: 526 B (357 B gzipped)
 - dist/assets/google-universal-analytics-v3.js: 654 B (403 B gzipped)
 - dist/assets/google-universal-analytics-v4.js: 461 B (298 B gzipped)
 - dist/assets/onpopstate-handler.js: 157 B (143 B gzipped)
 - dist/assets/pageview.js: 347 B (255 B gzipped)
 - dist/assets/plugins/automation_admin.js: 100.87 kB (15.85 kB gzipped)
 - dist/assets/plugins/chat.js: 778.32 kB (136.59 kB gzipped)
 - dist/assets/plugins/chat_admin.js: 21.26 kB (3.79 kB gzipped)
 - dist/assets/plugins/checklist.js: 3.81 kB (1.75 kB gzipped)
 - dist/assets/plugins/discourse-activity-pub.js: 112.78 kB (17.9 kB gzipped)
 - dist/assets/plugins/discourse-bbcode.js: 2.97 kB (1.22 kB gzipped)
 - dist/assets/plugins/discourse-calendar.js: 172.89 kB (34.78 kB gzipped)
 - dist/assets/plugins/discourse-chat-integration.js: 1.29 kB (585 B gzipped)
 - dist/assets/plugins/discourse-chat-integration_admin.js: 35.73 kB (5.63 kB gzipped)
 - dist/assets/plugins/discourse-details.js: 1.29 kB (637 B gzipped)
 - dist/assets/plugins/discourse-lazy-videos.js: 6.31 kB (2.12 kB gzipped)
 - dist/assets/plugins/discourse-local-dates.js: 30.86 kB (8.29 kB gzipped)
 - dist/assets/plugins/discourse-presence.js: 9.9 kB (2.06 kB gzipped)
 - dist/assets/plugins/discourse-reactions.js: 41.79 kB (9.3 kB gzipped)
 - dist/assets/plugins/discourse-whos-online.js: 16.35 kB (2.93 kB gzipped)
 - dist/assets/plugins/discourse-yearly-review.js: 2.01 kB (884 B gzipped)
 - dist/assets/plugins/docker_manager_admin.js: 32.3 kB (6.49 kB gzipped)
 - dist/assets/plugins/footnote.js: 2.87 kB (1.25 kB gzipped)
 - dist/assets/plugins/poll.js: 91.5 kB (20.43 kB gzipped)
 - dist/assets/plugins/spoiler-alert.js: 3.27 kB (1.39 kB gzipped)
 - dist/assets/plugins/styleguide.js: 155.23 kB (21.43 kB gzipped)
 - dist/assets/print-page.js: 111 B (125 B gzipped)
 - dist/assets/publish.js: 294 B (212 B gzipped)
 - dist/assets/qunit-custom.css: 6.74 kB (1.89 kB gzipped)
 - dist/assets/qunit.css: 974.62 kB (136.89 kB gzipped)
 - dist/assets/scripts/discourse-boot.js: 390 B (270 B gzipped)
 - dist/assets/scripts/discourse-test-listen-boot.js: 122 B (106 B gzipped)
 - dist/assets/scripts/discourse-test-load-dynamic-js.js: 1.14 kB (601 B gzipped)
 - dist/assets/scripts/module-shims.js: 771 B (326 B gzipped)
 - dist/assets/scripts/start-app.js: 216 B (180 B gzipped)
 - dist/assets/splash-screen.js: 1.17 kB (554 B gzipped)
 - dist/assets/start-discourse.js: 495 B (338 B gzipped)
 - dist/assets/test-i18n.js: 609.86 kB (153.77 kB gzipped)
 - dist/assets/test-site-settings.js: 14.25 kB (5.19 kB gzipped)
 - dist/assets/vendor.d3163860318024d1a45415fcf58dbe4b.js: 440.54 kB (123.43 kB gzipped)
 - dist/javascripts/chart.js/3.5.1/chart.min.js: 188.37 kB (65.3 kB gzipped)
 - dist/javascripts/chartjs-plugin-datalabels/2.2.0/chartjs-plugin-datalabels.min.js: 12.94 kB (5.24 kB gzipped)
 - dist/javascripts/count.js: 1.44 kB (636 B gzipped)
 - dist/javascripts/embed-topics.js: 1.34 kB (631 B gzipped)
 - dist/javascripts/embed.js: 2.47 kB (1.01 kB gzipped)
 - dist/javascripts/magnific-popup/1.1.0/jquery.magnific-popup.min.js: 20.22 kB (7.37 kB gzipped)
 - dist/javascripts/media-optimization-worker.js: 5.01 kB (1.74 kB gzipped)
 - dist/javascripts/pikaday/1.8.2/pikaday.js: 42.54 kB (9.67 kB gzipped)
 - dist/javascripts/squoosh/mozjpeg_enc.js: 39.03 kB (10.81 kB gzipped)
 - dist/javascripts/squoosh/squoosh_resize.js: 4.53 kB (1.28 kB gzipped)
I, [2024-11-02T01:47:24.999880 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:251: [BUG] Segmentation fault at 0x000016815713b548
ruby 3.3.4 (2024-07-09 revision be1089c8ec) [x86_64-linux]
-- Control frame information -----------------------------------------------
c:0065 p:---- s:0437 e:000436 CFUNC  :call_unsafe
c:0064 p:0011 s:0430 e:000429 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:251
c:0063 p:0068 s:0427 E:0022f8 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:378
c:0062 p:0004 s:0416 E:002630 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:250 [FINISH]
c:0061 p:---- s:0413 e:000412 CFUNC  :synchronize
c:0060 p:0026 s:0409 E:0024f0 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:249
c:0059 p:0012 s:0403 e:000402 BLOCK  /var/www/discourse/lib/discourse_js_processor.rb:127 [FINISH]
c:0058 p:---- s:0399 e:000398 CFUNC  :synchronize
c:0057 p:0014 s:0395 e:000394 METHOD /var/www/discourse/lib/discourse_js_processor.rb:126
c:0056 p:0049 s:0383 e:000382 METHOD /var/www/discourse/lib/discourse_js_processor.rb:151
c:0055 p:0090 s:0373 e:000369 METHOD /var/www/discourse/lib/theme_javascript_compiler.rb:247
c:0054 p:0043 s:0358 e:000357 BLOCK  /var/www/discourse/lib/theme_javascript_compiler.rb:176 [FINISH]
c:0053 p:---- s:0350 e:000349 CFUNC  :each_pair
c:0052 p:0025 s:0346 e:000345 METHOD /var/www/discourse/lib/theme_javascript_compiler.rb:172
c:0051 p:0053 s:0339 e:000338 METHOD /var/www/discourse/app/models/theme.rb:176
c:0050 p:0129 s:0332 e:000331 BLOCK  /var/www/discourse/app/models/theme.rb:132 [FINISH]
c:0049 p:---- s:0327 e:000326 CFUNC  :instance_exec
