Discourse wil niet herbouwen
MacGyver27 reported that their Discourse instance suddenly fails to rebuild despite no recent configuration changes, encountering a Pups::ExecError during rake themes:update assets:precompile. The full log shows a successful launcher update and gem resolution, but the rebuild halts mid-process. pfaffman suggested removing the Giphy plugin as a workaround, which resolved the issue for MacGyver27. They questioned whether the plugin is now incompatible, to which Benjamin_D replied that it hasn’t been updated in four years and pointed to community forks and an alternative solution via the ReplyGif plugin, referenced in a Meta Discourse thread. The issue appears to stem from an outdated, unmaintained plugin conflicting with current Discourse rebuild processes.
Hi,
My Discourse suddenly won’t rebuild. I was doing regular updates for over a 3 years and had no issues, but the latest try can’t go through.. I did no administration changes to the setup - neither introduced new themes. In other words there were zero changes from the last upgrade.
Error:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3945 exit 1>
Whole LOG:
./launcher rebuild discourse
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 discourse
discourse
cd /pups && git pull && git checkout v1.0.3 && /pups/bin/pups --stdin
From https://github.com/discourse/pups
   17f04ec..e0ff889  master     -> origin/master
 * [new tag]         v1.1.1     -> v1.1.1
 * [new tag]         v1.1.0     -> v1.1.0
Updating 17f04ec..e0ff889
Fast-forward
 .github/workflows/ci.yml     |  29 ++++++
 .github/workflows/lint.yml   |  27 +++++
 .rubocop.yml                 |   3 +
 Gemfile                      |   2 +
 Guardfile                    |   4 +-
 README.md                    |  21 ++++
 Rakefile                     |  14 +--
 bin/pups                     |   8 +-
 lib/pups.rb                  |  32 ++++--
 lib/pups/cli.rb              |  92 ++++++++++-------
 lib/pups/command.rb          |  25 +++--
 lib/pups/config.rb           | 240 +++++++++++++++++++++++--------------------
 lib/pups/docker.rb           |  69 +++++++++++++
 lib/pups/exec_command.rb     | 182 ++++++++++++++++----------------
 lib/pups/file_command.rb     |  60 +++++------
 lib/pups/merge_command.rb    |  94 ++++++++---------
 lib/pups/replace_command.rb  |  70 +++++++------
 lib/pups/runit.rb            |  47 +++++----
 lib/pups/version.rb          |   4 +-
 pups.gemspec                 |  37 ++++---
 test/cli_test.rb             | 102 +++++++++++++++---
 test/config_test.rb          | 215 ++++++++++++++++++++++++++++----------
 test/docker_test.rb          | 157 ++++++++++++++++++++++++++++
 test/exec_command_test.rb    |  62 ++++++-----
 test/file_command_test.rb    |  17 ++-
 test/merge_command_test.rb   |  64 ++++++------
 test/replace_command_test.rb |  86 ++++++++--------
 test/test_helper.rb          |   2 +
 28 files changed, 1158 insertions(+), 607 deletions(-)
 create mode 100644 .github/workflows/ci.yml
 create mode 100644 .github/workflows/lint.yml
 create mode 100644 .rubocop.yml
 create mode 100644 lib/pups/docker.rb
 create mode 100644 test/docker_test.rb
Note: checking out 'v1.0.3'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at d1db030 cut a new version
I, [2021-08-06T20:55:29.975137 #1]  INFO -- : Loading --stdin
I, [2021-08-06T20:55:29.978798 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2021-08-06T20:55:30.008331 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2021-08-06T20:55:30.008485 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2021-08-06T20:55:30.010760 #1]  INFO -- :
I, [2021-08-06T20:55:30.010879 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2021-08-06T20:55:30.012708 #1]  INFO -- :
I, [2021-08-06T20:55:30.012838 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2021-08-06T20:55:30.014027 #1]  INFO -- :
I, [2021-08-06T20:55:30.014118 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2021-08-06T20:55:30.016426 #1]  INFO -- :
I, [2021-08-06T20:55:30.016551 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2021-08-06T20:55:30.018251 #1]  INFO -- :
I, [2021-08-06T20:55:30.018391 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2021/08/06 20:55:30 socat[34] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2021-08-06T20:55:30.020876 #1]  INFO -- :
I, [2021-08-06T20:55:30.020942 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2021-08-06T20:55:30.023429 #1]  INFO -- :
I, [2021-08-06T20:55:30.023514 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2021-08-06T20:55:30.025854 #1]  INFO -- :
I, [2021-08-06T20:55:30.025923 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-08-06T20:55:30.027727 #1]  INFO -- :
I, [2021-08-06T20:55:30.027842 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2021-08-06T20:55:30.029544 #1]  INFO -- :
I, [2021-08-06T20:55:30.035415 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2021-08-06T20:55:30.039019 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2021-08-06T20:55:30.042824 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2021-08-06T20:55:30.046287 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2021-08-06T20:55:30.046444 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2021-08-06T20:55:33.132539 #1]  INFO -- :
I, [2021-08-06T20:55:33.132680 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2021-08-06T20:55:33.134858 #1]  INFO -- :
I, [2021-08-06T20:55:33.134929 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2021-08-06T20:55:33.146303 #1]  INFO -- :
I, [2021-08-06T20:55:33.146391 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2021-08-06T20:55:33.148096 #1]  INFO -- :
I, [2021-08-06T20:55:33.148200 #1]  INFO -- : > /root/upgrade_postgres
I, [2021-08-06T20:55:33.151392 #1]  INFO -- :
I, [2021-08-06T20:55:33.151469 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2021-08-06T20:55:33.152931 #1]  INFO -- :
I, [2021-08-06T20:55:33.153090 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.153445 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.153608 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.153763 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.153911 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.154056 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.154194 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2021-08-06T20:55:33.155685 #1]  INFO -- :
I, [2021-08-06T20:55:33.155839 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.156037 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.156212 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2021-08-06T20:55:33.156384 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2021-08-06T20:55:33.156543 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-08-06T20:55:33.156693 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2021-08-06T20:55:33.156821 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2021-08-06T20:55:33.157605 #1]  INFO -- : > sleep 5
2021-08-06 20:55:33.189 UTC [57] LOG:  starting PostgreSQL 13.3 (Debian 13.3-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2021-08-06 20:55:33.189 UTC [57] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2021-08-06 20:55:33.189 UTC [57] LOG:  listening on IPv6 address "::", port 5432
2021-08-06 20:55:33.197 UTC [57] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2021-08-06 20:55:33.207 UTC [60] LOG:  database system was shut down at 2021-08-06 20:54:23 UTC
2021-08-06 20:55:33.220 UTC [57] LOG:  database system is ready to accept connections
I, [2021-08-06T20:55:38.159279 #1]  INFO -- :
I, [2021-08-06T20:55:38.159499 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2021-08-06 20:55:38.191 UTC [70] postgres@postgres ERROR:  database "discourse" already exists
2021-08-06 20:55:38.191 UTC [70] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2021-08-06T20:55:38.192499 #1]  INFO -- :
I, [2021-08-06T20:55:38.192655 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2021-08-06 20:55:38.229 UTC [81] postgres@discourse ERROR:  role "discourse" already exists
2021-08-06 20:55:38.229 UTC [81] postgres@discourse STATEMENT:  create user discourse;
I, [2021-08-06T20:55:38.230113 #1]  INFO -- :
I, [2021-08-06T20:55:38.230240 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2021-08-06T20:55:38.264816 #1]  INFO -- : GRANT
I, [2021-08-06T20:55:38.264954 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2021-08-06T20:55:38.300671 #1]  INFO -- : ALTER SCHEMA
I, [2021-08-06T20:55:38.300800 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2021-08-06T20:55:38.338165 #1]  INFO -- : CREATE EXTENSION
I, [2021-08-06T20:55:38.338299 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2021-08-06T20:55:38.373916 #1]  INFO -- : CREATE EXTENSION
I, [2021-08-06T20:55:38.374048 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2021-08-06T20:55:38.411727 #1]  INFO -- : CREATE EXTENSION
I, [2021-08-06T20:55:38.411860 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2021-08-06T20:55:38.447989 #1]  INFO -- : CREATE EXTENSION
I, [2021-08-06T20:55:38.448182 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2021-08-06T20:55:38.450095 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2021-08-06T20:55:38.491795 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2021-08-06T20:55:38.493826 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2021-08-06T20:55:38.493898 #1]  INFO -- : > echo postgres installed!
