Как добавить AWS Cloudfront в качестве CDN для Discourse
We’ve moved the objects (such as image, and others) to AWS S3. Those have been great.
Now we want to speed up the site a bit more. How should I add the AWS cloudfront as the DISCOURSE_CDN?
I tried to setup myself. It works when I am using the forum-cdn. But as soon as I put the url into the discourse_cdn, the site becomes unusable and all images are having multiple redirects and stopped working.
Did you have a look through the documentation here:
also
1 лайк
Yap! I used this one as the way to setup.
But the second post contains which i am not sure if it is the official setup. And the post was from 2021.
Do not configure “DISCOURSE_CDN_URL”
Everything you need should be here, starting with this topic
I’ve already done this. The image of our site is on AWS S3 with cloudfront. I am trying to cache more such as the user_avatar image instead of hitting the server.
2 лайка
The S3 CDN should be DISCOURSE_S3_CDN.
DISCOURSE_CDN is for the app CDN
2 лайка
I understand this part. I am trying to add a full app CDN for the site. So i would like to utilize DISCOURSE_CDN.