c:0048 p:0008 s:0323 e:000322 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:448
c:0047 p:0040 s:0317 e:000316 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:239
c:0046 p:0006 s:0310 e:000309 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:602 [FINISH]
c:0045 p:---- s:0306 e:000305 CFUNC  :each
c:0044 p:0006 s:0302 e:000301 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:602
c:0043 p:0138 s:0297 e:000296 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:135
c:0042 p:0110 s:0288 E:0012e0 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:141
c:0041 p:0009 s:0278 e:000277 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:952
c:0040 p:0004 s:0273 E:001258 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/callbacks.rb:441
c:0039 p:0021 s:0268 e:000267 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/timestamp.rb:127
c:0038 p:0010 s:0261 e:000260 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/persistence.rb:751
c:0037 p:0013 s:0255 e:000254 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/validations.rb:55
c:0036 p:0006 s:0250 e:000249 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:313
c:0035 p:0020 s:0247 e:000246 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:365
c:0034 p:0027 s:0244 e:000243 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/database_s
c:0033 p:0023 s:0235 e:000234 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:361
c:0032 p:0004 s:0228 e:000227 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:313
c:0031 p:0022 s:0223 e:000222 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/suppressor.rb:56
c:0030 p:0061 s:0218 e:000217 BLOCK  /var/www/discourse/app/models/remote_theme.rb:430
c:0029 p:0351 s:0214 E:0000c0 METHOD /var/www/discourse/app/models/remote_theme.rb:439
c:0028 p:0209 s:0196 e:000195 BLOCK  /var/www/discourse/lib/tasks/themes.rake:89
c:0027 p:0012 s:0190 e:000189 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/transactio
c:0026 p:0002 s:0183 e:000182 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/concurrency/null_lock.rb:9
c:0025 p:0008 s:0179 e:000178 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/transactio
c:0024 p:0042 s:0172 e:000171 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/database_s
c:0023 p:0012 s:0163 e:000162 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:212
c:0022 p:0012 s:0157 e:000156 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:301
c:0021 p:0006 s:0151 e:000150 BLOCK  /var/www/discourse/lib/tasks/themes.rake:69 [FINISH]
c:0020 p:---- s:0146 e:000145 CFUNC  :each
c:0019 p:0008 s:0142 e:000141 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:82
c:0018 p:0006 s:0138 e:000137 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:158
c:0017 p:0158 s:0134 e:000133 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:396
c:0016 p:0018 s:0123 e:000122 METHOD <internal:kernel>:187
c:0015 p:0063 s:0118 e:000117 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:372
c:0014 p:0143 s:0102 e:000101 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:269
c:0013 p:0050 s:0087 e:000086 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:157
c:0012 p:0028 s:0076 e:000075 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:81
c:0011 p:0026 s:0065 e:000064 METHOD /var/www/discourse/lib/tasks/themes.rake:67
c:0010 p:0006 s:0059 e:000058 BLOCK  /var/www/discourse/lib/tasks/themes.rake:118
c:0009 p:0039 s:0056 e:000055 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:207
c:0008 p:0017 s:0048 e:000047 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21
c:0007 p:0007 s:0039 e:000038 BLOCK  /var/www/discourse/lib/tasks/themes.rake:118
c:0006 p:0030 s:0035 e:000034 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:650
c:0005 p:0014 s:0025 e:000024 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:441
c:0004 p:0012 s:0022 e:000021 METHOD /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:660
c:0003 p:0032 s:0014 e:000013 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:440
c:0002 p:0004 s:0006 e:000005 BLOCK  /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:219 [FINISH]
c:0001 p:---- s:0003 e:000002 DUMMY  [FINISH]
-- Ruby level backtrace information ----------------------------------------
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:219:in `block (4 levels) in in_threads'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:440:in `block in work_in_threads'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:660:in `with_instrumentation'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:441:in `block (2 levels) in work_in_threads'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/parallel-1.26.3/lib/parallel.rb:650:in `call_with_index'
/var/www/discourse/lib/tasks/themes.rake:118:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:207:in `with_connection'
/var/www/discourse/lib/tasks/themes.rake:118:in `block (3 levels) in <main>'