I, [2021-08-06T20:55:38.494947 #1]  INFO -- : postgres installed!
I, [2021-08-06T20:55:38.498073 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2021-08-06T20:55:38.501701 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2021-08-06T20:55:38.505031 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2021-08-06T20:55:38.505155 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.505503 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.506380 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2021-08-06T20:55:38.508241 #1]  INFO -- :
I, [2021-08-06T20:55:38.508462 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.508754 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.508994 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.511494 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.511692 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2021-08-06T20:55:38.511889 #1]  INFO -- : > echo redis installed
I, [2021-08-06T20:55:38.513410 #1]  INFO -- : redis installed
I, [2021-08-06T20:55:38.513516 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2021-08-06T20:55:38.515983 #1]  INFO -- : logfile ""
I, [2021-08-06T20:55:38.516072 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-08-06T20:55:38.518035 #1]  INFO -- : > sleep 10
174:C 06 Aug 2021 20:55:38.520 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
174:C 06 Aug 2021 20:55:38.520 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=174, just started
174:C 06 Aug 2021 20:55:38.520 # Configuration loaded
174:M 06 Aug 2021 20:55:38.520 * monotonic clock: POSIX clock_gettime
174:M 06 Aug 2021 20:55:38.521 * Running mode=standalone, port=6379.
174:M 06 Aug 2021 20:55:38.521 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
174:M 06 Aug 2021 20:55:38.521 # Server initialized
174:M 06 Aug 2021 20:55:38.521 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
174:M 06 Aug 2021 20:55:38.521 * Loading RDB produced by version 6.2.3
174:M 06 Aug 2021 20:55:38.521 * RDB age 75 seconds
174:M 06 Aug 2021 20:55:38.521 * RDB memory usage when created 5.00 Mb
174:M 06 Aug 2021 20:55:38.529 * DB loaded from disk: 0.008 seconds
174:M 06 Aug 2021 20:55:38.529 * Ready to accept connections
I, [2021-08-06T20:55:48.519778 #1]  INFO -- :
I, [2021-08-06T20:55:48.520057 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2021-08-06T20:55:48.523431 #1]  INFO -- : thpoff is installed!
I, [2021-08-06T20:55:48.523576 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2021-08-06T20:55:48.573512 #1]  INFO -- :
I, [2021-08-06T20:55:48.573664 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2021-08-06T20:55:48.625016 #1]  INFO -- :
I, [2021-08-06T20:55:48.625183 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2021-08-06T20:55:48.673708 #1]  INFO -- :
I, [2021-08-06T20:55:48.673858 #1]  INFO -- : > chown -R discourse /home/discourse
I, [2021-08-06T20:55:50.187443 #1]  INFO -- :
I, [2021-08-06T20:55:50.187715 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2021-08-06T20:55:50.190315 #1]  INFO -- :
I, [2021-08-06T20:55:50.192649 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2021-08-06T20:55:50.196279 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2021-08-06T20:55:50.200029 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2021-08-06T20:55:50.203299 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2021-08-06T20:55:50.206916 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2021-08-06T20:55:50.210465 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2021-08-06T20:55:50.210557 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2021-08-06T20:55:50.210743 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2021-08-06T20:55:50.212426 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
202:C 06 Aug 2021 20:55:50.214 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
202:C 06 Aug 2021 20:55:50.214 # Redis version=6.2.3, bits=64, commit=00000000, modified=0, pid=202, just started
202:C 06 Aug 2021 20:55:50.214 # Configuration loaded
202:M 06 Aug 2021 20:55:50.214 * monotonic clock: POSIX clock_gettime
202:M 06 Aug 2021 20:55:50.214 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
202:M 06 Aug 2021 20:55:50.214 # Failed listening on port 6379 (TCP), aborting.
Checking out files: 100% (28860/28860), done.
I, [2021-08-06T20:55:51.872305 #1]  INFO -- : HEAD is now at 74f71503 FEATURE: Automatically timed delete stub topics after entire topic is merged into another topic (#13187)
I, [2021-08-06T20:55:51.872402 #1]  INFO -- : > cd /var/www/discourse && git clean -f
I, [2021-08-06T20:55:51.958388 #1]  INFO -- :
I, [2021-08-06T20:55:51.958493 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2021-08-06T20:55:51.960768 #1]  INFO -- :
I, [2021-08-06T20:55:51.960820 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2021-08-06T20:55:51.965935 #1]  INFO -- :
I, [2021-08-06T20:55:51.966003 #1]  INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
From https://github.com/discourse/discourse
 * branch              tests-passed -> FETCH_HEAD
 * [new branch]        tests-passed -> origin/tests-passed
I, [2021-08-06T20:55:54.476291 #1]  INFO -- :
I, [2021-08-06T20:55:54.476389 #1]  INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2021-08-06T20:55:55.350856 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2021-08-06T20:55:55.350965 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2021-08-06T20:55:55.354244 #1]  INFO -- :
I, [2021-08-06T20:55:55.354326 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2021-08-06T20:55:55.356693 #1]  INFO -- :
I, [2021-08-06T20:55:55.356748 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2021-08-06T20:55:55.359270 #1]  INFO -- :
I, [2021-08-06T20:55:55.359354 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2021-08-06T20:55:55.361644 #1]  INFO -- :
I, [2021-08-06T20:55:55.361707 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2021-08-06T20:55:55.363277 #1]  INFO -- :
I, [2021-08-06T20:55:55.363319 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2021-08-06T20:55:55.365505 #1]  INFO -- :
I, [2021-08-06T20:55:55.365568 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2021-08-06T20:55:55.368090 #1]  INFO -- :
I, [2021-08-06T20:55:55.368151 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2021-08-06T20:55:55.371120 #1]  INFO -- :
I, [2021-08-06T20:55:55.371179 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2021-08-06T20:55:55.374060 #1]  INFO -- :
I, [2021-08-06T20:55:55.374111 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2021-08-06T20:55:55.377133 #1]  INFO -- :
I, [2021-08-06T20:55:55.377205 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2021-08-06T20:55:55.380123 #1]  INFO -- :
I, [2021-08-06T20:55:55.380185 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2021-08-06T20:55:55.383105 #1]  INFO -- :
I, [2021-08-06T20:55:55.383169 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2021-08-06T20:55:55.391208 #1]  INFO -- :
I, [2021-08-06T20:55:55.391282 #1]  INFO -- : > cd /var/www/discourse && find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2021-08-06T20:55:55.393641 #1]  INFO -- :
I, [2021-08-06T20:55:55.393753 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2021-08-06T20:55:55.394026 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2021-08-06T20:55:56.240429 #1]  INFO -- :
I, [2021-08-06T20:55:56.240543 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-voting.git
Cloning into 'discourse-voting'...
