관리자 빠른 시작 가이드 개요의 링크가 깨졌습니다
The links in this checklist of the admin getting started guide no longer work for me
In FIX: Add post id to the anchor to prevent two identical anchors by Lhcfl · Pull Request #28070 · discourse/discourse · GitHub the post-id was added to the anchor.
So while the link links to #magic_wand-complete-the-setup-wizard-3 the anchor of that heading is actually #p-7-magic_wand-complete-the-setup-wizard-3.
Is the id of that post always the same, so that it can simply be added to the link?
2개의 좋아요
Thanks @Moin! I’ve updated this in this PR: Fixing admin quick start links and formatting by hlashbrooke · Pull Request #29711 · discourse/discourse · GitHub - just needs to be approved and merged, which should happen shortly.
1개의 좋아요
Just to add on, I noticed that [details] wasn’t working, so I opened a Pull Request to fix that using <details> instead.
1개의 좋아요
I am not sure that will fix it. You have removed the number at the end, but you did not add the post ID. I tried editing the topic in my #staff category, which is created from the guide, like in your PR, and then the link still doesn’t take me to that section.
Therefore, I have no problem with the [details], they work fine in my Discourse topic.
The PR above was approved but never merged.
Anyway, I think this can be closed. That section is no longer part of the guide.
3개의 좋아요