/var/www/discourse/lib/tasks/themes.rake:67:in `update_themes'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:81:in `find_each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:157:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:269:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:372:in `batch_on_unloaded_relation'
<internal:kernel>:187:in `loop'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:396:in `block in batch_on_unloaded_relation'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:158:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:82:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/relation/batches.rb:82:in `each'
/var/www/discourse/lib/tasks/themes.rake:69:in `block in update_themes'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:301:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/var/www/discourse/lib/tasks/themes.rake:89:in `block (2 levels) in update_themes'
/var/www/discourse/app/models/remote_theme.rb:439:in `update_from_remote'
/var/www/discourse/app/models/remote_theme.rb:430:in `block in update_from_remote'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/suppressor.rb:56:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:313:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:361:in `with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/connection_adapters/abstract/database_statements.rb:342:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:365:in `block in with_transaction_returning_status'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/transactions.rb:313:in `block in save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/validations.rb:55:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/persistence.rb:751:in `save!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/timestamp.rb:127:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.2/lib/active_record/callbacks.rb:441:in `create_or_update'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:952:in `_run_save_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:141:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:135:in `block in run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:602:in `invoke_after'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:602:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:602:in `block in invoke_after'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:239:in `block in halting_and_conditional'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:448:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.4.2/lib/active_support/callbacks.rb:448:in `instance_exec'
/var/www/discourse/app/models/theme.rb:132:in `block in <class:Theme>'
/var/www/discourse/app/models/theme.rb:176:in `update_javascript_cache!'
/var/www/discourse/lib/theme_javascript_compiler.rb:172:in `append_tree'
/var/www/discourse/lib/theme_javascript_compiler.rb:172:in `each_pair'
/var/www/discourse/lib/theme_javascript_compiler.rb:176:in `block in append_tree'
/var/www/discourse/lib/theme_javascript_compiler.rb:247:in `append_module'
/var/www/discourse/lib/discourse_js_processor.rb:151:in `perform'
/var/www/discourse/lib/discourse_js_processor.rb:126:in `v8_call'
/var/www/discourse/lib/discourse_js_processor.rb:126:in `synchronize'
/var/www/discourse/lib/discourse_js_processor.rb:127:in `block in v8_call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:249:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:249:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:250:in `block in call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:378:in `timeout'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:251:in `block (2 levels) in call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/mini_racer-0.14.1/lib/mini_racer.rb:251:in `call_unsafe'
-- Threading information ---------------------------------------------------
Total ractor count: 1
Ruby thread count for this ractor: 13
-- Machine register context ------------------------------------------------
 RIP: 0x000016815713b540 RBP: 0x00007cecb50ea698 RSP: 0x00007cecb50ea678
 RAX: 0x000019ae27801789 RBX: 0x0000000000000010 RCX: 0x0000168157544996
 RDX: 0x00007cecb50ea660 RDI: 0x000023fff3e31209 RSI: 0x0000241e654c1151
  R8: 0x0000000000000042  R9: 0x0000000000000042 R10: 0x0000000000000055
 R11: 0x000000000000000b R12: 0x000025c093bc7aa1 R13: 0x00007cec9804ae40
 R14: 0x000000000000008b R15: 0x00007cec983c42d0 EFL: 0x0000000000010202
-- C level backtrace information -------------------------------------------
2024-11-02 01:47:33.306 UTC [2704] discourse@devsite_discourse LOG:  unexpected EOF on client connection with an open transaction
2024-11-02 01:47:33.306 UTC [2754] discourse@discourse LOG:  unexpected EOF on client connection with an open transaction
2024-11-02 01:47:33.306 UTC [2703] discourse@zab_discourse LOG:  unexpected EOF on client connection with an open transaction
Segmentation fault (core dumped)
I, [2024-11-02T01:47:33.307440 #1]  INFO -- : Updating themes with concurrency: 10
[db:default] 'DiscoTOC' -  checking...