I, [2021-08-06T20:55:56.774041 #1]  INFO -- :
I, [2021-08-06T20:55:56.774147 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/davidmh/discourse-giphy.git
Cloning into 'discourse-giphy'...
I, [2021-08-06T20:55:57.855222 #1]  INFO -- :
I, [2021-08-06T20:55:57.855328 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/davidtaylorhq/discourse-telegram-notifications
Cloning into 'discourse-telegram-notifications'...
I, [2021-08-06T20:55:58.284365 #1]  INFO -- :
I, [2021-08-06T20:55:58.284615 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2021-08-06T20:55:58.287516 #1]  INFO -- :
I, [2021-08-06T20:55:58.287618 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2021-08-06T20:55:58.289302 #1]  INFO -- :
I, [2021-08-06T20:55:58.289392 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2021-08-06T20:55:58.291290 #1]  INFO -- :
I, [2021-08-06T20:55:58.291439 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2021-08-06T20:55:58.291656 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2021-08-06T20:55:58.291818 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2021-08-06T20:55:58.291946 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2021-08-06T20:55:58.292066 #1]  INFO -- : > echo "done configuring web"
I, [2021-08-06T20:55:58.293474 #1]  INFO -- : done configuring web
I, [2021-08-06T20:55:58.293625 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2021-08-06T20:55:58.899514 #1]  INFO -- : Successfully installed bundler-2.2.19
1 gem installed
I, [2021-08-06T20:55:58.899611 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2021-08-06T20:56:07.547504 #1]  INFO -- :
I, [2021-08-06T20:56:07.547736 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
I, [2021-08-06T20:56:22.471464 #1]  INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.2.19
Frozen, using resolution from the lockfile
The definition is missing ["rake-13.0.6", "concurrent-ruby-1.1.9", "nokogiri-1.12.2-x86_64-linux", "loofah-2.11.0", "globalid-0.5.2", "addressable-2.8.0", "aws-sdk-kms-1.44.0", "aws-sdk-s3-1.96.1", "bootsnap-1.7.7", "css_parser-1.10.0", "excon-0.85.0", "faraday-httpclient-1.0.1", "faraday-net_http_persistent-1.2.0", "faraday-patron-1.0.0", "faraday-rack-1.0.0", "ruby2_keywords-0.0.5", "faraday-1.6.0", "fastimage-2.2.4", "ffi-1.15.3", "image_size-2.1.1", "logster-2.9.7", "message_bus-3.3.6", "redis-4.4.0", "nio4r-2.5.8", "oj-3.12.3", "puma-5.4.0", "rqrcode_core-1.1.0", "rubyzip-2.3.2", "sanitize-6.0.0"]
HTTP GET https://index.rubygems.org/versions
HTTP 206 Partial Content https://index.rubygems.org/versions
HTTP 200 OK https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Double checking for ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-httpclient", "faraday-net_http", "faraday-net_http_persistent", "faraday-patron", "faraday-rack", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"] in rubygems repository https://rubygems.org/ or installed locally
Looking up gems ["rake", "concurrent-ruby", "i18n", "minitest", "tzinfo", "zeitwerk", "activesupport", "builder", "erubi", "racc", "nokogiri", "rails-dom-testing", "crass", "loofah", "rails-html-sanitizer", "actionview", "rack", "rack-test", "actionpack", "globalid", "activejob", "mini_mime", "actionmailer", "actionview_precompiler", "activemodel", "active_model_serializers", "activerecord", "public_suffix", "addressable", "aws-eventstream", "aws-partitions", "aws-sigv4", "jmespath", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "ember-source", "execjs", "barber", "msgpack", "bootsnap", "byebug", "cbor", "chunky_png", "coderay", "colored2", "connection_pool", "openssl", "openssl-signature_algorithm", "cose", "cppjieba_rb", "css_parser", "diffy", "ember-data-source", "sprockets", "ember-handlebars-template", "method_source", "thor", "railties", "jquery-rails", "discourse-ember-rails", "discourse-ember-source", "discourse-fonts", "regexp_parser", "ecma-re-validator", "email_reply_trimmer", "excon", "exifr", "faraday-em_http", "faraday-em_synchrony", "faraday-excon", "faraday-httpclient", "faraday-net_http", "faraday-net_http_persistent", "faraday-patron", "faraday-rack", "multipart-post", "ruby2_keywords", "faraday", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "guess_html_encoding", "hana", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "image_size", "in_threads", "progress", "image_optim", "json", "uri_template", "json_schemer", "jwt", "kgio", "libv8-node", "request_store", "lograge", "logstash-event", "logstash-logger", "logster", "lru_redux", "lz4-ruby", "maxminddb", "memory_profiler", "message_bus", "mini_racer", "redis", "sidekiq", "mini_scheduler", "mini_sql", "mini_suffix", "multi_json", "multi_xml", "mustache", "nio4r", "oauth", "oauth2", "oj", "omniauth", "omniauth-oauth2", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-twitter", "optimist", "pg", "pry", "pry-byebug", "pry-rails", "puma", "r2", "rack-mini-profiler", "rack-protection", "rails_failover", "rails_multisite", "raindrops", "rbtrace", "rchardet", "redis-namespace", "rinku", "rotp", "rqrcode_core", "rqrcode", "rtlit", "ruby-readability", "rubyzip", "sanitize", "sassc", "sprockets-rails", "tilt", "sassc-rails", "seed-fu", "sshkey", "stackprof", "uglifier", "unf_ext", "unf", "unicorn", "webpush", "xorcist"]
HTTP GET https://index.rubygems.org/info/zeitwerk
HTTP GET https://index.rubygems.org/info/actionmailer
HTTP GET https://index.rubygems.org/info/actionpack
HTTP GET https://index.rubygems.org/info/nokogiri
HTTP GET https://index.rubygems.org/info/rake
HTTP GET https://index.rubygems.org/info/actionview
HTTP GET https://index.rubygems.org/info/globalid
HTTP GET https://index.rubygems.org/info/concurrent-ruby
HTTP GET https://index.rubygems.org/info/activemodel
HTTP GET https://index.rubygems.org/info/activesupport
HTTP GET https://index.rubygems.org/info/loofah
HTTP GET https://index.rubygems.org/info/activejob
HTTP GET https://index.rubygems.org/info/activerecord
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP GET https://index.rubygems.org/info/aws-sigv4
HTTP GET https://index.rubygems.org/info/aws-sdk-core
HTTP GET https://index.rubygems.org/info/aws-sdk-s3
HTTP GET https://index.rubygems.org/info/addressable
HTTP GET https://index.rubygems.org/info/aws-sdk-kms
HTTP GET https://index.rubygems.org/info/aws-sdk-sns
HTTP GET https://index.rubygems.org/info/bootsnap
HTTP 206 Partial Content https://index.rubygems.org/info/zeitwerk
HTTP GET https://index.rubygems.org/info/cppjieba_rb
HTTP GET https://index.rubygems.org/info/css_parser
HTTP 206 Partial Content https://index.rubygems.org/info/actionpack
HTTP GET https://index.rubygems.org/info/railties
HTTP 206 Partial Content https://index.rubygems.org/info/globalid
HTTP 206 Partial Content https://index.rubygems.org/info/nokogiri
HTTP 206 Partial Content https://index.rubygems.org/info/concurrent-ruby
HTTP 206 Partial Content https://index.rubygems.org/info/loofah
HTTP 206 Partial Content https://index.rubygems.org/info/actionview
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/addressable
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-kms
HTTP 206 Partial Content https://index.rubygems.org/info/railties
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sigv4
HTTP 206 Partial Content https://index.rubygems.org/info/activerecord
HTTP 206 Partial Content https://index.rubygems.org/info/rake
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-core
HTTP 206 Partial Content https://index.rubygems.org/info/activemodel
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-s3
HTTP 206 Partial Content https://index.rubygems.org/info/activejob
HTTP 206 Partial Content https://index.rubygems.org/info/activesupport
HTTP 206 Partial Content https://index.rubygems.org/info/actionmailer
HTTP 206 Partial Content https://index.rubygems.org/info/bootsnap
HTTP 206 Partial Content https://index.rubygems.org/info/cppjieba_rb
HTTP 206 Partial Content https://index.rubygems.org/info/css_parser
HTTP GET https://index.rubygems.org/info/faraday-httpclient
HTTP GET https://index.rubygems.org/info/excon
HTTP GET https://index.rubygems.org/info/faraday-rack
HTTP GET https://index.rubygems.org/info/faraday-patron
HTTP 206 Partial Content https://index.rubygems.org/info/aws-sdk-sns
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP 200 OK https://index.rubygems.org/info/faraday-rack
HTTP GET https://index.rubygems.org/info/faraday-net_http_persistent
HTTP GET https://index.rubygems.org/info/ruby2_keywords
HTTP GET https://index.rubygems.org/info/fastimage
HTTP 200 OK https://index.rubygems.org/info/faraday-httpclient
HTTP GET https://index.rubygems.org/info/ffi
HTTP 200 OK https://index.rubygems.org/info/faraday-patron
HTTP GET https://index.rubygems.org/info/image_size
HTTP 206 Partial Content https://index.rubygems.org/info/fastimage
HTTP 206 Partial Content https://index.rubygems.org/info/faraday-net_http_persistent
HTTP 206 Partial Content https://index.rubygems.org/info/ffi
HTTP 206 Partial Content https://index.rubygems.org/info/image_size
HTTP GET https://index.rubygems.org/info/redis
HTTP GET https://index.rubygems.org/info/logster
HTTP 206 Partial Content https://index.rubygems.org/info/ruby2_keywords
HTTP 206 Partial Content https://index.rubygems.org/info/redis
HTTP GET https://index.rubygems.org/info/message_bus
HTTP GET https://index.rubygems.org/info/oj
HTTP GET https://index.rubygems.org/info/nio4r
HTTP GET https://index.rubygems.org/info/puma
HTTP 206 Partial Content https://index.rubygems.org/info/message_bus
HTTP 206 Partial Content https://index.rubygems.org/info/oj
HTTP GET https://index.rubygems.org/info/rqrcode_core
HTTP GET https://index.rubygems.org/info/rubyzip
HTTP GET https://index.rubygems.org/info/sanitize
HTTP 206 Partial Content https://index.rubygems.org/info/nio4r
HTTP 206 Partial Content https://index.rubygems.org/info/puma
HTTP 206 Partial Content https://index.rubygems.org/info/logster
HTTP 206 Partial Content https://index.rubygems.org/info/rqrcode_core
HTTP 206 Partial Content https://index.rubygems.org/info/rubyzip
HTTP 206 Partial Content https://index.rubygems.org/info/sanitize
Looking up gems ["rails-deprecated_sanitizer", "thread_safe", "jsonapi", "case_transform", "jsonapi-renderer", "json_pure", "handlebars-source", "ember-template-compiler-source", "columnize", "debugger-linecache", "slop", "rb-readline", "hike", "ruby_parser", "rails", "erubis", "rack-mount", "rack-cache", "journey", "rspec", "functional-ruby", "ref", "rack-ssl", "rdoc", "arel", "activerecord-deprecated_finders", "mail", "text-format", "hoe", "weakling", "mini_portile", "mini_portile2", "pkg-config", "memcache-client", "rake-compiler", "rb-appscript", "xattr", "ffi-xattr", "activemodel-globalid", "termios", "bcrypt-ruby", "rdf", "snappy", "stud", "celluloid", "compass", "sass", "sprockets-sass", "sinatra", "slim", "libv8", "jamespath", "http-2", "ruby-hmac", "faraday-middleware", "httpauth", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "win32console", "yard", "spoon", "pry-doc", "escape_utils", "listen", "trollop", "base32", "net-http-persistent", "bundler", "therubyracer", "eventmachine", "thin", "bigdecimal", "hpricot", "nokogumbo"]
HTTP GET https://index.rubygems.org/info/rails
HTTP GET https://index.rubygems.org/info/slop
HTTP GET https://index.rubygems.org/info/ruby_parser
HTTP GET https://index.rubygems.org/info/rdoc
HTTP 206 Partial Content https://index.rubygems.org/info/rails
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP GET https://index.rubygems.org/info/hoe
HTTP GET https://index.rubygems.org/info/rdf
HTTP 206 Partial Content https://index.rubygems.org/info/ruby_parser
HTTP GET https://index.rubygems.org/info/listen
HTTP 206 Partial Content https://index.rubygems.org/info/rdoc
HTTP GET https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/slop
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/hoe
HTTP 206 Partial Content https://index.rubygems.org/info/rdf
HTTP 206 Partial Content https://index.rubygems.org/info/listen
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
Looking up gems ["jsonapi-parser", "abstract", "rspec-core", "rspec-expectations", "rspec-mocks", "atomic", "spruz", "ruby_core_source", "debugger-ruby_core_source", "multimap", "text-hyphen", "mime-types", "treetop", "tlsmail", "metriks", "bcrypt", "haml", "fssm", "compass-core", "compass-import-once", "rb-fsevent", "rb-inotify", "ZenTest", "RubyInline", "snappy-jars", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "sprockets-helpers", "mongrel", "backports", "mustermann", "sass-listen", "rack-openid", "ruby-openid-apps-discovery", "temple", "restclient", "rest-client", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "curses", "daemons", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "ParseTree", "sexp_processor", "net-ftp", "rubyforge", "gemcutter", "link_header", "hamster", "rb-fchange", "rb-kqueue", "celluloid-io", "ruby_dep"]
HTTP GET https://index.rubygems.org/info/net-ftp
HTTP GET https://index.rubygems.org/info/haml
HTTP GET https://index.rubygems.org/info/facter
HTTP GET https://index.rubygems.org/info/curses
HTTP GET https://index.rubygems.org/info/actioncable
HTTP GET https://index.rubygems.org/info/activestorage
HTTP GET https://index.rubygems.org/info/actionmailbox
HTTP GET https://index.rubygems.org/info/actiontext
HTTP 200 OK https://index.rubygems.org/info/net-ftp
HTTP 206 Partial Content https://index.rubygems.org/info/haml
HTTP 206 Partial Content https://index.rubygems.org/info/facter
HTTP 206 Partial Content https://index.rubygems.org/info/curses
HTTP 206 Partial Content https://index.rubygems.org/info/actioncable