[db:thirdsite] 'Kiosk' -  checking...
[db:secondsite] 'DiscoTOC' -  checking...
[db:thirdsite] 'Kiosk' -  up to date
[db:thirdsite] 'Dark-Light Toggle' -  checking...
[db:secondsite] 'DiscoTOC' -  updating from 67de4bd6 to 062d4c2d
[db:default] 'DiscoTOC' -  updating from 67de4bd6 to 062d4c2d
[db:thirdsite] 'Dark-Light Toggle' -  updating from 7ed31b75 to 8d84b508
151:signal-handler (1730512053) Received SIGTERM scheduling shutdown...
I, [2024-11-02T01:47:33.307646 #1]  INFO -- : Terminating async processes
I, [2024-11-02T01:47:33.307667 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 39
I, [2024-11-02T01:47:33.307685 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 151
2024-11-02 01:47:33.307 UTC [39] LOG:  received fast shutdown request
2024-11-02 01:47:33.359 UTC [39] LOG:  aborting any active transactions
2024-11-02 01:47:33.361 UTC [39] LOG:  background worker "logical replication launcher" (PID 54) exited with exit code 1
2024-11-02 01:47:33.361 UTC [49] LOG:  shutting down
151:M 02 Nov 2024 01:47:33.405 # User requested shutdown...
151:M 02 Nov 2024 01:47:33.405 * Saving the final RDB snapshot before exiting.
151:M 02 Nov 2024 01:47:33.644 * DB saved on disk
151:M 02 Nov 2024 01:47:33.644 # Redis is now ready to exit, bye bye...
2024-11-02 01:47:33.656 UTC [39] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 2662 exit 139>
exec failed with the params {"cd"=>"$home", "tag"=>"precompile", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'"]}
bootstrap failed with exit code 139
0a1c5d5564356a99382f072a4bfbdbf685d65ccfbae65d160fe12bd3df5d2025
5개의 좋아요
On a newly installed multi-sites I did not hit this bug.
But on a long time existing setup, running for years, I hit it. Ouch.
Is there any way to go back to a working version? – Rebooting fired up the previous container. Phew.
To get back to the older container you should just be able to run
./launcher run app
I haven’t gotten around to digging into this more given the time of the year but effectively the way I handle upgrading this one tricky instance right now is to do the following
cd /var/discourse
mv shared shared.good
./launcher rebuild app
./launcher stop app
mv shared shared.fresh # I use rm -rf here..
mv shared.good shared
./launcher start app
./launcher enter app
# Iterate through the different sites I have defined by setting RAILS_DB
# If it isn't set you reproduce the problem.
cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 RAILS_DB=default bundle exec rake themes:update assets:precompile'
cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 RAILS_DB=thirdsite bundle exec rake themes:update assets:precompile'
Once you’ve gone through that you can effectively do a completely new ./launcher rebuild app as long as no changes have come in and it should build end to end without a problem but this isn’t really necessary.
Looks like salt= is called on a User instance where it should not:
#<NoMethodError: undefined method `salt=' for an instance of User>
Other errors on theme updates:
[default] Failed to update 'DiscoTOC' (9): undefined method `ThemeModifierSetError' for class ThemeModifierSet
[default] Failed to update 'discourse-icon' (15): undefined method `ThemeModifierSetError' for class ThemeModifierSet
1개의 좋아요
다시 이 문제로 돌아와 보면, 해당 문제는 이제 더 이상 발생하지 않고 정기적으로 대응할 필요도 없게 되었습니다. 아마도 상류 단계에서 버그가 수정되어 이 문제가 더 이상 발생하지 않게 된 것 같습니다. 이 이슈를 종료 처리할 것이며, 다른 분들도 여전히 이 문제로 어려움을 겪고 계시다면 자유롭게 이 이슈를 다시 활성화해 주십시오.
수정: 제가 직접 버그를 종료할 권한이 없는 것 같으므로, 버그를 종료할 수 있는 권한이 있는 분이 이 내용을 보신다면 이 이슈가 해결된 것으로 간주해 주십시오.
2개의 좋아요
제 기억에 따르면 수정 사항이 커밋되었으니, Sam은 이 소식이 기쁠 거예요!
업데이트 감사합니다.
3개의 좋아요