HTTP 206 Partial Content https://index.rubygems.org/info/actiontext
HTTP 206 Partial Content https://index.rubygems.org/info/activestorage
HTTP 206 Partial Content https://index.rubygems.org/info/actionmailbox
Looking up gems ["rspec-support", "diff-lcs", "archive-tar-minitar", "facets", "polyglot", "mime-types-data", "hitimes", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "celluloid-gems", "coveralls", "rubocop", "dotenv-deployment", "ruby-openid", "macaddr", "tool", "netrc", "http-cookie", "http-accept", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "rails-observers", "activemodel-serializers-xml", "log4r", "SexpProcessor", "net-scp", "win32-api", "net-protocol", "time", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver", "marcel", "mimemagic"]
HTTP GET https://index.rubygems.org/info/net-protocol
HTTP GET https://index.rubygems.org/info/time
HTTP GET https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/faraday_middleware
HTTP GET https://index.rubygems.org/info/http-cookie
HTTP GET https://index.rubygems.org/info/mime-types-data
HTTP GET https://index.rubygems.org/info/websocket-driver
HTTP 200 OK https://index.rubygems.org/info/net-protocol
HTTP 200 OK https://index.rubygems.org/info/time
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
HTTP 206 Partial Content https://index.rubygems.org/info/http-cookie
HTTP 206 Partial Content https://index.rubygems.org/info/faraday_middleware
HTTP 206 Partial Content https://index.rubygems.org/info/mime-types-data
HTTP 206 Partial Content https://index.rubygems.org/info/websocket-driver
Looking up gems ["colorize", "simplecov", "term-ansicolor", "tins", "minitar", "minitar-cli", "configuration", "mkrf", "ruby-yadis", "systemu", "net-ssh", "test-unit", "ffi-win32-extensions", "libxml-ruby", "coffee-script", "hiredis", "io-wait", "timeout", "rainbow", "parser", "powerpack", "ruby-progressbar", "astrolabe", "unicode-display_width", "parallel", "jaro_winkler", "psych", "rexml", "rubocop-ast", "domain_name", "sqlite3", "roauth", "websocket-extensions"]
HTTP GET https://index.rubygems.org/info/io-wait
HTTP GET https://index.rubygems.org/info/timeout
HTTP GET https://index.rubygems.org/info/test-unit
HTTP GET https://index.rubygems.org/info/parser
HTTP GET https://index.rubygems.org/info/rubocop-ast
HTTP GET https://index.rubygems.org/info/psych
HTTP 200 OK https://index.rubygems.org/info/timeout
HTTP 206 Partial Content https://index.rubygems.org/info/test-unit
HTTP 206 Partial Content https://index.rubygems.org/info/psych
HTTP 206 Partial Content https://index.rubygems.org/info/parser
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop-ast
HTTP 200 OK https://index.rubygems.org/info/io-wait
Looking up gems ["sync", "powerbar", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "simplecov-html", "docile", "lockfile", "simplecov_json_formatter", "coffee-script-source", "power_assert", "jar-dependencies", "ast", "strscan"]
Looking up gems ["ansi", "ruby-maven", "pattern-match"]
Looking up gems ["maven-tools", "ruby-maven-libs"]
Looking up gems ["virtus"]
HTTP GET https://index.rubygems.org/info/virtus
HTTP 206 Partial Content https://index.rubygems.org/info/virtus
Looking up gems ["descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["ice_nine", "adamantium"]
Looking up gems ["memoizable"]
Fetching rake 13.0.6
Installing rake 13.0.6
0:  rake (13.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rake-13.0.6.gemspec
Using minitest 5.14.4
Using zeitwerk 2.4.2
Using builder 3.2.4
1:  minitest (5.14.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
Using erubi 1.10.0
Fetching concurrent-ruby 1.1.9
1:  erubi (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/erubi-1.10.0.gemspec
Using racc 1.5.2
1:  racc (1.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/racc-1.5.2.gemspec
Using crass 1.0.6
1:  crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/crass-1.0.6.gemspec
Using rack 2.2.3
1:  rack (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-2.2.3.gemspec
Using mini_mime 1.1.0
1:  mini_mime (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_mime-1.1.0.gemspec
Using public_suffix 4.0.6
1:  public_suffix (4.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/public_suffix-4.0.6.gemspec
Using aws-eventstream 1.1.1
1:  aws-eventstream (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-eventstream-1.1.1.gemspec
Using aws-partitions 1.432.0
1:  aws-partitions (1.432.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-partitions-1.432.0.gemspec
Using jmespath 1.4.0
1:  jmespath (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jmespath-1.4.0.gemspec
Using ember-source 2.18.2
1:  ember-source (2.18.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-source-2.18.2.gemspec
Using execjs 2.8.1
1:  execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/execjs-2.8.1.gemspec
Using msgpack 1.4.2
1:  msgpack (1.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
Using bundler 2.2.19
1:  bundler (2.2.19) from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.19/lib/bundler/source
Using byebug 11.1.3
1:  byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
2:  zeitwerk (2.4.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/zeitwerk-2.4.2.gemspec
1:  cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cbor-0.5.9.6.gemspec
Using chunky_png 1.4.0
2:  chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
2:  coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
2:  colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.2.5
2:  connection_pool (2.2.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/connection_pool-2.2.5.gemspec
Using openssl 2.2.0
2:  openssl (2.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-2.2.0.gemspec
Using cppjieba_rb 0.3.3
2:  cppjieba_rb (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cppjieba_rb-0.3.3.gemspec
Using diffy 3.4.0
2:  diffy (3.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/diffy-3.4.0.gemspec
Using method_source 1.0.0
2:  method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/method_source-1.0.0.gemspec
Using thor 1.1.0
2:  thor (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/thor-1.1.0.gemspec
Using discourse-ember-source 3.12.2.3
2:  discourse-ember-source (3.12.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-source-3.12.2.3.gemspec
Using discourse-fonts 0.0.8
2:  discourse-fonts (0.0.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-fonts-0.0.8.gemspec
Using regexp_parser 2.1.1
2:  regexp_parser (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/regexp_parser-2.1.1.gemspec
Using email_reply_trimmer 0.1.13
2:  email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/email_reply_trimmer-0.1.13.gemspec
Using exifr 1.3.9
1:  exifr (1.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/exifr-1.3.9.gemspec
Using faraday-em_http 1.0.0
3:  builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/builder-3.2.4.gemspec
Using faraday-em_synchrony 1.0.0
3:  faraday-em_synchrony (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_synchrony-1.0.0.gemspec
Fetching excon 0.85.0
1:  faraday-em_http (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-em_http-1.0.0.gemspec
Using faraday-excon 1.1.0
1:  faraday-excon (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-excon-1.1.0.gemspec
Using faraday-net_http 1.0.1
3:  faraday-net_http (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http-1.0.1.gemspec
Fetching faraday-httpclient 1.0.1
Fetching faraday-net_http_persistent 1.2.0
Installing concurrent-ruby 1.1.9
Installing faraday-httpclient 1.0.1
Installing faraday-net_http_persistent 1.2.0
1:  faraday-httpclient (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-httpclient-1.0.1.gemspec
Fetching faraday-patron 1.0.0
3:  faraday-net_http_persistent (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-net_http_persistent-1.2.0.gemspec
Fetching faraday-rack 1.0.0
Installing excon 0.85.0
Installing faraday-patron 1.0.0
Installing faraday-rack 1.0.0
1:  faraday-patron (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-patron-1.0.0.gemspec
Using multipart-post 2.1.1
1:  multipart-post (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multipart-post-2.1.1.gemspec
Fetching ruby2_keywords 0.0.5
3:  faraday-rack (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-rack-1.0.0.gemspec
Using fast_blank 1.0.0
3:  fast_blank (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_blank-1.0.0.gemspec
Using fast_xs 0.8.0
3:  fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fast_xs-0.8.0.gemspec
2:  excon (0.85.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/excon-0.85.0.gemspec
Fetching fastimage 2.2.4
Fetching ffi 1.15.3
Installing ruby2_keywords 0.0.5
Installing fastimage 2.2.4
1:  ruby2_keywords (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby2_keywords-0.0.5.gemspec
Using fspath 3.1.2
1:  fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
1:  gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
1:  guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
1:  hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hana-1.3.7.gemspec
Using hashie 4.1.0
1:  hashie (4.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hashie-4.1.0.gemspec
Using highline 2.0.3
1:  highline (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/highline-2.0.3.gemspec
Using hkdf 0.3.0
1:  hkdf (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/hkdf-0.3.0.gemspec
Using htmlentities 4.3.4
1:  htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
1:  http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/http_accept_language-2.1.1.gemspec
Fetching image_size 2.1.1
3:  fastimage (2.2.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/fastimage-2.2.4.gemspec
Using in_threads 1.5.4
3:  in_threads (1.5.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/in_threads-1.5.4.gemspec
Using progress 3.6.0
3:  progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/progress-3.6.0.gemspec
Using json 2.5.1
3:  json (2.5.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json-2.5.1.gemspec
Using uri_template 0.7.0
3:  uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uri_template-0.7.0.gemspec
Using jwt 2.2.3
3:  jwt (2.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jwt-2.2.3.gemspec
Using kgio 2.11.4
3:  kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 15.14.0.1 (x86_64-linux)
3:  libv8-node (15.14.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/libv8-node-15.14.0.1-x86_64-linux.gemspec
Using logstash-event 1.2.02
3:  logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-event-1.2.02.gemspec
Fetching logster 2.9.7
0:  concurrent-ruby (1.1.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/concurrent-ruby-1.1.9.gemspec
Using lru_redux 1.1.0
0:  lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
0:  lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lz4-ruby-0.3.3.gemspec
Using maxminddb 0.1.22
0:  maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.0
0:  memory_profiler (1.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/memory_profiler-1.0.0.gemspec
Fetching redis 4.4.0
Installing ffi 1.15.3 with native extensions
Installing image_size 2.1.1
Installing redis 4.4.0
1:  image_size (2.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_size-2.1.1.gemspec
Using mini_sql 1.1.3
1:  mini_sql (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_sql-1.1.3.gemspec
Using multi_json 1.15.0
1:  multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
1:  multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
1:  mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mustache-1.1.1.gemspec
Fetching nio4r 2.5.8
Installing logster 2.9.7
0:  redis (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-4.4.0.gemspec
Using oauth 0.5.6
0:  oauth (0.5.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth-0.5.6.gemspec
Fetching oj 3.12.3
Installing nio4r 2.5.8 with native extensions
Installing oj 3.12.3 with native extensions
Building native extensions. This could take a while...
3:  logster (2.9.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logster-2.9.7.gemspec
Using optimist 3.0.1
3:  optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/optimist-3.0.1.gemspec
Using pg 1.2.3
3:  pg (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pg-1.2.3.gemspec
Using r2 0.2.7
3:  r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.19.2
3:  raindrops (0.19.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/raindrops-0.19.2.gemspec
Using rchardet 1.8.0
3:  rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
Using rinku 2.0.6
3:  rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.0
3:  rotp (6.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rotp-6.2.0.gemspec
Fetching rqrcode_core 1.1.0
Installing rqrcode_core 1.1.0
3:  rqrcode_core (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode_core-1.1.0.gemspec
Using rtlit 0.0.5
3:  rtlit (0.0.5) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rtlit-0.0.5.gemspec
Fetching rubyzip 2.3.2
Installing rubyzip 2.3.2
RubyZip 3.0 is coming!
The public API of some Rubyzip classes has been modernized to use named
parameters for optional arguments. Please check your usage of the
following classes:
  * `Zip::File`
  * `Zip::Entry`
  * `Zip::InputStream`
  * `Zip::OutputStream`
Please ensure that your Gemfiles and .gemspecs are suitably restrictive
to avoid an unexpected breakage when 3.0 is released (e.g. ~> 2.3.0).
See https://github.com/rubyzip/rubyzip for details. The Changelog also
lists other enhancements and bugfixes that have been implemented since
version 2.3.0.
3:  rubyzip (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rubyzip-2.3.2.gemspec
Using tilt 2.0.10
3:  tilt (2.0.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tilt-2.0.10.gemspec
Using sshkey 2.0.0
3:  sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.17
3:  stackprof (0.2.17) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/stackprof-0.2.17.gemspec
Using unf_ext 0.0.7.7
3:  unf_ext (0.0.7.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf_ext-0.0.7.7.gemspec
Using xorcist 1.1.2
3:  xorcist (1.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/xorcist-1.1.2.gemspec
Fetching nokogiri 1.12.2 (x86_64-linux)
Installing nokogiri 1.12.2 (x86_64-linux)
3:  nokogiri (1.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nokogiri-1.12.2-x86_64-linux.gemspec
Using rack-test 1.1.0
3:  rack-test (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-test-1.1.0.gemspec
Using request_store 1.5.0
3:  request_store (1.5.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/request_store-1.5.0.gemspec
Fetching message_bus 3.3.6
Installing message_bus 3.3.6
3:  message_bus (3.3.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/message_bus-3.3.6.gemspec
Using rack-mini-profiler 2.3.2
3:  rack-mini-profiler (2.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-mini-profiler-2.3.2.gemspec
Using rack-protection 2.1.0
3:  rack-protection (2.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rack-protection-2.1.0.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at master@5b700fc)
3:  mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/2.7.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Fetching addressable 2.8.0
Installing addressable 2.8.0
3:  addressable (2.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/addressable-2.8.0.gemspec
Using aws-sigv4 1.2.3
3:  aws-sigv4 (1.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sigv4-1.2.3.gemspec
Using ember-data-source 3.0.2
3:  ember-data-source (3.0.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-data-source-3.0.2.gemspec
Using barber 0.12.2
3:  barber (0.12.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/barber-0.12.2.gemspec
Using uglifier 4.2.0
3:  uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/uglifier-4.2.0.gemspec
Fetching bootsnap 1.7.7
Installing bootsnap 1.7.7 with native extensions
3:  bootsnap (1.7.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/bootsnap-1.7.7.gemspec
Using openssl-signature_algorithm 1.1.1
3:  openssl-signature_algorithm (1.1.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/openssl-signature_algorithm-1.1.1.gemspec
Using pry 0.13.1
3:  pry (0.13.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-0.13.1.gemspec
Using ecma-re-validator 0.3.0
3:  ecma-re-validator (0.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ecma-re-validator-0.3.0.gemspec
Fetching faraday 1.6.0
Installing faraday 1.6.0
3:  faraday (1.6.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/faraday-1.6.0.gemspec
Using omniauth 1.9.1
3:  omniauth (1.9.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-1.9.1.gemspec
Using webpush 1.1.0
3:  webpush (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/webpush-1.1.0.gemspec
Using mini_racer 0.4.0
3:  mini_racer (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_racer-0.4.0.gemspec
Using logstash-logger 0.26.1
3:  logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/logstash-logger-0.26.1.gemspec
Using i18n 1.8.10
3:  i18n (1.8.10) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/i18n-1.8.10.gemspec
Using tzinfo 2.0.4
3:  tzinfo (2.0.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/tzinfo-2.0.4.gemspec
Using sprockets 3.7.2
3:  sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-3.7.2.gemspec
Using image_optim 0.30.0
3:  image_optim (0.30.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/image_optim-0.30.0.gemspec
Using sidekiq 6.2.1
3:  sidekiq (6.2.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sidekiq-6.2.1.gemspec
Using redis-namespace 1.8.1
3:  redis-namespace (1.8.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/redis-namespace-1.8.1.gemspec
Using unicorn 6.0.0
3:  unicorn (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unicorn-6.0.0.gemspec
Using rqrcode 2.0.0
3:  rqrcode (2.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rqrcode-2.0.0.gemspec
Using unf 0.1.4
3:  unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/unf-0.1.4.gemspec
Fetching loofah 2.11.0
Installing loofah 2.11.0
3:  loofah (2.11.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/loofah-2.11.0.gemspec
Using ruby-readability 0.7.0
3:  ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ruby-readability-0.7.0.gemspec
Fetching sanitize 6.0.0
Installing sanitize 6.0.0
3:  sanitize (6.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sanitize-6.0.0.gemspec
Fetching css_parser 1.10.0
Installing css_parser 1.10.0
3:  css_parser (1.10.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/css_parser-1.10.0.gemspec
Using aws-sdk-core 3.112.1
3:  aws-sdk-core (3.112.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-core-3.112.1.gemspec
Using cose 1.2.0
3:  cose (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/cose-1.2.0.gemspec
Using pry-byebug 3.9.0
3:  pry-byebug (3.9.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-byebug-3.9.0.gemspec
Using pry-rails 0.3.9
3:  pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/pry-rails-0.3.9.gemspec
Using json_schemer 0.2.18
3:  json_schemer (0.2.18) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/json_schemer-0.2.18.gemspec
Using oauth2 1.4.7
3:  oauth2 (1.4.7) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oauth2-1.4.7.gemspec
Using omniauth-oauth 1.2.0
3:  omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth-1.2.0.gemspec
Using activesupport 6.1.3.2
3:  activesupport (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activesupport-6.1.3.2.gemspec
Using ember-handlebars-template 0.8.0
3:  ember-handlebars-template (0.8.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ember-handlebars-template-0.8.0.gemspec
Using mini_scheduler 0.13.0
3:  mini_scheduler (0.13.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_scheduler-0.13.0.gemspec
Using rails-html-sanitizer 1.3.0
3:  rails-html-sanitizer (1.3.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-html-sanitizer-1.3.0.gemspec
Fetching aws-sdk-kms 1.44.0
1:  nio4r (2.5.8) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/nio4r-2.5.8.gemspec
Using aws-sdk-sns 1.38.0
1:  aws-sdk-sns (1.38.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-sns-1.38.0.gemspec
Using omniauth-oauth2 1.7.1
1:  omniauth-oauth2 (1.7.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-oauth2-1.7.1.gemspec
Using omniauth-twitter 1.4.0
1:  omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-twitter-1.4.0.gemspec
Using rails-dom-testing 2.0.3
1:  rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails-dom-testing-2.0.3.gemspec
Fetching globalid 0.5.2
Installing globalid 0.5.2
1:  globalid (0.5.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/globalid-0.5.2.gemspec
Using activemodel 6.1.3.2
1:  activemodel (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activemodel-6.1.3.2.gemspec
Fetching puma 5.4.0
Installing aws-sdk-kms 1.44.0
3:  aws-sdk-kms (1.44.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-kms-1.44.0.gemspec
Using omniauth-facebook 8.0.0
3:  omniauth-facebook (8.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-facebook-8.0.0.gemspec
Using omniauth-github 1.4.0
3:  omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
3:  omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Using actionview 6.1.3.2
3:  actionview (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview-6.1.3.2.gemspec
Using activejob 6.1.3.2
3:  activejob (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activejob-6.1.3.2.gemspec
Using active_model_serializers 0.8.4
3:  active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 6.1.3.2
3:  activerecord (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/activerecord-6.1.3.2.gemspec
Fetching aws-sdk-s3 1.96.1
Installing puma 5.4.0 with native extensions
Installing aws-sdk-s3 1.96.1
3:  aws-sdk-s3 (1.96.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/aws-sdk-s3-1.96.1.gemspec
Using actionpack 6.1.3.2
3:  actionpack (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionpack-6.1.3.2.gemspec
Using actionview_precompiler 0.2.3
3:  actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionview_precompiler-0.2.3.gemspec
Using seed-fu 2.3.9
3:  seed-fu (2.3.9) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/seed-fu-2.3.9.gemspec
Using actionmailer 6.1.3.2
3:  actionmailer (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/actionmailer-6.1.3.2.gemspec
Using railties 6.1.3.2
3:  railties (6.1.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/railties-6.1.3.2.gemspec
Using sprockets-rails 3.2.2
3:  sprockets-rails (3.2.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sprockets-rails-3.2.2.gemspec
Using jquery-rails 4.4.0
3:  jquery-rails (4.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/jquery-rails-4.4.0.gemspec
Using lograge 0.11.2
3:  lograge (0.11.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/lograge-0.11.2.gemspec
Using rails_failover 0.7.3
3:  rails_failover (0.7.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_failover-0.7.3.gemspec
Using rails_multisite 3.0.0
3:  rails_multisite (3.0.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rails_multisite-3.0.0.gemspec
Using discourse-ember-rails 0.18.6
3:  discourse-ember-rails (0.18.6) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/discourse-ember-rails-0.18.6.gemspec
1:  puma (5.4.0) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/puma-5.4.0.gemspec
0:  oj (3.12.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/oj-3.12.3.gemspec
2:  ffi (1.15.3) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/ffi-1.15.3.gemspec
Using mini_suffix 0.3.2
Using rbtrace 0.4.14
Using sassc 2.0.1
3:  mini_suffix (0.3.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/mini_suffix-0.3.2.gemspec
0:  sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-2.0.1.gemspec
1:  rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/rbtrace-0.4.14.gemspec
Using sassc-rails 2.1.2
2:  sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/2.7.0/specifications/sassc-rails-2.1.2.gemspec
Bundle complete! 126 Gemfile dependencies, 171 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
Post-install message from rubyzip:
following classes:
  * `Zip::File`
  * `Zip::Entry`
version 2.3.0.
I, [2021-08-06T20:56:22.471704 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake plugin:pull_compatible_all'
I, [2021-08-06T20:56:24.062109 #1]  INFO -- : discourse-voting is already at latest compatible version
discourse-giphy is already at latest compatible version
discourse-telegram-notifications is already at latest compatible version
docker_manager is already at latest compatible version
I, [2021-08-06T20:56:24.062282 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
I, [2021-08-06T20:56:27.409456 #1]  INFO -- :
I, [2021-08-06T20:56:27.409667 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile'
Purging temp files
Bundling assets
I, [2021-08-06T20:56:33.444442 #3947]  INFO -- : Writing /var/www/discourse/public/assets/vendor-9e69876ef88af15a98c891006ce921a856d493aeca4be129f273759800f9fbe2.js
<<<<<<<<<<<<<<<<<<<<OMMITED>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
I, [2021-08-06T20:56:49.951479 #3947]  INFO -- : Writing /var/www/discourse/public/assets/plugins/discourse-details-61554ea83ad59329c2d5c9f0390a0498f3e3665deb58d32dc608aeca24fa0bb9.js
rake aborted!
Barber::PrecompilerError: Pre compilation failed for: {{#d-modal-body id="giphy-modal"}}
  <div>
    {{input
      type="text"
      name="query"
      key-up="refresh"
  </div>
  <div class="giphy-content">
    {{#if loading}}
      {{i18n "loading"}}
    {{/if}}
    <div class="giphy-box">
      {{#each currentGifs as |result|}}
        {{giphy-result content=result pick="pick"}}
      {{/each}}
    </div>
  </div>
{{/d-modal-body}}
. Compiler said: ReferenceError: console is not defined
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/barber-0.12.2/lib/barber/precompiler.rb:33:in `rescue in compile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/barber-0.12.2/lib/barber/precompiler.rb:30:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/sprockets-rails-3.2.2/lib/sprockets/rails/task.rb:66:in `block (2 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
ExecJS::ProgramError: ReferenceError: console is not defined
logDeprecationStackTrace ((execjs):7049:11)
HANDLERS.<computed> ((execjs):7126:11)
raiseOnDeprecation ((execjs):7059:11)
invoke ((execjs):7138:11)
deprecate ((execjs):7097:30)
(execjs):11958:56
Array.forEach ((execjs))
MustacheStatement ((execjs):11956:29)
visitNode ((execjs):10234:16)
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.4.0/lib/mini_racer.rb:219:in `eval_unsafe'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.4.0/lib/mini_racer.rb:219:in `block (2 levels) in eval'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.4.0/lib/mini_racer.rb:339:in `timeout'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/mini_racer-0.4.0/lib/mini_racer.rb:218:in `block in eval'
Caused by:
MiniRacer::RuntimeError: ReferenceError: console is not defined
JavaScript at logDeprecationStackTrace (<anonymous>:7049:11)
JavaScript at HANDLERS.<computed> (<anonymous>:7126:11)
JavaScript at raiseOnDeprecation (<anonymous>:7059:11)
JavaScript at invoke (<anonymous>:7138:11)
JavaScript at deprecate (<anonymous>:7097:30)
JavaScript at <anonymous>:11958:56
JavaScript at Array.forEach (<anonymous>)
JavaScript at MustacheStatement (<anonymous>:11956:29)
JavaScript at visitNode (<anonymous>:10234:16)
Tasks: TOP => assets:precompile
I, [2021-08-06T20:56:50.056489 #1]  INFO -- : Updating Vincent...
Updating Material Design...
I, [2021-08-06T20:56:50.056766 #1]  INFO -- : Terminating async processes
I, [2021-08-06T20:56:50.056803 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 57
I, [2021-08-06T20:56:50.056832 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 174
174:signal-handler (1628283410) Received SIGTERM scheduling shutdown...
2021-08-06 20:56:50.056 UTC [57] LOG:  received fast shutdown request
174:M 06 Aug 2021 20:56:50.067 # User requested shutdown...
174:M 06 Aug 2021 20:56:50.067 * Saving the final RDB snapshot before exiting.
2021-08-06 20:56:50.068 UTC [57] LOG:  aborting any active transactions
2021-08-06 20:56:50.069 UTC [57] LOG:  background worker "logical replication launcher" (PID 66) exited with exit code 1
2021-08-06 20:56:50.069 UTC [61] LOG:  shutting down
174:M 06 Aug 2021 20:56:50.085 * DB saved on disk
174:M 06 Aug 2021 20:56:50.085 # Redis is now ready to exit, bye bye...
2021-08-06 20:56:50.125 UTC [57] LOG:  database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 3945 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'bundle exec rake themes:update assets:precompile'"]}
475409d9256a492683c02da01e68da51c5fd8de79a6f8565ac1de486f734657f
Appreciate your help. Thanks
Try removing the giphy plugin.
It helped. Thanks. Anyway this means the giphy plugin is no more compatible?
It hasn’t been updated since 4 years ago… There are some forks though, moreover see:
